TheBack40 89 High Desert Runner build & 3.4swap
Old Jul 29, 2015 | 10:15 PM
LosPatosDelSur's Avatar
So finally got a new toy! always wanted a 1st gen so here it is! Not sure about the odd faded.... pink ish camo??? I kinda cut up my DD so with this build I'm gonna just keep it simple and will leave the plasma alone..... I hope.
Probably going to start with the 3.4 swap first. I will update as this progresses.
Old Jul 30, 2015 | 07:28 AM
I don't have to cut the top on this one!!!! This thing is sweet!
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-989009452.jpg
Old Jul 30, 2015 | 10:06 AM
1996 3.4 M/T with harness!!!!!! Ecu, air box, O2's, 5 plugs, and some other odds and ends.
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-2970382292.jpg
Old Jul 30, 2015 | 11:52 AM
Alright I have hit a small snag. I downloaded the EWD for the 96 from TIS w/ no problems. I know TIS typically only goes to 1990 so I figured I would just call the toyota dealership and purchase a hard copy of the 89 EWD. Makes sense right? I just got off the phone with the parts dept. and they said they don't have access to the 89 EWD!? Wtf man.... So anybody have any advice? Yes I could trace wires and figure it out but I was hoping to avoid that time consuming task. I have casually searched the inter-tube for the needed diagrams but have not found what I need. I will keep searching but figured I'd post the question as well.
Thanks guys.
Old Jul 31, 2015 | 12:50 PM
Old POS in rig
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-119727415.jpg
Old Jul 31, 2015 | 12:53 PM
Old POS removed from rig
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-3225065650.jpg
Old Jul 31, 2015 | 12:54 PM
Filthy engine bay. I will fix that later.
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-2094201690.jpg
Old Jul 31, 2015 | 12:59 PM
New 3.4 in rig!!!! Now onto the wiring and such. Reused the 3 liter pan, dipstick and tube, pickup tube, alt bracket, and a/c head.
A small tip here would be to use the old driver side hoist hook off the 3.0 and bolt into a vacant bolt hole on the pass side 3.4. It worked great for the swap but only one bolt made me a little uneasy. I will mod it so two bolts can be used and re install.
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-3818229739.jpg
Old Aug 3, 2015 | 08:27 AM
While I'm waiting on the EWD's I thought I would prep the inside for some bedliner. Took all weekend to hammer out the sound deadening black tar. Did it with a hammer and chisel. If I had to do it again I would have used an air chisel.
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-1513845445.jpg
Old Aug 5, 2015 | 01:35 PM
Has anyone one here bought service manuals from Helminc.com? Are they legit?
Old May 12, 2016 | 01:07 PM
It's been awhile, figured I'd update for the hell of it.
This the old crossover chopped up and reconfigured.
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-4264977619.jpg
Old May 12, 2016 | 01:10 PM
The new cross over lined up pretty nicely. Wish I had a shot of it in the rig.
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-3052245418.jpg
Old May 12, 2016 | 01:13 PM
3.4 in and running! I can't believe how much nicer this engine is then the 3.0 or 22re!! This thing is a blast to drive! It even passed emissions!
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-3950555188.jpg
Old May 12, 2016 | 01:14 PM
17 in trail edition wheels.... Any thoughts?
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-2528434756.jpg
Old May 12, 2016 | 01:15 PM
Before,
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-3449123993.jpg
Old May 12, 2016 | 01:16 PM
Terrys87's Avatar
Not sure how I missed this build. Looks like you got a solid runner. I have never bought a manual from Helm so not sure on that. Wiring in a 3.4 does look like it would be the hardest part to me just because I don't fully understand the diagrams. Looking forward to your build. The 3.4 is a great motor and sure it will make a 1st gen runner scoot down the highway.
After,
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-3928097327.jpg
Old May 12, 2016 | 01:18 PM
Took it out with the top off. Can't believe it took me so long to do this engine swap!
Attached Thumbnails TheBack40 89 High Desert Runner build & 3.4swap-image-3008690354.jpg
Old May 12, 2016 | 02:11 PM
Thanks Terry it is pretty solid, I've been back and fourth about selling the dang thing. Every time I drive it though I am amazed at the difference with the 3.4 and don't want to sell it. Too many projects though.
The fuel pump is wired in with a switch currently. All I need to do for the wiring to be Complete is to get the pump to turn on with the COR.
Old May 12, 2016 | 03:24 PM
donomite49's Avatar
anti theft switch? 3.4 is a great v6, nice rig.
