Lybriums 92XtraV6
Old Mar 19, 2019 | 08:00 PM
  #81
old87yota's Avatar
Sweet!
Old Mar 22, 2019 | 12:29 PM
  #82
Lybrium's Avatar
Here we go!
Cross your fingers for me folks, we're going to hear this thing rumble this weekend!
Old Mar 24, 2019 | 05:32 PM
  #83
Lybrium's Avatar
It is alive
So this happened! The Engine sounds amazing, smooth and steady. I have to adjust the throttle cable as it's too tight not allowing the idle speed to go down, sits at about 1500. and power steering isn't working right now, but whatever! This thing is f***ing running!!!!!!
Old Mar 24, 2019 | 06:49 PM
  #84
old87yota's Avatar
Nice!
Congratulations!
Now we need a video of the engine running!
Old Mar 25, 2019 | 06:17 AM
  #85
Lybrium's Avatar
Originally Posted by old87yota
Nice!
Congratulations!
certainly! How do you embed a YouTube video?? Haha
Old Mar 26, 2019 | 02:16 PM
  #86
old87yota's Avatar
If you have your video uploaded to YouTube, you just need to post a link to your video using the link button. The forum will automatically turn that link into a video once you post.
Old Apr 9, 2019 | 08:16 PM
  #87
Lybrium's Avatar
Running
Alright! Sorry this took me so long, busy busy, yaddah yaddah...check it out!!!
Everything is going well, there is the high idle, but i'm not going to start chasing that too far until I actually have an exhaust system and sensors on it, power steering is good, and the only codes it has thrown so far are for the O2 sensors not being plugged in, Waahoo!
I have been tying up loose ends, sand blasted, painted and put new hoses and clamps on the filler neck, (it was super rusty but managed to save it) , cleaned up the seat belts as they were getting a little moldy, bleached them and de-rusted the hardware + painted. This weekend I am prepping to paint. The Cab will come first, then doors, hood, fenders and finally box.
Ended up having to put the stock trans shifter back in, but I'm not going to go into detail about that before I chat with Marlin Crawler.
Overall i'm super thrilled, this thing is actually starting to come together.
more to come!
Old Apr 11, 2019 | 08:00 AM
  #88
gyates93's Avatar
Great thread! Us east coasters assume BC is a rust-free paradise - obviously we are not correct! Is there any particular reason you went with rebuilding the IFS rather than a Solid Axle conversion since you had the entire body and frame apart? What's the plan for tires/gears/locker?
Old Apr 11, 2019 | 08:39 PM
  #89
old87yota's Avatar
Yay!
It sounds like things are going well!
The engine does sound funny without the exhaust, but it sounds nice and smooth!
Old Apr 15, 2019 | 06:01 AM
  #90
Lybrium's Avatar
Depends where you are in bc, in the Okanagan it's an actual desert so rust is not a big issue, here on the north coast it's pretty bad though.
In regards to the IFS vs SAS, it comes down to what we do with the truck, a combination of daily driving, logging roads, highway, and some light trails. The majority of the recreational use my rig gets used for is on logging roads, some active some deactivated, all in relatively good condition with minor obstacles to get over, mainly to get to forest rec sites (free remote campsites that the ministry of forests up-keeps) and hiking and biking tail heads.
This stuff is basically all IFS's bread and butter.
A rear locker isn't off the table but I'm going to run without for a couple years and see if i actually would use one first.
In regards to gearing and tires, when i had the 3.0 i ran 31's and the ratio was a good match, but I wouldn't have wanted to go any bigger. with the 3.4 I'll continue with the 31s for now, as i know I'll have lots of power, with the option of moving up to 33's and doing regear/locker later.
Old Apr 21, 2019 | 09:03 PM
  #91
Lybrium's Avatar
In preparation for painting the cab i found some more rust, ended up pulling the windshield off to dig it out, kinda sucked at the time but I'm glad it happened, things were getting pretty bad under there.
