My little gem...86' 4runner
Old Sep 3, 2014 | 05:56 PM
  #41
rumdumb's Avatar
Spoke to early...haha
The TPS was quite the learning experience as me an electronics don't go together at all! I followed 4crawlers instructions to a tee. Still had some small issues? Went back to double check and my throttle stop had a gap so all my gaps and testing where useless. Fixed that and went back through and she purred like a kitten...for a few miles then as before my rockers seem to fall out of adjustment. Was recommended to do 6 on the intake and 8 on the exhaust (engine cold). I'm hoping this solves my issue, but if not the only thing left to change is my cam.
Side note: told to change to a 4 wire denso o2 plug due to LC header.
Love this site!
Old Sep 15, 2014 | 05:21 AM
  #42
rumdumb's Avatar
4 wire O2 sensor
Alright gents I have a question. I suck at electrical. I know what each of the the colors means on the 4 wire plug but my question is where did you run your hook ups to? Would kinda like everything to run together so as not to have a bunch of single wires running all over the place. Pics are always a plus.
Thanks in advanced!
Old Oct 29, 2014 | 11:29 AM
  #43
rumdumb's Avatar
Sorry guys haven't been on in a while do to work and other stuff. So I have run into a few issues.
1. Truck will not go in gear at all. It started where I had to wiggle it to get it into 1st gear. Now it sounds as if the clutch was not engaging all the way. When I try to engage any gear you can hear the revs start to creep down. I don't see any leaks any where. Do you think its bypassing internally? Forgot to mention the arm is moving in and out just not sure its moving in and out all the way? Upon further research I think it might be the shifter bushings?
2. This one involves my brake booster. So the truck is idling at 700 rpms. Rev the engine or bump the throttle and it hangs at 1000 rpms. Now I step on the brake pedal and the rpms drop back to 700 and then start to bounce between 400-700 rpms??? Brake pedal firms up then sinks down after the revs drop? Gonna check my idle speed screw tomorrow.
3. Another brake issue just different area. I installed all new pads and rotors and on the front right I here squealing?!?! Took everything apart and cant see anything that would cause it?
Before all this I was tooling around with little to no issues. Please offer any advice that you can! I'm all ears
Old Oct 30, 2014 | 07:02 AM
  #44
rumdumb's Avatar
Shifter bushing
Here are some pics. What do you guys think. Clutch master looks new and so does the slave. Gonna order one from Marlin Crawler regardless.
Thanks
Old Oct 30, 2014 | 07:09 AM
  #45
rumdumb's Avatar
Couple more...it's only letting me do one pic per post
Old Oct 30, 2014 | 10:41 AM
  #46
rumdumb's Avatar
Update...
I think I got the idle speed screw worked out. Well have to wait to be 100% sure do to the shifter bushing. And on a side note I finally got rid of that dang random miss!!
Through some research I found a little trick where you cut a piece of a coke can or what ever can you have and slide it on the aft section of the intake where the egr connects. BOOM...she purrs like a kitten!!!! What a relief...
Old Nov 10, 2014 | 06:25 AM
  #47
rumdumb's Avatar
Update...
Well I installed the MC shifter bushing and it didnt fix the problem. So I decided to adjust my clutch pedal and it seem to let me shift gears except onocasion. Meaning it seems like I have to force it in or i push pass a notch and then it goes in? Does that make any sense? Let me do a little back story that might help. A few months ago my clutch cancel switch stopped working. I didn't pay much attention as I thought it was the little rubber peice fell out and I was fine using my clutch cancel switch on my dash. I checked for that grommet yesterday and it was still there. I pressed the clutch down and it would not hit the switch? I have heard of broken brackets but I didnt see anything or movement. Then the hard to get in gear started. Now all the gears where difficult to get into except reverse wich would just grind. Things I have checked:
1. Fuild leak - None
2. Still need to check fluid in tranny.
3. Adjusted pedal and clutch cancel button under dash.
What could be the issue?
Synchroes?
Worn out forks?
It does not pop out of gear or grind except when I was trying to put it in reverse (before adjusted).
Old Nov 10, 2014 | 08:28 AM
  #48
coryc85's Avatar
You're in Boca, right? We've talked on MUD a couple times, didn't realize you were over here too. I'm in Coral Springs, so not too far down the road.
Great progress! I'm going to do that soda can trick...I have pulled all the vacuum lines from my EGR, but I haven't officially blocked it off with anything.
I really don't know what to say about your clutch issue. I know there was a similar issue long ago on here somewhere and somebody mentioned that it could be that soft line that goes from the frame to the clutch slave cylinder. That line can flex from age and basicially ruins the travel of your little slave piston. It's only a few dollars, so that could be something to look at.
