irab88's 1993 PickUp Build-Up Thread
Old Nov 21, 2011 | 09:50 AM
  #1061
Outsane's Avatar
I'm a fan of NGK
Old Nov 21, 2011 | 10:10 AM
  #1062
xxxtreme22r's Avatar
NGK plug wires working just fine on our BMW. And that thing don't like NGK plugs.
Old Nov 21, 2011 | 10:12 AM
  #1063
irab88's Avatar
yeah... as far as i'm concerned, denso is roughly the same as ngk.
my only concern after replacing the plugs are the condition of #3 & #4. they looked like #1 & #2 at 175k... hmmm...
edit: here's what they looked like at ~182k
any ideas, anyone?
Old Nov 23, 2011 | 09:44 PM
  #1064
ChefYota4x4's Avatar
Happy Thanksgiving, Ian!
Looks like 1 and 2 are burning hot/pulling rich on one side.... 3 and 4 might be a bit lean? Have you checked the lash since your top end rebuild(+ some) ???? ..........Think you said you had.. Just curious.
Old Nov 24, 2011 | 09:42 AM
  #1065
irab88's Avatar
yeah, i set lash. maybe i should check it again? good call, thanks mark.
happy thanksgiving to you and your family! make it a good one!
Old Nov 24, 2011 | 11:16 AM
  #1066
RBX's Avatar
RBX
Check it hot?
Old Nov 24, 2011 | 12:23 PM
  #1067
john4wd's Avatar
I don't care what kind a box my parts come in as long as I get them and undamaged, a box is a box :}LOL
I love getting brand new or new used parts, I just love to get them :}
< I love putting this on my thread :}LOL
Happy Thanksgiving :}
Old Nov 24, 2011 | 12:58 PM
  #1068
irab88's Avatar
^^ heh, thanks! you too (and you, rb)
Originally Posted by RBX
Check it hot?
yes
hehe, i'll check it sometime later.
Old Nov 29, 2011 | 07:36 AM
  #1069
irab88's Avatar
for my reference
http://www.greenvalleycompressor.com/mm5/merchant.mvc?
http://www.ebay.com/sch/i.html?LH_Pr...4.l1581&_pgn=2
what i realized is that the oasis air compressors are nothing more than a high-torque motor with a york compressor. how about using a 2100 rpm, 4.5 hp winch motor?
http://www.ebay.com/itm/NEW-12V-Winc...item1e689562ab
hmmm... ideas...
Old Nov 29, 2011 | 08:08 AM
  #1070
RBX's Avatar
RBX
Or a starter motor. Duty cycle is critical.
Old Nov 29, 2011 | 08:29 AM
  #1071
irab88's Avatar
from what i've read, winch duty cycle depends heavily on electrical system setup. if i'm drawing 100 amps up to 15 ft away (30 ft round-trip), that puts me at 1/0. it should be easy to add a continuous duty circuit with my bus-bar setup.
as for heat, i'll make sure to add a heat sink with fins and a fan (as that's what the oasis compressors have)
i'm not sure about starter motors, for 2 reasons: 1) seems like they'd have a short duty cycle, and 2) they don't have a standard output shaft. with the winch, it's 3/4" keyed, and mcmaster sells pulleys that'll fit
though, it's just an idea. i'll wait a little while longer 'til i start doing this stuff.
Old Nov 29, 2011 | 08:48 AM
  #1072
RBX's Avatar
RBX
Amp draw is going to be huge with either motor I'm guessing. I think is really cool to make your own oasis.
Old Nov 29, 2011 | 09:10 AM
  #1073
irab88's Avatar
and for way cheaper
i'm looking at parts now, but i think i could get it under $300 for the whole system
Old Nov 29, 2011 | 09:29 AM
  #1074
RBX's Avatar
RBX
What about amp draw? I'm guessing you will need to run the engine whenever you spin-up the compressor for more then a few seconds.
Old Nov 29, 2011 | 09:44 AM
  #1075
irab88's Avatar
yeah, i'll add in an idle-up control like what logan did. just a simple bypass.
Old Nov 29, 2011 | 11:56 AM
  #1076
Black_1985_SR5's Avatar
order now http://www.oconeeoffroad.com/servlet...Onboard/Detail
Old Nov 29, 2011 | 12:08 PM
  #1077
irab88's Avatar
thanks but nah... only 0.97 cfm @ 90psi
york: 4 cfm @ 90 psi, running at 1200 rpm (for about the same cost)
Old Nov 29, 2011 | 12:16 PM
  #1078
ahh see im not even thinking about the a/c compressor oba since i love my ice cold a/c lol. i just came across that last night and thought of it when i saw your post today.
Old Nov 29, 2011 | 12:21 PM
  #1079
irab88's Avatar
york compressor ($25) + winch motor ($100) = oasis compressor ($2,000)
in other words, i'm making my own $2,000 electric compressor
Old Nov 29, 2011 | 12:27 PM
  #1080
I'll be sure to follow this i just read about them and did a bit of searching yeah those suckers are spendy
