Stanz's 1986 4Runner
Old Jan 3, 2020 | 11:47 PM
  #261
stanz's Avatar
New bumper under development
Old Jan 3, 2020 | 11:51 PM
  #262
stanz's Avatar
Side armor installed. Will serve as mounts for modular roof rack posts when using soft top
Old Jan 4, 2020 | 12:01 AM
  #263
stanz's Avatar
3 link coil over SAS in progress - Tacoma width plus Tacoma rear axle swap. ARB lockers going in front and rear. T100 brakes front rear.
Old May 19, 2020 | 04:36 PM
  #264
stanz's Avatar
Custom sculpting triple switch bezel for the new air lockers
Old May 19, 2020 | 05:34 PM
  #265
84 yota dude's Avatar
Can't wait to see the rig's finished set up!!
Old May 21, 2020 | 09:03 PM
  #266
stanz's Avatar
thanks. I may end up selling it when I finally get it finished. Two years of fighting with the fab shop to finish their half of the work and give me my truck back (we agreed to two months in the shop) has taken the fun away and caused so much personal stress in leaving me without transportation.
Old May 21, 2020 | 10:18 PM
  #267
maco35's Avatar
2 years? That hurts.
Old May 22, 2020 | 02:36 AM
  #268
arlindsay1992's Avatar
Whose idea was it to connect the drag link to the tie rod in that way? Because of the offset between the end of the drag link and the centerline of the tie rod, you're going to have the first bit of steering wheel input cause the tie rod to rotate instead of translate. And as you turn the steering wheel the other way, it will cause the tie rod to rotate the other way before translating. This is a bad design. You're going to have a lot of play in the steering. The drag link should connect to the passenger side steering arm to fix this problem. Either this or make the end of the drag link and both ends of the tie rod EXACTLY in line which is more difficult.
Old May 22, 2020 | 09:24 AM
  #269
[url=https://www.instagram.com/p/B_qBGtKluo7/]
View this post on Instagram
[/ame]
Two years, that's frustrating to say the least.
Old May 22, 2020 | 11:53 AM
  #270
stanz's Avatar
the saddle on the drag tie rod is a tried and proven approach that was borrowed from early Broncos.
if we went to the steering arm, the drag link wouldn’t be parallel with the track bar and there would be tremendous bump steer
Old May 22, 2020 | 01:14 PM
  #271
stanz's Avatar
https://www.instagram.com/p/B_qBGtKluo7/[/ame]
beyond frustrating. It’s caused major issues for me
Old May 22, 2020 | 01:36 PM
  #272
How close is it to completion?
Old May 23, 2020 | 09:12 AM
  #273
You're right about the reduction in bump steer with parallel and equal length drag link and panhard bar. This is important on a linked truck. This is different than a leaf sprung truck where you want to maximize the length of the drag link and simply try to keep it closer to flat to try to reduce bump steer.
The setup in the video is slightly different than yours. His setup appears to limit the tie rod's ability to rotate along its own axis. This will reduce the play your setup will have.
Also, there is an inherent drawback to this design. You're alignment can only be set to a finite number of points. You're toe can only be set in increments equal to the pitch of the threads. Depending on tire size and knuckle lengths this could mean adjusting toe at only increments of 1/4" at a time. Secondly, every single adjustment would require disassembling, rotating, and reassembling the tie rod to the knuckle. Not the end of the world, but not ideal. A tie rod with no brackets welded to it (and both LH and RH threaded ends) can be adjusted to an infinite number of lengths and toe adjustments.
If you're really committed to this design, I'd recommend rotating your tie rod so that the bracket to the drag link is as close as possible to vertical, not canted forward like in your picture. I would try to find a way to prevent the tie rod from rotating along its own axis. And separate from the linkage setup, the bolts holding the Heims to the knuckle are pretty long. I'd see if you could put those in double shear or just bring the Heims up closer to the knuckle and shorten those bolts. You don't want the bolts connecting the Heims to the knuckle to bend or break.
Old Jun 5, 2020 | 07:13 AM
  #274
stanz's Avatar
Thanks for all of the input — it’s valid. After 2 more weeks back at that fab shop, I got a call that it was done and that other than some slip in the steering shaft, it drives much better.
I don’t agree that there is much slop in the steering shaft and I didn’t see any improvement in drivability - it’s scary as hell above 30 mph - bump steer, dead spot in steering, twitchy, rear feels like it’s sliding in the turns.
its going to a new fab shop in two weeks. Hoping to get some answers then.
in the meantime, here are some pics of the new color going on while it’s out of commission
Old Jun 13, 2020 | 02:18 PM
  #275
stanz's Avatar
Next up: a pillar quad switch pod... took two Daystar pods for a Jeep and molded them together to get the right depth, angle and contour
Old Jun 13, 2020 | 03:24 PM
  #276
stanz's Avatar
Old Aug 8, 2020 | 10:24 AM
  #277
stanz's Avatar
Finally finishing up my doors. Two new regulators and tons of wiring for the FJ power mirrors, power lock/unlock switch add to the pass side, mirror defrost and speakers
Old Aug 25, 2020 | 01:13 PM
  #278
stanz's Avatar
Pa
Paint job progress
Old Sep 2, 2020 | 09:37 PM
  #279
Sweet. Are you painting it with a paint gun?
Old Sep 26, 2020 | 11:01 PM
  #280
stanz's Avatar
no. Just rattle can Steel-It paint