Good luck.
Old Nov 11, 2014 | 01:16 PM
  #49
rumdumb's Avatar
Yeah I'm in Boca. Haven't been real active on either board do to working so much! The can trick worked awesome and I highly recommend it. As far as my transmission goes I'm just gonna keep working on it till I get it right...well that actually goes for the entire truck. Haha
Old Nov 20, 2014 | 04:54 AM
  #50
Terrys87's Avatar
The clutch fork doesn't move much at all. I have gotten wrong parts at the local part store. Might try adjust the nut on the clutch Master Cylinder. I forget which way I had to adjust the nut, but what you are trying to do is cause the push rod to be pushed in further. I have heard of the bracket having a crack in it and not letting it push the rod all the way in.
Is the plug to the switch making good contact. It is located right up at the fire wall just before it goes out the into the inner fender. I currently have a jumper wire in my 85 as I don't have a Cancel Switch at this time. Just keeps me from having to get into the cab each time I want to start it without having to hold the clutch in. Just a piece of wire jumping the contacts to the connector on the harness.
Might check the switch or the plug on our Clutch Cancel Switch.
Old Nov 20, 2014 | 09:08 AM
  #51
rumdumb's Avatar
Thanks Terry
Well here is where I'm at and maybe you guys can give me some hints.
I decided to readjust the pedal height, engagement point, and also adjusted the clutch sensor. Pushed in clutch turned key and it fired up with out having to use clutch cancel button. Then I try to shift through gears. No problem at all. Drive around a little bit and no real issues except on occasion I would have to wiggle shifter to get in first gear. Now fast forward to today (truck has been sitting idle all week). After reading Terry's post I went outside fired it up and went to put in gear to take it to work. Well it won't go into gear at all even if I wiggle it. It will grind going into reverse. What could it be? I didn't see any cracks in the clutch pedal assymbly. I guess new master and slave are in order to eliminate them. I'm stumped!
Old Dec 3, 2014 | 03:44 PM
  #52
Terrys87's Avatar
I just fought that battle today with my brothers truck. It started out with a leaky slave cylinder the other day. Today we had to change out the master cylinder. I am wondering if the new seals increased pressure to the master cylinder and caused it to fail two days later. Hopefully we got it fixed for good. Might give that a try. The master cylinder seemed to be operating fine but there is only the master and slave cylinder and the lines involved.
Old Dec 4, 2014 | 07:53 AM
  #53
dart_man440's Avatar
might be a dumb question but, is your slave cylinder fastened securely to the tranny? it sounds like the clutch is not engaging correctly,
Synchroes?
Worn out forks?
Old Jan 20, 2015 | 04:25 AM
  #54
rumdumb's Avatar
Well I installed new calipers and replaced the clutch master/slave. Got the brakes bleed with no issues. The clutch master/slave is another story! Long story short I gave up. I run the 4Runner every weekend for about 10-15 mins. After taking a break from working on the clutch I decided to fire it up for a few minutes. The engine started missing! That's where I lost it. I've owened this truck for a year and have put 260 miles on it and it has fought me the entire way! I turned it off. Cleaned my tools and called a reputable mechanic and told him to come get it! He picked it up last night. Hope to have it back within a week or two.
Old Jan 20, 2015 | 11:18 AM
  #55
Terrys87's Avatar
Sometimes it is worth having someone else to look at a problem. Been a little frustrated myself at times.
Old May 4, 2015 | 08:07 AM
  #56
rumdumb's Avatar
For Sale
My 4Runner does not have the tow capacity to tow my new boat and trailer. So I decided to get a new Trail Team 4Runner. That means the 4Runner and my Lexus are for sale. A proper for sale thread will be posted in a couple days.
Thanks
Attached Thumbnails My little gem...86' 4runner-9e1f9eed-77c4-4d71-837b-19e2de3a22e2_zps6yw8gspl.jpg   My little gem...86' 4runner-d86f763a-c0cd-49af-92dc-fd518e8c64e3_zps2wpbdt3u.jpg
Old May 29, 2015 | 11:59 AM
  #57
rumdumb's Avatar
4Runner is sold.
Old Sep 4, 2015 | 04:36 AM
  #58
rumdumb's Avatar
Haven't posted in a good while but I thought I would share my new 4Runner with you guys.
Old Sep 4, 2015 | 12:13 PM
  #59
Terrys87's Avatar
Dont like seeing the old runner go but understand why. New runner looks great and should have plenty of power.
Old Sep 5, 2015 | 05:28 AM
  #60
rumdumb's Avatar
Don't be...
I sold the 4Runner to a good buddy so I'll show his progress. He's already redone the interior and repaired our corrected the wiring. Believe me it went to a very good home.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
