irab88's 1993 PickUp Build-Up Thread
Old Nov 25, 2010 | 07:59 PM
  #141
space-junk's Avatar
geez... at least drive through a mud puddle so the Jeep owners wont see that your replaced a broken part on the yota!
No shiny parts allowed...
Old Nov 26, 2010 | 01:34 PM
  #142
irab88's Avatar
hey- it wasn't broken, just clogged . the new one works soooo much better. i'm getting better mileage and acceleration. wooo
yeah, i do need to find some dirt to drive over. i found out that gw park has a bunch of trails, and is only 1.5 hours away. hafta go out there sometime
oh, and here's the "final" design for the rear platform. weighing in at a light 63 lbs!
Old Nov 26, 2010 | 08:16 PM
  #143
ChefYota4x4's Avatar
WOOT, WOOT, WOOT! hahaha, an extra woot for the plans! lol.
Although...... CAT'S not welded in?????????? EEEEEEEEEEEEEEk! hehehe.
Old Nov 26, 2010 | 08:18 PM
  #144
Uh oh..........I better get out to the garage with a file and some hammers.....hehehe.
Old Nov 27, 2010 | 02:42 AM
  #145
norcal93's Avatar
Where did the exhaust flanges come from, i've only found them with the tube attached to them. Did they bolt right up to the toyota flange? Thanks.
Old Nov 27, 2010 | 05:38 PM
  #146
irab88's Avatar
thank you mark!
and the original cat was bolted in, too
yup. here's the link. they are a little larger, but the pipe diameter is the same and it has slots for easy adjustment
oh, and that tig weld ain't mine. a friend at school works at a performance racing euro car shop. his handy-work. he accidentally made it 6.5 inches, so he cut and re-welded it. still a pro job. i'll post pics of my welds (not nearly as nice, but still plenty strong) when i'm doing my platform
Old Nov 28, 2010 | 01:23 PM
  #147
Z's Confederate Toy's Avatar
Coming along nicely Ian! The makeshift tranny fluid pump is ingenious! The final design on the platform looks killer, can't wait to see it all done
Old Nov 29, 2010 | 10:17 AM
  #148
Originally Posted by irab88
thank you mark!
Hey Ian, I only mention that with a chill because EVERYONE in CA, at least, knows that TWEEKERS LOVE CAT's that are only bolted in..... it means they don't have to cut them out and make tons of noise! lol.
Even my exhaust shop said, .... "Dude, you're not using this flange, are ya? We'll weld it in with the rest for nothing extra.....don't want to give the tweekers any incentive to get it easier!" hahaha.
Old Nov 29, 2010 | 10:29 AM
  #149
irab88's Avatar
hmm... good point...
i'll think about that, thanks for the heads-up
Old Nov 29, 2010 | 10:36 AM
  #150
Swimmerboy2112's Avatar
Looks good but i wanna see MORE!
Old Nov 29, 2010 | 08:18 PM
  #151
irab88's Avatar
not really much more to see. the holidays get busy really fast for us, so i won't be doing a whole bunch. i might take a trip out to washington forest in search of good wheeling places, but that's still a "might"
Old Dec 1, 2010 | 08:34 PM
  #152
irab88's Avatar
hmmm... is this a problem?
http://www.flickr.com/photos/ianrab/5225175859/
after 45 mins of ~55 mph with the occasional stop light, the needle barely moved
nothing else is wrong, no noises/smells/vibrations or anything. i've gone other times without this happening
Old Dec 2, 2010 | 07:57 AM
  #153
Dbarker42's Avatar
Any bigger tires in the near future? would really set this truck off
Old Dec 2, 2010 | 07:59 AM
  #154
toyospearo's Avatar
looks like your temp sensor went out. There is no way your motor didn't heat up. Thats an easy fix. I would replace it.
Old Dec 2, 2010 | 08:26 AM
  #155
irab88's Avatar
i know, but $ome thing$ aren't nece$$ary. this is my daily driver, and i don't really need any 33 bfg at's right now. it already has 235's on it. my next mods will probably be some lights (on the brush guard and a light bar) along with the platform in the bed.
stay tuned!
well, it worked fine this morning. still, i think it's getting to be that time to replace stuff like that. thanks for the info!
and what "fit kit" do you have with your yakima rack? 16?
Old Dec 2, 2010 | 08:35 AM
  #156
toyospearo's Avatar
Not sure what you mean by "fit kit?"
It is the q tower set up with extension and load warrior.
I would pull a temp sensor off a junk yard yota, sodder it in place of your old one and you are good to go. Would be much cheaper than buying one.
Old Dec 2, 2010 | 08:40 AM
  #157
irab88's Avatar
It is the q tower set up with extension and load warrior...
sorry, i meant q-clips. they're the parts that grip the door frame and the pads that press against the roof
...I would pull a temp sensor off a junk yard yota, sodder it in place of your old one and you are good to go. Would be much cheaper than buying one.
sounds easy enough. if i can find a yota in the yards here
Old Dec 2, 2010 | 08:43 AM
  #158
toyospearo's Avatar
q towers is the only description I have for those. Hope that helps.
I think if you go to Yakima's website and type in your rig it will give you info on a set up for it. If I remember correctly that's what I did.
Old Dec 2, 2010 | 08:47 AM
  #159
irab88's Avatar
yeah, on their site it says #16 clips. just wondering since the profiles of the door and rear window are different. thanks
Old Dec 6, 2010 | 08:45 PM
  #160
irab88's Avatar
in the mail came my "my-ride" system. super stoked. i'll post some pics later this week
