Melrose 4runner 1986 restomod summer beach truck
Old Oct 16, 2018 | 08:58 AM
  #401
Melrose 4r's Avatar
5 Year Member
Originally Posted by wallytoo
different seat-back latch than on my two runners. i suppose there may not have been a sole supplier to all dealers.
I wonder about these seats. There seems to be no provision for head rests. Is that common?
Old Oct 16, 2018 | 01:52 PM
  #402
wallytoo's Avatar
not common, but i have a runner that has rear seats lacking provision for head rests, too.
Old Oct 17, 2018 | 12:13 AM
  #403
SomedayJ's Avatar
It's tough to answer because I had to learn some things as I went along. This time I had to begin with "confidence builders" like the hood and fenders. I had to learn how to tell when I had done
sufficient prep work and could move on to the next step in the process. Next time, I will do all the body work before doing any primer or paint work. But still, each vehicle is different, and each panel
on a vehicle may require different repairs.
What I would recommend for a beginner:
Use quality materials for filler, sandpaper, masking tape, masking paper, paint and primer.
Get a decently rated spray gun - does not have to be expensive <$200, but read the reviews.
Have somebody you can ask lots of questions. Paying somebody to consult is worth it.
If you remove the doors, DO NOT remove the seam sealer around the hinges. Assuming your doors shut nicely now, these are the witness marks you need to put them back on correctly.
Label all bags of screws, trim, etc better than you would think you need to. It will save you time.
Take lots of photos in disassembly...it cannot hurt!
Use a basecoat/clearcoat process. It may cost more but is much more forgiving than a single stage paint process. Start with a simple respray in the same color- much less work.
Spray cans- etching primer, color and clear, = all applicable where needed. (again, buy quality)
My paint job is not perfect, but not finished yet either, I need to touch up rockers below the doors where the paint is thin, due in part to the bright sunlight conditions I was spraying in(snowblindness) and I need to wetsand and buff the clear for a nicer finish.
Thanks a lot! The body work and paint job looks perfect in the pics, I've learnt a lot with this thread.
Old Oct 17, 2018 | 04:02 AM
  #404
Melrose 4r's Avatar
5 Year Member
Pulled the rear bumper mounts off completely, drove it to work and went for state inspection yesterday. It passed with no trouble.
up next, will be wiring the amps and mounting the bumper so that we’ll be able to mount bikes for the weekend in NH. It’s hard to get out in the garage after a cold, long, dark commute home from the office but I have Friday off and we won’t drive to NH until evening so I’ll have time during the day to finish preparing for the road trip.
Old Oct 17, 2018 | 11:34 AM
  #405
Melrose 4r's Avatar
5 Year Member
Drove in to the office today and along the way, decided to try to get an alignment done today. Town Faire Tire got me in during lunch break and here's the results. The "Before" numbers were my eyeball alignment. Much more caster now which means better highway stability. It drove great back to the office, can't wait for the evening commute and our road trip to NH this weekend. Looking at the rear toe numbers it appears my rear axle is skewed a little, probably due to the leaf spring replacement performed by a previous owner. Oh well, another future project.
Old Oct 19, 2018 | 05:05 PM
  #406
Melrose 4r's Avatar
5 Year Member
Took the day off work to mount up the new rear bumper and begin the road trip.
i had tried the bumper last weekend and decided I could use the original 1986 step bumper mounts with some modification.
so I cut 2.5” out of each one and welded them back together.
this is a crappy job to do alone, fitting the bumper on and off.
i used one of the existing holes in the bumper itself and drilled another hole between the leftmost one in the photo and the end of each mounting bracket.
also wound up mig welding the bumper to the brackets.
These bumpers seem pretty flimsy to me and my end goal was to mount a bike rack with two mountain bikes and hit the road. So I felt it would flex less if I welded it.
After fitting and welding I needed to paint the rusty looking mounts so the plastic drop cloth was a quick and dirty way to mask it.
Here it is Ready for the road.
Now, we’ve travelled up the road and made it to our hotel in NH. it was about 2 hours on the highway total. stop and go until we hit the NH line then highway speeds from there.
as soon as we pulled into the hotel a guy commented on the “Nice truck!”
At one point on the highway I saw a red light flash on the dashboard very quickly. So quickly I didn’t know which it was. Then after thinking about it I pulled on the e-brake a little and that was the one that had lit up. But after idling with the e-brake on while unloading the bags at the hotel front door, I went to park it and I noticed the “charge” light was now on too. I parked it and came inside. This is a long way of saying I hope my alternator is not about to die and leave us stranded here, if I had my shop manual with me i’d Look up dash board indicator circuits to see if the two have something in common like ground.