So I've been grinding away at this pinch weld with some drill attachments, taking a long time but it's looking pretty good, only one spot so far where the rusty actually ate a hole through the outside layer.
Any tips for surface preparation before epoxy primer? There's quite a bit of pitting.
Onwards and forwards!
Old Apr 22, 2019 | 04:12 AM
  #92
gyates93's Avatar
I've used rust converter before epoxy primer - you can try to smooth it out in there as best you can with body fill as well but be careful not to go overboard.
Old Apr 23, 2019 | 09:31 AM
  #93
old87yota's Avatar
It is better that you decided to take the windshield out and deal with the rust now than to find a water leak a few months later!
Old Apr 23, 2019 | 09:33 AM
  #94
gyates93's Avatar
Not to mention that the developing rust will cause the window to crack!
Old Apr 24, 2019 | 05:56 AM
  #95
Lybrium's Avatar
My thoughts exactly, the windshield pinch weld is a pretty crucial part of the cab, no compromise!
Old Apr 30, 2019 | 05:46 AM
  #96
Lybrium's Avatar
It took quite a few discs but i managed to get it cleaned up pretty good.
Then put two coats of epoxy primer on.
All ready for glass, nearly ready for spraying the cab.
Old Apr 30, 2019 | 06:37 AM
  #97
gyates93's Avatar
Are you going to paint the cab before the glass goes back in?
Old Apr 30, 2019 | 11:33 AM
  #98
Lybrium's Avatar
Glass first, that way i have a clear line to mask against and bring the spray up to.
Old May 12, 2019 | 10:14 PM
  #99
Lybrium's Avatar
Bunches of stuff
Alrighty, lots to report since the last update, i found more rot, learned how to weld, put the new windshield in, and sprayed the cab, tailgate and one fender.
Let's start at the beginning, rust.
This actually came as quite a surprise, i was just doing some preliminary surface prep on the bottom edge, saw a couple small bubbles, hit it with the wire brush and two big holes appear.
A neighbor had a welder he was willing to lend, but was too busy to actually weld for me, so it was high time to learn.
Behold my first ever weld
Hah! Ugly for sure but it's solid. Which got me thinking about my doors, sure enough the 'minor surface rust' i remember is actually through and through rot there as well...back to the welder.
It's amazing what you can do with a welder, some sheet steel, a grinder and some hammering, I'm hooked.
On to painting, wait. Back up, surface prep. Alll the surface prep.
I wasn't sure exactly how far one gallon would go so i wanted to have a couple over flow pieces prepped to use up any extra. Tail gate shell and rh fender got dibs.
On to spraying, wait, back up....cutting in.
The spraying went pretty good, except part way through doing the second coat the trigger pin flew out of the gun and shot across the shed, I momentarily panicked, then by some fluke found it on the ground within seconds, it's a brass pin about the size of a toothpick, anyway! Continued.
ta-da.
More to come!
Old May 26, 2019 | 09:22 PM
  #100
Lybrium's Avatar
Nearly there, nearly there!
Howdy, it's been a busy couple weekends since the last update.
Spraying the body is officially complete! Plus more.
Let's go back one week...
Looked pretty comical to have most of the truck strung up from the forest, like some sort of vehicular Christmas ornaments.
Had mocked up the hood scoop and cut the hole the night before.
Spray!
Managed to get everything painted and put away before the rains started in the week.
During the week i worked on a grill for the hood scoop.
Got some expanded metal from work, ground it down to shape, primed and painted it, jb welded it to the scoop.
Finished pictures of that coming up.
Fast forward to this weekend, we started by prepping the box and remaining bits.
Spray!!!
Really happy with how the hood turned out
Then we moved on the installing the replacement carpet, if you have a cruddy old stock carpet I would certainly recommend this product, good quality molds and materials.
And that's a wrap. Going to be a busy week again in hopes to have it ready to go to the exhaust shop on the 11th, see ya soon!
