the dragons 88 runner buildup/rebuild
Old Jul 21, 2012 | 11:48 PM
Terrys87's Avatar
Mine was a broken easy out in the oil sending unit. What my machine shop did was weld a nut to the sending unit shaft. He put a washer between the block and the broken shaft. Maybe your shop could try something like that.
You will be surprised at how much more you get done with a to do list. When you are actually out working on it, alot of things slip your mind. It makes a differemce.
As far as the rear of your drivers fender, I havent had much luck on being able to get on straightened back out after a door has pushed it in, but they are fairly reasonable to get replaced. On the core support a come along works well also. I have used a bottle jack and cut some 2x4 to length and rigged it to the fire wall and used slow gentle pressure to push it out. It is a balancing act.
Core support doesnt look like it needs to come out to much. I had to replace my core support on my 86 and it is bolted in. I know another guy that his is bolted in and has been for 5 years and never a problem. I am not going to have mine welded in as it makes pulling the drive train so much easier.
I am looking for a sewing machine for me to learn on doing seats. I havent tried patching, but could see where the levi patch could help. Interior work is my next learning step on these this winter. I plan on taking some old seats and cut the covers stitching and use them as a pattern. Kind of like they did in the old days when you could go in a Wal-Mart or K-Mart and buy shirt patterns. Having it done is expensive and interior shops sell the material for a cheap price. Got to be a better way of doing it.
Old Jul 22, 2012 | 07:32 PM
Cyberhorn The Dragon's Avatar
my friend has a mig welder sounds like a plan to try, though if it does need a shop then thats where it'll go
oh absolutely!
nod ive been looking at new metal for that fender the hood has a crease i might be able to hammer an dolly out enough a coat of duraglass an ect will make good but yeah that fender is toast the passenger needs rust repairs
i took a better look at mine the passenger side is rusted out low down due to battery acid (its right below the tray) ive seen replacement metal for that as well
well for those reading the idea would be to keep the tear damage from getting worse the iron on patch slips in behind the vinyl a towel over it to slowly heat the patch an vinyl to bond them together Ill likely hand stitch the seat side an headliner with a curved needle the seat side i might also add a bit of the levi patch to the inside to reinforce the repair an cover with some nice seat covers the back seat is very clean would be nice to keep them that way
personal note get dash cover!
Old Jul 22, 2012 | 09:18 PM
jason in tn's Avatar
Sounds like a good plan for the seat, also a good list of upgrades.
Old Jul 23, 2012 | 08:31 PM
something i found on Ebay cup holder fit under an after market radio mounts in what would be an empty pocket for junk to be tossed in
Universal-Car-Single-Double-Din-Radio-Pocket-Kit-w-Drink-Cup-Holder storage
Old Jul 23, 2012 | 08:59 PM
  #25
thank you jason,
best news short of buying the runner doctor ordered my wound vac off now im not slinging around a 5Lb weight off my shoulder with a tube attached to my foot IM FREE!! still have a small hole but its healing
Old Jul 23, 2012 | 09:43 PM
  #26
RMP8080's Avatar
Dragon, nice runner, looks like you got some work, remember the most important thing is have fun doing the build and take your time, I got two builds one a 87 pickup and a 89 runner, most of the work in on the runner, looks like the same rust areas....
Good luck and be safe,......Bill
Old Jul 23, 2012 | 11:46 PM
  #27
Terrys87's Avatar
You may have come up with the best solution yet on a cup holder. Glad you poated that. Never would of thought of that.
Old Jul 24, 2012 | 12:28 AM
  #28
You may have come up with the best solution yet on a cup holder. Glad you posted that. Never would of thought of that.
thank you Terry! ive been payin attention to various build threads around the forum an seen a lot of the 1st gen runners an trucks have no cupholders i saw that while just looking at ebay an had that inspiration/share this light pop on!
RMP8080, oh i plan on enjoying every moment of it even if its just cleaning bolts! ive been stuck on my rear in a chair for 5 years im chewin the titanium bit right now foot isnt quite healed totally but look out once doc says it is its so DANG close!
Old Jul 25, 2012 | 04:12 AM
  #29
Terrys87's Avatar
5 years, Ouch!! I bet you are chomping at the bits. Accident? I was bed ridden for 2 weeks one time and that was about all I could handle. Hope things get better soon.
