GreenYoda's 1995 4Runner Build-Up Thread
Old Nov 20, 2011 | 01:41 PM
  #101
GreenYoda's Avatar
didnt get as far as I wanted today, but made some progress
lots of brackets
A mechanics best friend, shes such a cute little dog
˟˟˟˟ removed
now its not hanging so low
next up, cutting off my tailpipe and centering my fuel tank, and making brackets so its not held in by ratchet straps[/QUOTE]
Old Nov 27, 2011 | 11:31 AM
  #102
GreenYoda's Avatar
Got my brackets made
clamped in place
Tanked tucked up in there nicely
Old Dec 4, 2011 | 05:39 PM
  #103
GreenYoda's Avatar
got my front shock brackets mounted up finally and my shocks on
Old Dec 6, 2011 | 05:23 AM
  #104
rattlewagon's Avatar
Are you going to make a skidplate for the tank?
Keep us updated! Cant wait to see some action shots!
Old Dec 6, 2011 | 03:24 PM
  #105
GreenYoda's Avatar
yea, probably going to just re-use the stock one for now (and probably reinforce it) , I gotta add on another part to my brackets to make the stock plate work. if it ends up catching on a lot of stuff i'll probably just build a thick ass plate that can withstand just about anything
action shots wont happen for a little bit yet, still a long list of things to do, but now that I started my new job, money isn't tight, time is
Old Dec 6, 2011 | 04:58 PM
  #106
badcompany's Avatar
liking your build. rally cool.
i missed out on the tank, what veichle did the fuel tank come from, and are you worried about the structual integrity of the rear part of the frame, because the part cut out looks like it ties the frame togeather.
Old Dec 6, 2011 | 05:02 PM
  #107
GreenYoda's Avatar
its the stock tank, just relocated.
not worried about the rear part of the frame, that bracket that was cut out is thin crap just to mount the spare tire under it.
the trailer hitch ties together the frame more than that bracket did.
I still dont have the filler neck hooked back up, it looks like I can make it work. i'll probably work on it this weekend
Old Dec 6, 2011 | 07:00 PM
  #108
badcompany's Avatar
thanks, im thinking of doing the same with mine but i want to keep the stock one and add another one. my plan is to do more expidition style trips so im hoping to get my runner to go at least 1000km before i have to fill it up with 2 tanks should be possiable.
like the 4 link, when im ready to sas mine its something to think about. which pitman arm did you use?
Old Dec 7, 2011 | 02:12 AM
  #109
GreenYoda's Avatar
I believe it came off of a mid 80's land cruiser, it has more drop to it than the stock one, and a little bit beefier.
I just walked around the yota bone yard until I found one that looked like what I wanted
the 4-link is a ton of work (and a little bit more $$$) than a leaf spring setup, but there is a reason why all the competition trucks are 4-link with coil overs.
Old Dec 7, 2011 | 03:32 AM
  #110
badcompany's Avatar
its personal prefrance i guess. i built a double
truanglated 4 link buggy, in 08 it wad too expensive
i havented calculated but im sure leafs will
be cheeper
Old Dec 7, 2011 | 03:12 PM
  #111
GreenYoda's Avatar
be cheeper
got any pics of the suspension setup on the buggy?
Old Dec 7, 2011 | 06:01 PM
  #112
badcompany's Avatar
unfortunatly i dont have many.
hear's one during testing of everything
i had to resize it so i hope its good
Old Dec 27, 2011 | 06:40 PM
  #113
GreenYoda's Avatar
well, Ordered rear shocks today.... really only needs a high pinion diff for the front, put the front gears in the rear, and order a new set of high pinion gears for the front to go with everything else
soon we will grenade something.....
Old Dec 27, 2011 | 10:49 PM
  #114
john4wd's Avatar
I love your front coil suspension set up, Subscribed :}
Old Dec 27, 2011 | 11:16 PM
  #115
Trevin49's Avatar
How much in materials did it cost you to build that bumper?
Old Dec 28, 2011 | 09:18 AM
  #116
GreenYoda's Avatar
Its like $100 worth of steel, all 3/16" with half inch thick brackets
Old Dec 30, 2011 | 08:12 PM
  #117
GreenYoda's Avatar
got my shocks yesterday, had time to put them on today
also, got some new heims to replace half of the ones I ordered a while ago (bought all RH like an idiot, then realized when I tried to align it why everyone offered RH and LR threads )
$250 mistake later
If all goes well I will take it to get fuel on monday (about a mile each way)
Old Dec 30, 2011 | 08:17 PM
  #118
john4wd's Avatar
Are the shocks Rancho adjustables?
Old Dec 30, 2011 | 08:40 PM
  #119
GreenYoda's Avatar
yes, they are cheap for what they are.
Old Jan 5, 2012 | 11:46 AM
  #120
Red Wagon's Avatar
What a great thread. You're doing exactly what I hope to do to mine!
