DIRTCO's 1986 4Runner Build-Up Thread
Old Apr 9, 2009 | 06:22 PM
  #581
idayota's Avatar
i know its been awhile since you posted up on the gauges, but here's another option that i went with on my '84.
Old Apr 9, 2009 | 07:19 PM
  #582
DIRTCO's Avatar
Originally Posted by cubuff4runner
Looks Awsome.. I am ready to run some trails with you guys again.
Thanks, your rig is looking awesome too! I think Cory and I might be going out to BV on Sunday. Maybe we could try to break Spring Creek in a couple weeks? Let me know what works for you, most the weekends are pretty much open for me!
Old Apr 9, 2009 | 07:33 PM
  #583
DIRTCO's Avatar
Originally Posted by OutlawMike
Quote:
A while back there was a thread about whether or not it's normal for a turbo to glow red at night; we pretty much decided this is normal to a certain extent, but it did worry me.
Dirtco,
Just a comment on this. I did my Mechanical Engineering internship with Allied Signal Automotive, Turbocharger division (formerly Garrett Turbo).
It is perfectly normal for the turbo to glow red after it has been driven, especially if it has been driven hard. The turbo creates an enormous amount of back pressure on the motor, by design, and is placed as close to the exhaust valves as possible to ensure that the highest temp, highest energy exhaust flow is getting to the turbine.
There are two things that spell an early death for a turbo. Old, dirty oil will kill the bearings very quickly and heat soak-back will cook the oil in the bearings.
The RPM's that turbo's spin is a little mind boggling. While these engines are lucky to see 5k RPM every once in a while, turbo's spin at 50, 60, 70, 80k, RPM, even higher for some models. I working on their GT15 turbo for 1.2 L turbodiesels. 180k RPM max for that little semifloating, one piece journal turbo. You must keep the oil clean and change it frequently, the journals in the average turbo rely on oil to be at it's peak performance. (Ball bearing turbos have their own set of requirements.)
The other thing that kills a turbo over time is heat soak-back. When you turn the engine off the turbine housing is very hot, as you have noticed. The center section of the turbo, where the bearings are, is cooled by the oil flow and coolant flow, if it is a water cooled center (some are air cooled, even worse). When you turn the engine off, all forced flow ceases. The oil quickly drains out of the center section. The coolant stagnates and only moves by natural convection. The heat from the turbine housing soaks into the center section. Without any flow, the residual oil in the housing sees very high temps for a period of time, as the system air cools (tick, tick, tick).
With conventional oil, if it is a little past it's prime, it will cook into crystals in there. Those crystals (coaking) will restrict the passages and damage the bearings.
The best thing you can do is run a full synthetic for your turbo and change it every 3k. You can get away with longer oil changes on a non-turbo motor with synthetic, but not with a turbo. The synthetic is highly resistant to coaking in the center section
Mike
Wow, thank's Mike! That's some great information!
I use Mobil 1 synthetic and change it every 3k, sometimes even sooner. I also have a turbo timer to let the turbo cool down a bit before shuting down the engine (between 3-6 minutes). Whenever possible (95% of the time), I get the engine up to full operating temp before driving it. Even if I don't have time, I still will let it warm up for at least a few minutes before taking off. Thanks again for the infomation!
Old Apr 9, 2009 | 07:43 PM
  #584
DIRTCO's Avatar
Originally Posted by Richjrosa
Subscribed.. Let me say I just spent 3 hours going through all this and your build is amazing. I wish I had the mad skills to take on something like this. I won't be using my runner for crazy crawling like that but it is sure inspiring to see you guys go at it. I do enjoy learning stuff here and there.
Thank you
Thank you! I'm glad that you enjoyed reading it.
Old Apr 9, 2009 | 07:50 PM
  #585
DIRTCO's Avatar
Look's good, I like how that turned out.
Old Apr 10, 2009 | 10:17 AM
  #586
OutlawMike's Avatar
Dirtco, as with everything else on this project, you are on it!! You are doing everything you can do to keep that turbo operating properly.
Below is a picture of a turbo cross section I keep on my desk, a going away present from Garrett when I finished my internship. This is their GT15 turbo. It has a single, semi-floating journal bearing and a thrust bearing. The thrust bearing is on the compressor side. The high pressure oil is fed in from the top through the threaded fitting. It feeds sideways to the thrust bearing on the left, down to the compressor side journal lands, and sideways to the right to the turbine side journal lands. The oil then exits into the oil jacket and drains out the bottom. This is an air cooled unit, so, no water jackets in this casting. The problems with oil coaking start on the turbine side in the oil jacket around the oil slinger. As that cavity fills with crystalized oil, oil drain flow is restricted and eventually the oil in the journal cannot drain fast enough, heat develops, and you spin the bearing.
[IMG][/IMG]
Good luck with the rest of the project, not that you need it. You do good work.
