GreenYoda's 1995 4Runner Build-Up Thread
Old Jan 19, 2012 | 04:05 PM
  #141
GreenYoda's Avatar
nice, UPS showed up with my other set of 5.29's
gonna start the gear/locker install tomorrow night
High pinion on the left, Low pinion (rear) on the right
Old Jan 19, 2012 | 05:28 PM
  #142
Red Wagon's Avatar
Please take lots of photos. My front ring and pinion went so I am about to regear and doing it myself will save me almost 2k.
Old Jan 19, 2012 | 05:33 PM
  #143
GreenYoda's Avatar
werd, I just got a new charger for my DSLR, i'll charge up extra batteries for my flash... all the write ups I find on how to do it people have crappy photos.
im no expert, but at least I can take good pics
Old Jan 19, 2012 | 05:54 PM
  #144
Red Wagon's Avatar
This is going to be my first fix on anything major for a vehicle. We have the same rig but mine still has IFS. I imagine the setup process will still be similar up front. I think I'll get 5.29 as well si I can go up from my 33's to 35's no worries.
Old Jan 19, 2012 | 06:03 PM
  #145
GreenYoda's Avatar
yep, essentially the same thing on the inside.
why stick with IFS? SAS ftw
a leaf setup is pretty easy
Old Jan 19, 2012 | 09:52 PM
  #146
Red Wagon's Avatar
Not sure what my plan it is yet and I don't know what I'm doing. I'd rather not pay for a build on what I can eventually learn myself.
I'd also rather not pay for something that I would eventually want to replace. This is my DD as well as a toy so I would like to retain some ride quality. I also want to do some overlanding and want decent hwy comfort. Coil over are better for that and IFS is better than that again. So a coil over would give me the best as a wheeler and a compromise for hwy that leafs wouldn't.
For now I also live in Yellowknife and my next prospect move will be to Saskatoon. Neither have big mountains for me to wheel so IFS can handle whatever I throw at it for now.
Not saying I don't want to SAS but it's not the top of the priority list. Gears and locker first. Then rust removal from the body and surface frame rust. I'll give it the Rustoleum treatment! I can learn some basics from making it look good.
Get rid of the carpet and line the interior with some sort of bed liner. Muskeet bog mud smells like manure and so does the truck carpet for weeks after wheeling.
I plan on creating my own thread for advice when I start because I don't really know where to start. Looking forward to it and will begin over the next couple months. My upcoming job is two weeks on two off on site so I'll have time to have a good shot at a restore/build.
Old Jan 20, 2012 | 06:37 PM
  #147
GreenYoda's Avatar
Well, one step forward, 2 steps back...
the 3rd member in the front is welded (I purchased it for $20 from a friend cause the 85 axle I had was missing a 3rd member)
well, the carrier is ˟˟˟˟ed.
now I gotta find out where I can get a carrier (or a whole v6 3rd member) on a saturday in west MI.
Old Jan 20, 2012 | 07:20 PM
  #148
Red Wagon's Avatar
Looks like a trip to the wrecker!
Old Jan 20, 2012 | 07:32 PM
  #149
GreenYoda's Avatar
trying to find one that might have what I need in stock.
there is one that has an 02 4runner v6 that they are parting out... no info on if it has an e-locker or not (I don't want to spend extra on ˟˟˟˟ I don't need)
they open at 9 am tomorrow, I will be their first caller
Old Jan 20, 2012 | 07:41 PM
  #150
Red Wagon's Avatar
Did the 3rd Gens have E-lockers up front as well? I didn't know that the 2nd and 3rd Gen diffs where interchangeable especially after an SAS like you've done.
Are the front 3rd gears 7.5" the same as the IFS? It will be nice to know that when I do an SAS the gears I have to buy soon will be able to reused.
Sorry that I'm using your issues and thread in general as a learning tool. Tell me to piss off if it's annoying. I'll never learn if I don't ask though.
Old Jan 20, 2012 | 07:48 PM
  #151
GreenYoda's Avatar
no big deal, I don't mind the questions.
a lot of 3rd gens had e-lockers in the rear.
the solid front axles from the early 80's trucks used the 8" diff, which is used in all rear ends from the early 80's till now.
its all the same (variations exist for 4cyl and v6 models)
this site has a lot of info on the different years/models/diffs
http://home.4x4wire.com/erik/diffs/
Old Jan 20, 2012 | 08:02 PM
  #152
Red Wagon's Avatar
Did not know that about the front end. I'll just make sure I instal picture perfect first time then so I can resell some used parts.
Cheers for the reply.
Old Jan 21, 2012 | 05:35 PM
  #153
GreenYoda's Avatar
took a ton of pics of my locker/R&P install for the rear.
Parts:
Aussie Locker
5.29 gears
Tools:
Lots
Time:
All ˟˟˟˟ing day
took like 2-3 hours to get the 3rd member out, 2 rusted studs hung me up for a little while.
3rd member out, and clamped to the bench
marked those wheels so it would make it easy to set backlash
caps and races off
I don't know how you could do this job without impact, but people do... I don't
ring bolts removed
ring removed
had to run to harbor freight to pick this tool up, $25 worked awesome multiple times for this one job
I didn't even bend the bolts (yet)
bearings off
spider gears :run:
INSTALL
pull the washer off the back side of the spider gears, put them on the locker
drop it into the carrier
the next part of the locker
then this thing goes in there
then the other half of the locker
putting the diff carrier back together
checked my tolerances, and made sure they were within factory spec
new ring gear on
take the pinion off
press the bearings off the old pinion
press them back onto the new pinion
press the carrier bearings back on
bolt the pinion back in, then drop the carrier into the housing
adjust those stupid wheels to the same marks = perfect backlash in my case
mark some of the teeth
looks good to me
this looks ok too
Tomorrow I'll put this ˟˟˟˟ back in the truck and see how it does
Old Jan 21, 2012 | 07:24 PM
  #154
badcompany's Avatar
thanks for posting.
Old Jan 21, 2012 | 10:38 PM
  #155
RMP8080's Avatar
Nice photos of the rear, can you do mine when I'm ready?
Old Jan 22, 2012 | 04:59 AM
  #156
GreenYoda's Avatar
Thanks.... How much money you got?
Old Jan 22, 2012 | 03:09 PM
  #157
GreenYoda's Avatar
Just got everything put back together and taken for a test drive, drives sooooooo much better, traction in the snow is 10x what it was before, and it actually accelerates
that was the first time I drove it more than a mile since I lifted it, I was a little nervous but it actually rides pretty smooth
I have to dial in the alignment a little more, but im getting close
Old Jan 22, 2012 | 07:45 PM
  #158
Z's Confederate Toy's Avatar
Lookin good man
Old Jan 23, 2012 | 12:34 PM
  #159
RMP8080's Avatar
wow, I'm glad it worked out. Looks great.
Old Jan 24, 2012 | 05:36 PM
  #160
GreenYoda's Avatar
yep, rear end works great....
waiting on a new diff carrier for the front from yoda jims (www.jimsgotparts.com)
best yota junk yard ever
ordered monday, should be here thursday
$25 + shipping for a diff from CO to MI (it was a lot better when I lived 30 mins from them)
