xxxtreme22r's 1987 Pickup Build-Up Thread
Old Jan 8, 2011 | 10:17 AM
  #201
xxxtreme22r's Avatar
I will probably take it apart and paint it come summer. Not too worried about the bare aluminum for right now.
The wood itself seems to be in really good shape considering I think it is not pressure treated. Tailgate panel seems a little warped though.
Pics will come, but my old bed is still in the way and it's snowing lol.
Old Jan 8, 2011 | 10:22 AM
  #202
for you Rob. And yes, that as far as my window goes up !!!
Old Jan 8, 2011 | 10:26 AM
  #203
92 TOY's Avatar
snowing again here after about a 2hr respite. was going to do some running around with the kids but may be reconsidering.
so maybe some good sanding with my belt sander and some deck sealer and you'll be in good shape.
this summer your truck gets painted. i don't care what you say. i have a huge yard and we can park it far away from everything and spray it .
Old Jan 9, 2011 | 07:26 AM
  #204
ok got some more photos for ya. Still got to wire up the passenger side lights yet. Pay no attention to that gas filler either. The one you see is not hooked up. Not sure if I am gonna use that and extend what I am using now or just keep it that way as it's tucked under there pretty good.
Also notice my tail pipe, dang that thing looks awfully low now haha. That just goes to show how much higher the "bumper" sits now than it did before. Right where the reverse lights are the the very end of the frame which is exactly the same height my homemade bumper was. Since the truck is obviously not lifted I doubt the height is gonna be an issue comes inspection time as I don't believe they will even check it.
One issue I may or may not have is the fact this is a little narrower than what I had on before and the 31X10.50's are a little outside of the bed rails. And will most likely face the same issue of my compression travel and tire clearance issues when off-roading. I got till at least spring to figure out what I am gonna do about that. I know my springs are somewhat flat and there is no bump stops there either. Which I am sure is part of the problem.
Old Jan 9, 2011 | 07:47 AM
  #205
xlaxx's Avatar
Subscribed.
I like reading about your truck and mods,... it gives me and my truck,... hope. You da man.
Old Jan 9, 2011 | 07:51 AM
  #206
It's the ultimate budget build haha.
Old Jan 9, 2011 | 07:55 AM
  #207
xlaxx's Avatar
Naw man serious,... you got some skills and seem to be a helpful person (You got a Friend in PA type-'o-guy). Thanks for the reading. The '92 Toy thread was pretty cool with you adjusting that dude's engine, etc. Wish you were local! LOL
Old Jan 9, 2011 | 07:56 AM
  #208
morena67's Avatar
xxxtreme22r, man it's cold up there...!!!
-How come an 87 PU don't have power steering? ...am I right ?
...That box fits just right...congrats...!!!
_Happy new year by the way...
Old Jan 9, 2011 | 08:00 AM
  #209
Just so you now that new bed I DID NOT build.
The only real mods to the truck are the manual to power steering swap, dual diaphragm booster and 1" master cyl, weber carb, downey header (which was already on the truck when I bought it) and the bed. And maybe the exhaust, but all I did was select the components, an exhaust shop put them on. I don't count the 31's or the engine rebuild I did myself which wasn't covered in any threads.
Oh I forgot the upgraded wiring harness for the headlights and fog lights.
Old Jan 9, 2011 | 08:01 AM
  #210
Mine came factory with manual steering. This truck was about as base model as you can get. I am sure there were years before and after this truck that came with power steering.
Old Jan 9, 2011 | 08:07 AM
  #211
xlaxx's Avatar
You going to add a leaf just for clearance?
Old Jan 9, 2011 | 08:10 AM
  #212
no, I am most likely gonna go with the OME 2" leaf springs. This thing is never gonna see anything bigger than a 33" tire nor will it be getting a bracket lift.
Old Jan 9, 2011 | 08:37 AM
  #213
Swimmerboy2112's Avatar
That bed looks AWESOME! WAY better than your old flat bed.
Old Jan 9, 2011 | 08:43 AM
  #214
I agree 100%, also I will not have to ratchet strap almost everything down in it. lol.
I wish I had a line on a cheap spare tire mount though. Also still have to find out if my tool box is gonna fit in there or not.
So far the only bulb that doesn't seem to work right now is the lic plate light. Have not done the passenger side lights yet however.
Oh and the LED tails are real cheap quality the drivers side seems like it has a loose wire or something. fixed it somewhat by taping the wires a little tighter where they go into the light housing.
The smaller round lights are not much better either.
But I am not complaining.
Old Jan 9, 2011 | 09:10 AM
  #215
92 TOY's Avatar
I've got some 2x4's for fender flares.....
oh wait, you've got some spare wood too.
looking good.
Old Jan 9, 2011 | 09:14 AM
  #216
looking good.
Some of that wood I think is gonna be used to make myself a belly plate. I think I can use some of it for a diff drop and BJ spacers as well as some lift blocks for the leaf springs.
Old Jan 9, 2011 | 09:22 AM
  #217
92 TOY's Avatar
Excellent innovation. Be sure to start a thread about those.
maybe you could fab up an antenna out of a baseball bat too.
wood mud flaps
wood roof rack
wood push bar / stinger
Old Jan 9, 2011 | 09:23 AM
  #218
xlaxx's Avatar
Looks like the rear end of a quarter-fly or something, sweet!
Don't forget about tacking that license plate,... PA only has the one in the back right?
Old Jan 9, 2011 | 09:24 AM
  #219
xlaxx's Avatar
...wood license plate frame?
Old Jan 9, 2011 | 09:27 AM
  #220
yeah, only 1 required, there is a bracket for the lic plate I have to put back on, it was riveted I drilled the rivet out so I can bolt it in and make it removable for off-road purposes.
this is what the original owner did with the lic plate:
