Speedcrazy's 94 Pickup Evolution
Old Aug 6, 2013 | 07:53 AM
  #121
SpeedCrazy's Avatar
Originally Posted by bone collector
I would choose option 1 or 2. Maybe even return the truck to stock height and run 33s. I have a few friends that are doing this and looks awesome and wheels great. Realize that you are going to need new knuckles etc when switching out lifts. I'm sure you could sell the lift and tires on craigslist without much trouble.
When it comes to gas mileage, don't forget to calculate for the difference in your tire size. The odometer still thinks you are running stock tires. Your gas mileage might be better than you think.
That being said.... what gears are you going to run? They need to match your tire size. I know there are people running 4.30 gears with 35 to get better gas mileage. The trade off is a slower take off... just stuff to think about. Good luck
Yes, from a purely cosmetic standpoint i lean towards #1, from a "probably the best" standpoint i lean towards #2. My only problem with #2 is the re-gearing, that is not something i can do and finding a set of gears could be expensive.
Tire size does not play into my current calculations as my odometer still does not work so i will be calculating mpg based on a miles between set points using google.(figure distance between gas station and a set point and back and fill up at both ends to discover fuel used)
I currently run 5.29 gears, if i went to 33"s i would probably try to find some 4.88s. Not 100% sure on that though.
Originally Posted by bbrideau
option 1 or 2 for sure, leaning more towards option 2. the difference in mpg between 35's and 33's is more than you would think.
As i said above i kinda lean to #2 as well as the ideal, but #1 may be less hassle. It may come down to figuring which will be more expensive and then figuring how much that extra investment will save me. I know i'm not going to get amazing mileage, if i wanted that i wouldn't have bought a truck(well, at least not a lifted one). And well dangit i kinda like having a big truck, i just need to find the balance.
Mean time, while i decide, can y'all help me come up with a list of what i will need to lower the truck, whether that be 2 inches or all the way.
I know i will need:
Springs
Shocks
U-bolts
Knuckles
Tie Rods
Ball Joints
Idler Arms
.... you get the idea, i have no clue what i'm up too
Whichever height i end up going for i want to do it right, replace anything i need to and beef anything i ought.
EDIT: Updating the list with suggestions from following posts so i have the list in one place for reference.
Old Aug 6, 2013 | 08:19 AM
  #122
SpeedCrazy's Avatar
For reference here is how it sits right now:
Old Aug 6, 2013 | 08:28 AM
  #123
bone collector's Avatar
Shocks knuckles springs. Unless your A arms are damaged you will not net new ones. Might as well look at new tie rods ball joints idler arms.... etc
Old Aug 6, 2013 | 08:31 AM
  #124
SpeedCrazy's Avatar
Thanks. Updating the list in my post.
Btw, its that etc that gets me, i have never messed with suspension etc does not suggest anything to me. So if you wouldn't mind expanding your list i would be grateful.
Old Aug 6, 2013 | 09:51 AM
  #125
Look up a 4 inch lift kit from a reputable company. Look at all the parts involved and realize that is what you are replacing. You now want the stock replacements for those parts.
As far as a front end goes look up a front end kit from Moog or other company and see what is all involved. I'm not saying that your front end is trashed or anything. I was merely suggesting that you will be messing with those parts anyway, so it would be a good time to replace it since you are already there. 4 wheel drive Toyota owner magazine just did a big how to article on replacing the front end our trucks. It was very informative
Old Aug 6, 2013 | 10:08 AM
  #126
SpeedCrazy's Avatar
Good idea, i will do that.
I completely agree that now would be the time to replace those parts.
I will have a look for that article.
Old Aug 6, 2013 | 04:02 PM
  #127
SpeedCrazy's Avatar
I think what i'm going to do is a combination of one and two. I will drop it to 2" then see how much trimming would be required and at that point decide if it will be 33"s or 35"s.
Can anyone recommend a good front end lift kit and a good quality leaf spring brand or rear lift kit.
I am normally in favor of buying individual parts to be picky but speed is of the essence now so i want to buy kits.
Old Aug 6, 2013 | 04:30 PM
  #128
got a friend close that wants a lift kit and has the same truck??? could do a swap, stock for lift....
I think most 2 inch lifts are going to be ball joint spacers versus a knuckle lift. if that is true you will still have switch the knuckle. you will have to do some research.
Old Aug 6, 2013 | 05:04 PM
  #129
SpeedCrazy's Avatar
Ah... i did not realize there was a difference. That might complicate things.
Old Aug 6, 2013 | 06:02 PM
  #130
SpeedCrazy's Avatar
Okay here is a picture of a basic lift kit similar to what i assume must be on my truck, 4" front 3.5" back.
I see and can name:
Shocks.
U-bolts
Blocks
Brake drop-down plate
Then i recognize those big brackets in the middle(they sit below the dif correct? and do the actual lifting on the front, right?)
The other stuff i have no real clue. In the morning i will take some pics of what is currently on my truck and play some matching.
Old Aug 7, 2013 | 03:25 AM
  #131
I see and can name:
Shocks.
U-bolts
Blocks
The triangular pieces at the top are your knuckles. Yes the big brackets in the middle are for the diff.
Old Aug 7, 2013 | 06:24 AM
  #132
SpeedCrazy's Avatar
Okay. So i need to find a stock set of those? I assume that would be as simple as finding a rebuild set.
Old Aug 7, 2013 | 07:19 AM
  #133
SpeedCrazy's Avatar
Had an idea. I'm searching cl for a parts truck that i could pull the stock suspension off of. Would have the advantage that i would know where each piece came from.
Old Aug 7, 2013 | 01:57 PM
  #134
SpeedCrazy's Avatar
Or.... i could cheat and trade it for a stock height truck in a little better shape... that could save time and money. Then i could put that money in other mods rather than suspension.... I hate cl =p
Old Aug 7, 2013 | 04:20 PM
  #135
SpeedCrazy's Avatar
Score, maybe.(i doubt it but hey, a chance is a chance)
http://greenville.craigslist.org/ctd/3898850874.html
I did a spur of the moment txt and ask if he would trade, and he is asking questions and considering... Shoot yes!
94, 4x4, 22RE, 5spd
Told him he could keep his sound system and his pristine bench and he likes the look of my truck. Win win, he wants a lifted truck, i want a stock one.
Old Aug 7, 2013 | 05:32 PM
  #136
looks good!! best of luck
Old Aug 7, 2013 | 05:38 PM
  #137
SpeedCrazy's Avatar
Yeah... i kinda feel bad for quitting on this one but i think this way i would come out ahead.
Originally Posted by Email from owner
Its a 1994 toyota pickup DLX cab when i bought it it had 187k on it it now has 196k the guy i got it from said it had brand new shocks etc the body is 95% perfect the only problem behind the rear bumber theres alittle dint from the previous owner but besides that its perfect i wash and wax it every 2 weeks. Under the bed liner its alittle dirty but a simply power wash should clean it up. A couple days ago i replaced the timing chain so it has a brand new chain and guides and gaskets that will last for years it costed me 847$ beside that everything is perfect no leaks, no rust on the frame, nothing. Its never seen mud in its life and it never will as long as its with me. No after market parts except visors and bug deflector and 15 inch pacer razer blade rims.
What else should i ask. I know its a 22re, 5spd. Extra-cab, DLX.
Old Aug 7, 2013 | 05:42 PM
  #138
is the title clean?? and when can you pick it up??
Old Aug 7, 2013 | 06:05 PM
  #139
SpeedCrazy's Avatar
Yeah, can't forget those. He talks like he wants it but is hesitating, so we shall see. Unfortunately it would be Monday at the earliest before i could meet him as i am out of town so he will have plenty of time to hem and haw.
I was thinking given the condition of his i would price out a few of the smaller fixes i never got around to and add some cash to the trade, but only if he says no to an as-is trade.
Old Aug 12, 2013 | 04:44 PM
  #140
SpeedCrazy's Avatar
I actually think he is going to bite. He has been asking questions all weekend and is trying to arrange to meet me Wednesday so we can see and test drive each others vehicles. So far i haven't had to add money.
I like everything i am hearing about his, but those rims will definitely have to go ASAP.