I would say count on a good 10% of build time just cleaning and prepping. Alot dont factor that in and that does add into. That is something that can always be done when waiting for parts or funds.
Old Jul 25, 2012 | 10:54 AM
  #30
yes i stepped on a chunk of glass went right through my flipflop sandals an found out the hard way i had diabetes (much longer story im cutting to save space)
i had diabetes related bone infection (ostiomyalitus) which to head it off the doctor did a 1/4 tarsal amputation so i cant count to 20 anymore other factors came in an it just didnt want to heal so i got to sit.. till it healed
April of this year the hole could hold 2 half dollars in it an be flush with the surface of the foot i got a skin graft spent 2 weeks in a nursing home (my 3rd graft)
yup i expect that i think this weekend im gonna pull that driver fender off so it wont ruin the door any further i can do most of that sitting on a kitchen stool :-D
Old Jul 28, 2012 | 04:54 AM
  #31
Terrys87's Avatar
Had a skin graft myself, dont want to go thru that again. One moment can change your life so fast. Hopefully the worse is behind you and brighter days are ahead.
Old Jul 28, 2012 | 12:14 PM
  #32
thank you terry, i hope so too
Old Aug 1, 2012 | 12:18 PM
  #33
another note for myself:
make sure to fix the factory crimp connections for the fuel injectors before putting engine back in see terrys thread for location an what to look for
Old Aug 1, 2012 | 05:34 PM
  #34
rustED's Avatar
Nice build!
X2 on the cupholder, nice find! I've been looking for a solution to that dilemma, lol, do you know if it interfere with the shifter at all?
Old Aug 1, 2012 | 07:33 PM
  #35
Originally Posted by rustEDyota83
Nice build!
i was out there in her looking an you know what i dont think so now if its a sonic 44oz it might.. but huge as that is i still think it'll have room
also my shifter is bumping the transfer case shifter when i put it into reverse is this the bushings in the cups down in the trany?
will be posting a couple picts i pulled the drivers fender so i can actually open the door fully an the inner fender is definitely gona need some tugging an hammering to straighten it out
Old Aug 1, 2012 | 07:38 PM
  #36
yep gona need some pulling
sprayed some pen oil on the backs of the bolts. still snapped one bolt at the bottom of the fender (two next to each other) an broke the one holding the air box top to the radiator core darn things :-|
Old Aug 2, 2012 | 06:24 AM
  #37
Terrys87's Avatar
Busted a few of them bolts myself. I would suggest getting a come along on the front of the inner core support and take a piece of 2x4 over the inner fender and a big freaking hammer and try tapping it out. Maybe a jack on the firewall. It doesnt have to be perfect as you will have quite a bit of leeway for the feder.
Hope doc says your foot is getting better.
Old Aug 2, 2012 | 11:24 AM
  #38
yep likely to use my 79's little bottle jack an some rigging to push an a big dead blow hammer got to remove a few things from the inner fender where shes parked ive got nothing out infront to rig a cable to for the come along darn it
i will figure something out MUHAHAHAHA
foot is doing well, i shouldnt have been on it to do the fender but agh! pulls on hair an forgets shaved self bald tired of the bozo the clown hair the hole in my foot is down to 2mm x 2mm nearly no depth YAY
Old Aug 2, 2012 | 07:34 PM
  #39
gah never have i had so many bolts break
1 13mm
2 12mm
2 10mm
also broke the plastic clip end of the hood cable (*&^%# badwords)
all involved with the components attached to the drivers fender im gona be drilling a lot of those out yuck
the aftermarket cruise control wasnt hooked up only one wire was i suspect it doesnt function anyone happen to know how hard it is to pull a factory one an put it in?
Old Aug 4, 2012 | 08:30 AM
  #40
Terrys87's Avatar
I feel your frustrations on the broken bolts. Got a few to ake care of myself. I have been trying to build up a factory cruise control but am having to do it in bits and pieces. I am not sure, but am wondering if the wiring harness has to support it as if there may be two types of harness for these trucks. One with cruise control and one without. I could be wrong. My 86 had it but that harness was toast. I am considering aftermarket.
Its looking better.
