irab88's 1993 PickUp Build-Up Thread
Old Mar 2, 2011 | 08:44 AM
  #441
yotarob2005's Avatar
Propane would be sweet Ian, I say do it, and a full write up for me too follow when the time comes.
Old Mar 2, 2011 | 08:52 AM
  #442
xxxtreme22r's Avatar
wire it right meaning use the pressure switch not just wire it up to keyed ignition like most others do.
Summit has em. http://www.summitracing.com/search/D...s/?Ns=Rank|Asc
if oil pressure falls below 7psi it shuts the fuel pump off. Only possible drawback to this is it might take an extra crank or two to start when the oil pressure is @ 0. One way around this is to also wire a rocker switch to bypass the safety switch when starting, but can also be done a different way in where you wire a relay to trigger the fuel pump when key is in start position that bypasses the safety switch as well. Confusing I know but....
Old Mar 2, 2011 | 08:56 AM
  #443
RBX's Avatar
RBX
^^^What Rob said....I'm thinking dual fuel 1UZ!!
Old Mar 2, 2011 | 09:04 AM
  #444
irab88's Avatar
if i do this, i will be sure to document every step. it's looking more and more feasible as i research further
Summit has em. http://www.summitracing.com/search/Department/Air-Fuel-Delivery/Section/Fuel-Pumps-Regulators/Part-Type/Oil-Pressure-Safety-Switches/?Ns=Rank|Asc
actually, that makes perfect sense. does that make me a geek ?
the only other question is where do i put the pressure switch?
let us know how that turns out. the only thing is that the 1uz has way too much electronics to work with propane. the "efi" kit basically strips the 22r-e of all wiring (except ignition and alt) and uses the stock manifold kind of as a carb'd intake
Old Mar 2, 2011 | 09:09 AM
  #445
RBX's Avatar
RBX
What about Natural Gas? I would like to fill up at my house, and there are some NG stations across the country.
Old Mar 2, 2011 | 09:20 AM
  #446
the pressure switch would attach just like any other aftermarket pressure gauge. Wether it be an oil filter adapter ring or some sort of tee fitting on your oil pressure sender and whatnot. Just remember the factory oil pressure hole is not an NPT fitting.
Old Mar 2, 2011 | 09:25 AM
  #447
irab88's Avatar
i don't know about natural gas, but i would assume it would be similar in setup.
aaaaand
i just got off the phone with bill from nashfuel, and was extremely helpful with all my questions. their kit ($699) is bolt-on efi dual-fuel. sweeeeeeeeeeeeet. he's going to get me some pics later, so i'll be sure to post them here
thanks brandon. i'll probably do a "tee" from the sender
Old Mar 2, 2011 | 09:28 AM
  #448
that's pretty cool, much better then converting to 22r and then to pane. Much cheaper too probably. I like the idea it keeps the efi intake.
Old Mar 2, 2011 | 09:40 AM
  #449
irab88's Avatar
yes. it'll save time, money, fuel, and best of all, i might actually be allowed to do it! (the truck is legally my dad's)
Old Mar 2, 2011 | 09:45 AM
  #450
Z's Confederate Toy's Avatar
Natural Gas would be awesome. Its realtivley cheap and pretty easy to come by.
Old Mar 2, 2011 | 09:54 AM
  #451
RBX's Avatar
RBX
stations
http://www.afdc.energy.gov/afdc/locator/stations/#
Old Mar 2, 2011 | 09:57 AM
  #452
irab88's Avatar
i've seen some vehicles that use it (besides buses). it's pretty neat what they can do now-a-days. i haven't looked into natural gas, but i know i can get propane easier than natural gas
the next thing i need to look at is where to mount the tank(s). i was thinking of using one large tank and one or two bbq-style tanks that could be changed out at home depot or something. since my bed is already dented, i wouldn't be opposed to putting an access door towards the front (cab side) and have a slide-out tray. i need to take some measurements, but i think i could pull it off
i also read that lpg is better for turbos...
(not in my near future)
Old Mar 2, 2011 | 10:00 AM
  #453
irab88's Avatar
ha, i looked at a 30-mile radius for ng. nothing too close. everything is on the other side of washington (bleh). there's nothing near school or work.
anyway, i'm off for school. i'll check back later
Old Mar 2, 2011 | 10:02 AM
  #454
RBX's Avatar
RBX
Tanks would be the issue, i am thinking bumper tire carrier, and tanks where spare used to be. You could easily make a drop out canister that would hinge so you don't need to cut up your dad's(haha) bed.
Old Mar 2, 2011 | 11:49 AM
  #455
irab88's Avatar
good idea. forgot about that...
if i do this, i'll probably just have two or three tanks in the bed, nothing permanent until i figure out a design. i still need to find out what pressure fuel to run (both propane and gas). i talked with an rv sales guy today about propane, and there are motor-homes that cary 100lb tanks. they also sell tee fittings and propane hose by the foot, along with almost any other type of adapter.
woo.
Old Mar 2, 2011 | 03:00 PM
  #456
irab88's Avatar
project propane is a go!
Old Mar 2, 2011 | 03:10 PM
  #457
Old Mar 2, 2011 | 08:24 PM
  #458
irab88's Avatar
the following confirms there is a god, and he has a sense of humor.
i saw this after leaving work today. i burst out laughing at the irony
Old Mar 2, 2011 | 08:55 PM
  #459
irab88's Avatar
https://www.yotatech.com/forums/f116...uel-go-230782/
Old Mar 3, 2011 | 03:19 AM
  #460
RBX's Avatar
RBX
Good Luck!!!
