Fjtoymans 1994 extra cab build
I recently purchased a 1994 exta-cab. 3.0 5spd 4x4. It was as the factory offered it. I bought it with the intention of a full build-up. It has 124k on it. It Had a bad head gasket . The motor was previously taken apart. And had some missing engine parts. And so the buildup starts . I replaced the motor with a rebuilt gm 4.3 with TPI, and a 700 r4 Trans. It is attached to a gear driven dual crawler case. I will post pics as the buildup has progressed .This is the starting pic of the day I picked it up.
My buddy gave me the go ahead to use his shop to get this done. 1 week after acquisition, and the motor is outta here. Here's a pic of the oil. 2.5 gallons of milky mixture.
The engine bay cleaned up nicely.
It's now ready for a new heart.
With a Chevy engine swap , I needed to install a suspension lift and a body lift.
I had painted the components for the lift several years ago, as I was working on a 1989 4runner. Long story. Took the accumulated parts from it and went to town. I used everything from the 4 runner frame except the frame.
The engine was originally out of a 91 Chevy blazer. A trip to the local Trans guru to install the adaptor kit Transmission tails haft was in order. I needed to adapt the 700 r4 Trans to a gear drive transfer case. While I was there, I asked him about rebuilding my 4.3. He told me he had built one for his van, and wasn't sure if he was going to use it or get a new van. Long story short, I bought his long block. He told me it would produce 275 hp. $1600 bucks, I got the Trans rebuilt with a new torque converter and a newly built 4.3. Game on.
My 1994 has no A/C. So a trip to the local scrap yard and I got a set of pulleys and new alternator for $50.00.
A trip to my sandblaster and a fresh powdercoat( Eastwood ) and its looking super. No big cast brackets from the serpentine set up.
After the engine was installed , I needed to get a radiator. I called advanced adapters . I spoke to Matt. He was very helpful. I ordered an aluminum radiator with the Trans cooler built in. After I received it and fit it in place, I decided to do a electric fan. I also needed to customize this custom radiator a little more. I moved the top neck from the side to the rear and needed to get some custom brackets to fit the Spall fan.
I kept the Chevy power steering pump. Had a custom pressure line made and added a cooler to the temp low. After making up some brackets, the install is complete.
As you can see it the previous suspension pics, i kept themindependent suspension for now. I added a dual crawler box. The marlin coupler,worked like a dream. I actually added it for two reasons. First was I needed a way to move the transfer case mount back. The original mounts were a ways off. I purchased a All-Pro X-Member to take care of the rear mount and skid plate duty.it also incorporates a parking brake on the t-case. ( not shown) the second was lower gearing for the woods.
Once the crossmember was installed, I needed to measure for a driveshaft. Now that that's done, I purchased Pro Comp MX4 shocks to ease the ride. I also added a set of 16x10 weld wheels, and Mickey Thompson Baja Claw 35x13.5- 16 bias plies.
I'm finally done with 95 % of the build. I need to add a dual speed sensor. 1 for the Chevy computer to tell it how fast we're going, and 1 for the speedometer . The dash is electronic speedo and the case is cable drive. A few little odds and ends to tie up and on to the next project. Here's a few shots on the trailer as I'm headed to the alignment shop tomorrow .
Yes..as I'm reading it, I start liking something you're doing and wonder how it's gonna end up and then I keep scrolling and there it is! Haha, very quickly built from an Internet point of view. I love the colors and those tires, too.
Awesome build!
Awesome build!
I bought this April 18th. Started tearing into it on the 25th. I worked on it 2 days a week. Plus I made a few other doodads. I made this seat /gun rack for a friend of mine.
I welded rim stiffeners for a FJ cruiser.
And a few sets of gusset end spindles for FJ cruiser/ 4 runner / Tacoma .
I am happy to see my dream come reality. Lots of work, lots of research, lots of money. But it's mine and its built, not bought.
Road Bull
Oct 10, 2015 04:55 PM