Mike
Old Apr 10, 2009 | 11:54 AM
  #587
Dirt Driver's Avatar
I have one of them little GT15s too, but the ends are still on and it doesn't have a big hole in the center housing. Twins would probably work pretty well on a 22R-E....
Nice build DIRTCO. I look forward to more.
Old Apr 10, 2009 | 01:56 PM
  #588
Volcom's Avatar
Originally Posted by DIRTCO
Dash out of truck, and gauges mounted up
In the truck
I've got 3 small gauges to mount also (oil pressure, water temp, and volt meter) and think they would go perfect where you have mounted yours. Do you think I could drill the holes in the dash pad without removing it from the dash? I know it's only a couple of screws that hold it down but I'm pretty lazy and hate messing with the dash
Old Apr 10, 2009 | 07:19 PM
  #589
DIRTCO's Avatar
I don't think so, most the gauges I've seen have a bracket that has to be attached from the back side of the gauge. I also had to trim some of the dash behind the pad, there's also wiring, etc. Nice try though!
If you do pull the dash, don't forget the nut behind the far passenger side vent. And the nut in about the middle/back of the dash (you can reach it with a long extension behind the glove box openning).
Old Apr 10, 2009 | 07:29 PM
  #590
DIRTCO's Avatar
[IMG][/IMG]
Mike
Wow, that's awesome! It's amazing to see the inside of a turbo and how it works, I can't believe how much punishment these things can take! Very cool, thanks for sharing.
Old Apr 11, 2009 | 04:21 AM
  #591
joeskater923's Avatar
Love the fact you have a place to do all of that, and the tools. Im doing a SAS swap to my runner here soon. In the mean time i have been looking for a turbo setup for my 22re. Harder to come by then i first expected. I know LC makes one, just a little too expensive for me. But anyways nice truck dude.
"Wheel till the rims fall off"
Old Apr 16, 2009 | 06:54 PM
  #592
DIRTCO's Avatar
I got a few more details wrapped up .
First, I got my rear CV driveshaft installed. It is a stock front shaft that I had re-tubed for the rear. It really helped to get rid of the drivetrain vibration that I was having. (Thanks again Hayes for bringing the driveshaft up to the county for me)
The transfer case rear output seal developed a small leak, (I'm guessing from the slight driveshaft vibration) So I replaced that too.
I also pulled the transmission pan and installed the bung for the temp sender. I really wish I would have installed it when the transmission was all tore apart, but oh well.
Old Apr 16, 2009 | 07:31 PM
  #593
DIRTCO's Avatar
I took the 4Runner for a test drive and I realized that I was going to have to balance the tires. I never really pushed the speed limit with the old driveshaft, but with the new one I wanted to cruise at a decent speed.
So I went back to the shop and balanced the tires. Let me tell you that 35's with 2" of backspacing and rockrings suck to balance. It was not the process of doing it, but getting the tire on the machine, etc. The large wing nut/lever assembly only cleared the rock ring by about 1/2" and had to go about 6" inside the wheel. With the extreme offset of the wheel, it would not stay on the cone that lines everything up on the machine. I had to hold the entire weight of the tire and wheel, while threading everything through the rock ring and into postion. I did get all of them balanced, it just took some smashed hands, a sore back and tire tracks all over my body to finish the job.
Each tire and wheel took about 6-7 oz on each side of the wheel. I used hammer on weights on the inside and stick on weights on the outside, behind the rock rings. I was able to get all of the tires/wheels within 1oz of zero, I could have zero'ed them but it was really not worth the effort.
Anyway's, it was time to take the 4Runner out again and see if I fixed most of the small stuff that I ran into the first time out. The GF and I met up with Cory and ran Chinaman's again on Easter. The weather sucked on the drive down, but once we got on the trail it was not that bad. There was nobody on the trail so we had the whole thing to ourselves.
Like last time, I didn't get many pictures. The truck worked awesome and I didn't run into any issues. I drove the whole way out there at about 70mph, I could have gone faster but didn't see the need. Also, the fan didn't rub any more when flexed out. When SUPER flexed out, the rear tire just barely touches the trim on the back of the rear wheel well. Once I get my bumpstops installed it should take care of that issue.
Here's the only pictures I got
Old Apr 16, 2009 | 07:56 PM
  #594
abecedarian's Avatar
/me longs for the olden days of dynamic balancing like semi-trucks have ... sorry meant had ... (yeah, I'm a smartarse)
looking good though.
Old Apr 16, 2009 | 08:37 PM
  #595
Volcom's Avatar
What?? You hit up Chinamans again and didn't take but 2 pics
Did you make the left line on Whale Rock? I made it up without slipping a tire while on 33's and haven't tried it yet on 40's. Kinda scared I won't make it since the COG is now higher
Glad your rig is finally drivable closer to the speed limit. I bought some cheap 35's and plan on mounting them on some spare wheels in preperation of having to drive it rather than trailer it this summer. I also will have to pull a small utilty trailer with the big tires / wheels in it and swap them at the trailhead and back again at the end of the run. No fun but that's the only way I'm going to make it to the trails in less than 10 hours
Old Apr 16, 2009 | 08:47 PM
  #596
airmen65's Avatar
wow, Dirtco. i do believe this is the sweetest yota i've ever seen. the attention to detail, the 22re-t, the digital dash, its all awesome. congrats on gettin her in shape to wheel, i'm uber jelous!
