TheBack40 89 High Desert Runner build & 3.4swap
Old May 12, 2016 | 04:26 PM
Seebolt's Avatar
Trail wheels
Originally Posted by LosPatosDelSur
Took it out with the top off. Can't believe it took me so long to do this engine swap!
I like the new and old twist. I miss my trail.
Old May 18, 2016 | 09:44 AM
LosPatosDelSur's Avatar
Originally Posted by donomite49
anti theft switch? 3.4 is a great v6, nice rig.
I thought about a toggle switch but for safety reasons I like the pump wired in some factory form. My COR was sticking and causing the pump power issues. Got it fixed and now it operates as it should.
Old May 18, 2016 | 09:46 AM
Thanks see bolt. Now I need to fix the paint. The faded camo the PO sprayed on needs to go. The factory white underneath looks cherry. I may try to power wash the thing and get the camo to chip off.
Old Mar 12, 2021 | 03:08 AM
4GunRnr's Avatar
What Engine Mount Bracket and Engine Mount did you use?
1996 3.4 M/T with harness!!!!!! Ecu, air box, O2's, 5 plugs, and some other odds and ends.
What engine Mount bracket and motor Mount did you use? My engine has never sat quite straight. I am currently running Tacoma brackets and motor mounts from a 99 Taco. However, my motor does not sit quit right and I would like to fix this finally.
OutlawMike
Mar 4, 2019 06:45 AM
ClintonP929
3.4 Swaps
7
May 12, 2016 04:49 PM
89hilux1
May 13, 2015 03:13 PM
vmax84
Jul 21, 2005 06:03 AM
