Dropzone's 1994 4runner Build AKA: Project Recycle:
Old Nov 5, 2017 | 11:42 AM
  #581
dropzone's Avatar
Fossilized
Went up to the Seattle area yesterday and met Corey and picked up some stuff for the truck
got a great deal on his old awning and storage box
by https://www.flickr.com/photos/42814812@N06/, on Flickr
The awning will go on the rack I have. I have plans to rework the rack to get it lower.
I'll have to figure out how to mount the box and will use it as a base for a future sleeping pattern. might see if I can extend the drawers so the two bigger ones go to the back seat
Old Nov 5, 2017 | 03:47 PM
  #582
habanero's Avatar
Nice additions! Will be interesting to see how you incorporate the drawers into your truck.
Old Nov 12, 2017 | 07:00 AM
  #583
dropzone's Avatar
Fossilized
Thanks Hab..may be a little while till i figure out what to do with it. Too good of deal to pass up after pricing stuff many times to build something.
Had a little time to work on the 4Runner yesterday to make it 4WD before winter.
Found that the front output flange on the A340F Transfer case works like a Jeep Slip yoke.
I go and pull the stock output flange and ATF dumps out like crazy
To top that off I couldn't use the multi pattern flange because the spline shape/count is totally different and a small diameter
Little tidbit too is the stock flange is pinned with studs.
I ended have using the long slip driveshaft from the 81 after cutting 5" off the outside and 2" off the inside slip. Hopefully it will still be long enough to use when i finally get the duals put in the 4Runner
finally have 4WD just in time for winter daily driver duty and some light snow wheeling
still don't know why some pics using flicker double post..
Old Nov 12, 2017 | 02:59 PM
  #584
habanero's Avatar
Cross fingers for length. Also, what is this...snow...you speak of?
(took the trash out tonight in my bare feets)
Old Nov 12, 2017 | 05:13 PM
  #585
87and94's Avatar
94 4runner build
Hi y'all I just fixed my yota after her sitting for 8 months I am so excited to drive her again!! But I have a plan for her, to make her into an adventure rig! Something I can take a girl on a date in but then fine a spot of emptiness and just drive. The guy that I bought it from bought it from a guy who put a lift on her so I'm not sure what the lift is but it's running stock A arms and I need to upgrade to better ones any suggestions? What's the best after market A arms I can buy that aren't stock?
Old Nov 13, 2017 | 05:27 AM
  #586
dropzone's Avatar
Fossilized
I am praying for a lot of white stuff...my fingers are crossed too!
congrats on the truck. I don't know a lot about IFS suspension arms, i cut mine off but you could try total chaos
Old Nov 13, 2017 | 05:33 PM
  #587
87and94's Avatar
Thanks I'll look them up I'm about to start a thread for my project
Old Nov 13, 2017 | 05:42 PM
  #588
87and94's Avatar
94 4runner build
Okay well, here it is (sorry for my punctuation in advanced) I'm building my runner finnaly things I want to do is a roof rack a compressor front and rear bumper a winch a light bar new lights probably halos eventually paint a manual transmission swap so far that's it do you guys and girls have any advice or things I've missed any tips where to find
Old Nov 13, 2017 | 06:29 PM
  #589
habanero's Avatar
A build thread piggybacked onto somebody else's thread? Nope.
I know Dropzone has a really interesting build and constantly makes us drool over his ideas and additions, but you'll have to start your own thread with your own title in the proper build-up section.
Good luck with your build and new thread and that's my advice.
Old Nov 13, 2017 | 06:39 PM
  #590
87and94's Avatar
How do I make a new thread
Old Nov 14, 2017 | 04:51 PM
  #591
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
Go back up to top of page; hit the (mumbo-jumbo) Section link, (then choose a different age range/forum topic if appropriate), but anyway at the list of all posts in that particular forum is a button on top left labeled "New Thread".
Old Nov 15, 2017 | 12:41 PM
  #592
dropzone's Avatar
Fossilized
thanks hab
looks like you got it figured out
see above, thanks for helping keep this one clean
i have a pile of spare parts and left overs from the trekker. No LED aftermarket LED tail lights that i can find for 2nd gen 4runners and stock taillights even with bright LED replacement 1156 and 1157's leave a lot to be desired so decided to experiment
220* for 12 minutes did the trick
throw tail lights from Trekker and some clear KC LED for signals
running lights
brake and turn signals
not too bad with faded stock lenses
Old Nov 15, 2017 | 02:59 PM
  #593
habanero's Avatar
Nice work yet again, I like that it will look stock until it doesn't. Then it will look surprising.
I pm'd 87&94 with a simple how-to. He was a quick study, may not have even needed help figuring it out.
Old Nov 16, 2017 | 12:49 PM
  #594
dropzone's Avatar
Fossilized
Thanks Hab appreciate the feedback and helping out the new guy
So went to polish the lenses since they are faded as heck, they cracked like crazy
pretty much a waste of time...I was heating and separating the housings from the lenses since that is how you do it for headlights...well a set of trashed housings and some frustration i think,
Hey idiot why didn't you just cut out the back of the housing to mount the LED's (amber light for mock up). Won't need to do as big of hole for version 2.0 for the brake light
would have been time and money ahead if I would have done that the 1st time around.
so said screw it and ordered a new set of aftermarket housings off ebay since the last good set of housing I have has 25 year old lenses and what to keep one good set unmangled.
Also ordered a set of Clear LED brake lights since they should show through the red brake light better.
overall cost will be about $70 and lessons learned.
Version 2.0 should be done next week when stuff comes in
Old Nov 16, 2017 | 06:05 PM
  #595
habanero's Avatar
Ancient plastic or ancient plastic + heat? Either way, I'd debated asking if you were going to polish them because they are pretty dull. Guess you agreed.
Well, $70 for a shiny new restart and a lesson? Worse things could happen.
Old Nov 17, 2017 | 02:06 PM
  #596
dropzone's Avatar
Fossilized
Yep, also remembered I had a 4" hole saw so that should help make for a cleaner cut when the new housing arrive.
decided to inventory the Prius Winter Recovery Kit. With the addition of a couple of soft shackles I can lose a few pounds of steel
Old Nov 17, 2017 | 04:01 PM
  #597
CreeperSleeper's Avatar
How do you like using those soft shackles. I thought about getting some but I'm not sure if I trust them. There is something about threading in a bolt that inspires confidence. LOL
Old Nov 17, 2017 | 07:21 PM
  #598
habanero's Avatar
They sure seem to have become quite popular...
Old Nov 19, 2017 | 10:35 AM
  #599
dropzone's Avatar
Fossilized
i hear you, i will probably try one out in a week or so out at my parents to see how they work in a controlled environment. I probably have 12-15 D-rings that I have accumulated over the years.
yep, they are slowly becoming popular. I think you would always need a couple of steel shackles for contact on a vehicles recovery point (like hitch mounted shackle point)
Old Nov 20, 2017 | 12:44 PM
  #600
Well let us know what you think!
