can't wait to see the runner when you get it back, you got to be pretty excited!...
gotsta love some more LED goodness!
Quote:
Yaaaaaaaaaaaaay!!!!!!
Sweet LED too!!!
Quote:
Originally Posted by bootscootboogie
nice nice
Thanks everyone, so gonna be a little delay in picking up the truck. I thought I had everything for the swap but misplaced some parts so they are on order.
I was able to get down to a friend of mines shop today to pick up the 4runner. *I was in Texas visiting family last week so pick up was delayed a few days. *I am really happy with what he did with my limited budget.
Had a co-pilot on the way home*
Anyway on to pics
what he started with
Front view:
side view
Will be swapping the front shackles to a set of boomerangs from Sky's to help clear the front body mount
going from a 235/75/15 to a 35x12.50x15 was nice
anybody need some left over IFS parts? *
added some X-O Fab frame plates and Ford shock towers.
I will be swapping to the 2WD oil pan in the next couple of days, tight fit as is
I will probably be swapping to rear leaf springs in the near future. the FJ80 springs I had didn't raise the rear as much as I had hoped.
Anyway on to pics
Front view:
side view
We had a lot of fun doing this swap for ya Rob. Now let's so stretch these springs out!!!
Looks like a great job was done. A picture with the stock tires on it compared to the new tires really make the stock ones look like donuts. Congrats!!!
I like the bluetooth front driveline! Lol. What are your plans for a replacement? What springs are you going to go with in the rear? Looks great so far!
Thanks Ed- it was hard to get stuff done, 4 people in the neighborhood walking by wanted to take a look and a few slowed down and shouted as they drove by. Hard to get stuff done
Quote:
Originally Posted by Reluctanse
it has arrived! looking way good!
Thanks!
Quote:
Thanks Don! I appreciate your hard work. Hoping to get the 2WD pan on in the next few days. That will allow me to check the flex. Tackling the rear end to check the 5.29 third swapped and the rear shocks mounted.
You were right, that thing with out rear shocks was squirrelly as hell. It was even bouncing on I-5 hitting some bumps on the trailer.
Quote:
Thanks Terry, Don (85Toyman) and his crew did a great job. I am really happy with it
Quote:
Originally Posted by magnet18
Looks awesome, ready to crawl!
any trips planned yet?
And I want to say yes to ifs parts because they look shiny, realistically i don't think I have any use for them
Haha, I would just about give the parts away if someone wants to pay shipping. I'll get them cleaned up and see what is usable and post an add. I think I may have the front diff sold.
Runs- yep I plan on helping out with the Oregon Trophy challenge, a camping run with Gitout.com and some other stuff.
Quote:
Originally Posted by habanero
Wow! That sure amped things up(wards) a bit.
Thanks Hab, it is a little higher than I was hoping for. May pull a leaf or two.
Quote:
Bluetooth driveshaft, that is awesome I took a measurement I should be able to use the front shaft from the 81. If that doesn't work it will be a little while before i can order a replacement.
Current rear springs are FJ80. If I end up converting to rear leafs they will be the rear springs from the 81, hence the name project recycle. Front springs are off the Trekker too. I'll take it out a couple of times to see how the current system works
tripped over a grinder in the garage and decided to try an idea for adapting the rear swing out to clear the lower part of the rear bumper with a 35" spare
measuring it I would need to raise the mounting surface 2.5-3"
made a stencil out of some old poster stock. my idea is to cut 4 pieces of 11 or 12 gauge steel that I picked up last summer. Angle it so that it will clear the rear, cut the mounting plate and raise it up the distance I need. I'll use a combination of welds and bolts to support it.
test fit of the 1st piece. the red line indicates where i will probably end up angling the bottom to clear the rim
got the idea from this post. I think having the plates on both sides, with a few beads on each side and grade 8 bolts should support it fine.
Quote:
Originally Posted by BUDD
good job!
if you worried that with the bigger tyre, you might touch the ground when offroading, someone done this to have more clearance
