Weber 32/36 carb leaking
Old Jan 5, 2023 | 04:47 AM
Bell Farms 86's Avatar
Hello everyone just picked up a 86 toyota pickup with 327k miles on it. It has been well taken care of but I’m having a fuel issue. It is leaking around the 2 piece gasket for the carb. Also after a drive and the motor warms up, after cranking back up again it take 3-4 times to turn motor over before motor cranks. When cranking up from cold it is kinda rough to crank sometimes have to pump gas 2 times to be able to crank.
I plan to install a fuel pressure regulator starting at 2.5psi which is the best to get for easiest use? I also plan to get a LCE performance one piece adapter.
I am new to carb motors so I do not know how to make sure the carb is set up correctly. I am learning though. Thanks.
Old Jan 7, 2023 | 05:14 AM
No one or did I post in wrong spot ?
1987StandardCab2ndGe
May 29, 2014 10:31 AM
WSUWESTON
Dec 14, 2011 09:39 PM
CumminsTurbo4
Apr 7, 2011 12:33 PM
toyotacrawler1
Jan 14, 2009 08:37 AM
raymeg
Apr 23, 2007 10:19 AM