Old Oct 19, 2018 | 10:16 PM
  #407
SomedayJ's Avatar
Nice truck!
The body and paint job look amazing.
First time I see a white soft top.
The bumper looks good. If I install that one, I'll put the license plate in the step, and I'd modify the tail gate, truck flat style, with the big 'TOYOTA' decal, I love the truck tailgate.
Old Oct 21, 2018 | 06:35 PM
  #408
Melrose 4r's Avatar
5 Year Member
We made it back from NH without so much as a flicker from the CHARGE light but I promised the truck I’d look into it and have ordered some new alternator brushes for it. In my family’s Toyota history alternator brushes didn’t last beyond 125k miles and this one might have 182k on it, I don’t know for sure if it’s the original alternator or not.
Really glad I got the alignment before this road trip! It’s a bit tiring to drive at 70+ mph in traffic but the alignment sure has helped.
Got the speakers remounted in the doors today and now working on wiring back to the amps. I want it to look very clean. Also thinking about putting a dark blue double pinstripe down the sides of the truck. Still have more detail stuff like windshield trim and wheelwell trim to work on. And also the Toyota 4Runner badges for the B pillars need to be restored. Lots of small indoor projects for the winter!
Old Oct 21, 2018 | 06:43 PM
  #409
Melrose 4r's Avatar
5 Year Member
Originally Posted by SomedayJ
Nice truck!
that bumper looks a lot sturdier than my chrome one.
i thought the off-white soft top would look strange with the bright white paint but I like the contrast.
I’d really like to see it with a denim blue top, though. Maybe I’ll get some quotes on it.
  #410
old87yota's Avatar
The 4Runner is looking good!
I am glad your trip ended well!
Old Oct 23, 2018 | 06:48 AM
  #411
magnet18's Avatar
Truck is looking awesome, your bodywork skills have definitely payed off!
now it just needs some graphics!
Old Oct 23, 2018 | 08:18 AM
  #412
Melrose 4r's Avatar
5 Year Member
Thanks! Still on the fence about graphics.
James Dean hasn't answered my emails so that is helping me decide.
Also, most people I ask say it looks good without. I think the 1986 factory graphics would help raise the value but the counter argument made by a friend is "put them on before you sell it."
So the only decision I've made is to add some blue pin stripes after I wet sand and buff it...whenever I get around to that!
Old Oct 23, 2018 | 08:38 AM
  #413
magnet18's Avatar
I think these trucks look waayy better with the graphics, 86 being my favorite, but that's just my opinion
They do still look great without, no doubt
Curious how it goes with the james dean graphics. I'm considering getting some big rolls of paper and tracing mine to use as a template when i get around to painting
Old Oct 23, 2018 | 11:49 AM
  #414
Melrose 4r's Avatar
5 Year Member
I don't think its going anywhere with him. I'm not going to send $300 to a guy that doesn't answer emails.
Tracing your own is the way to go. My friend traced the graphics that were on mine and created a vector file. Then the sign shops can reproduce them, they way i understand it. Perhaps the shop would prefer to do the tracing or maybe they have some other method.
My problem is I can't find a photo of an 86 with blue graphics anywhere. Maybe it was shown in the original sales brochure but I don't know. Maybe blue doesn't exist.
Old Oct 23, 2018 | 11:57 AM
  #415
magnet18's Avatar
Is there any way you can post or send me that vector file?
My father in law has done a lot of work with a guy that makes vinyl decals for cars, he does very good work, I'd like to get a quote from him. (See the signs on the wall in my avatar pic)
I also have a 2'*4' CNC/laser machine that can probably cut a vinyl decal, but I'd have to sink a lot of time into fiddling
Old Oct 23, 2018 | 11:59 AM
  #416
Melrose 4r's Avatar
5 Year Member
Sure I can send you the files. But remember, mine don't look like your graphics.
PM your email address
Old Oct 23, 2018 | 12:00 PM
  #417
magnet18's Avatar
Forgot avatar resolution suck, it's a very nice hood sized mountain dew logo
He also recreated the mach 1 decals on my wifes mustang just from a picture of them
Sending pm
Old Oct 23, 2018 | 12:06 PM
  #418
SomedayJ's Avatar
Do you know how to create a vector file from the traced graphics?
Old Oct 23, 2018 | 12:08 PM
  #419
magnet18's Avatar
PM sent
i forgot yours had custom/dealer installed paint instead of the factory decals
Looks like some pieces might be too long to squeeze on my machine, but I'll definitely get estimates for yours and my decals both
Old Oct 23, 2018 | 12:35 PM
  #420
Melrose 4r's Avatar
5 Year Member
I sure don't, but I guess my friend does.