Old Apr 16, 2009 | 09:33 PM
  #597
DIRTCO's Avatar
It's hard to take pictures and drive at the same time! I gave the camera to Laura to take some pictures, but she is so used to the green 4Runner that she does not take a picture until at least two tires are off the ground. She said it just drove through the obsticle and didn't do anything cool, ... I guess that means it works pretty freaking good
I took the middle line up Whale Rock. In the last 4Runner I used to take the left line, but I'm a little scared to in this one. I have a lot more overhang in the rear and I'm a little concerned about the transmission starving for fluid and getting stuck. There's also the the super hard roll if you mess up. I would love to try it once I get more used to the vehicle and have some more people to give a hand if things go South.
I have one question on trailering your 40's to the trail. I know this will save wear on the tires, but how much time do you think it will save? I've thought about the same thing in the past and came to the conclusion that the only advantage is less tire wear. Between the time it takes to pull the tires off, mount the new ones, switch at the trail head, run the trail, switch again and drive home (with over a 1000lb's of trailer behind you), I bet that 45 mph on the 40's would overall be faster. I do think it would save some tire wear on the 40's but it's something to think about. I'm not trying to be negative, just just something to think about.
Let me know when you are ready to go wheeling, with all this new snow we keep getting I want to do some snowbashing bad. The time frame you talked about should work out great!
Speaking of Whale Rock here's a couple old pictures
K5 Blazer on 42's getting denied
The old green 4Runner back in the day, walking up it with no spot
Old Apr 16, 2009 | 09:48 PM
  #598
Hayes's Avatar
How was the balance? If you want, when you come down to A-town, I can balance those for you (I have all the special cones and tricks).
Old Apr 17, 2009 | 01:38 PM
  #599
Volcom's Avatar
Good to hear that the new 4Runner works out that good! I'm just giving you a hard time about no pictures. I also understand about the left line and no forgiveness! It's a long fall down if you mess up. The time I went up on 33's and my current 4" lift, I didn't drag my gate (no bumper on mine). Looking at the video, I might have barely touched a rear bumper if I had one.
Do the autos starving for fluid that easy? How do they take getting overfilled a couple of oz's to try and prevent that?
I have one question on trailering your 40's to the trail. I know this will save wear on the tires, but how much time do you think it will save? I've thought about the same thing in the past and came to the conclusion that the only advantage is less tire wear. Between the time it takes to pull the tires off, mount the new ones, switch at the trail head, run the trail, switch again and drive home (with over a 1000lb's of trailer behind you), I bet that 45 miles per hour on the 40's would overall be faster. I do think it would save some tire wear on the 40's but it's something to think about. I'm not trying to be negative, just just something to think about.
Believe me, I'm not looking forward to swapping tires at the trailhead I think I would probably swap out the 35's for the 40's in twenty minutes. But the drive on 35's (balanced ) and closer to the correct gearing will probably be more enjoyable and like you said, save on some tire wear. We'll see how well a 22RE on 35's pulls a trailer loaded with 500 pounds of tires and a couple hundred pounds of camping gear does.
Early May is looking great for some snowbashing with all the snow the mountains have been getting!!!
Old Apr 19, 2009 | 07:20 AM
  #600
DIRTCO's Avatar
They seem to be balanced great now. An extra set of hands would have made all the differance, it was just a PITA doing it alone. If I do run into issues down the road I might hit you up, thanks for the offer. Have you worked on your transmission yet?
I know that your just joking around! The left line is one of my favorite lines ever, but like you said it can be unforgiving. I would hate to total the truck on it's second time out, or ever for that matter. Part of wheeling your only vehicle is knowing where and when to take the smart line. I would love to take the left line one day, when I get more used to the vehicle.
I'm sure you would make it up, no problem! Cory doesn't even stop for the thing anymore, just goes right up it.
I don't know. It's a pretty steep climb, so I'm not sure if there would be any issues or not. I have not run into any issues yet but I have not had the thing at a high angle. I had heard of people adding an extra qaurt, so I added about 1/2 a quart extra. I figure that it's better to have a little too much than not enough.
I don't think it would be that bad to switch the tires around, if your wheeling for the weekend or camping for a night. If your just going on a day trip it might suck, that's alot of work. You better get yourself a ramp to roll the tires in and out, a nice floor jack (prerunner style with no wheels), an electric impact and maybe a couple beers to recruit help
May works for me, just let me know a couple weeks in advance and we'll try to find the best place to go!
I started on my front bumper, too! I'm really excited with the progress so far, but there's still alot that needs to be done to it. I figured it would be nice to have a good front bumper and winch (if it works) for the early season snow wheeling. We'll see if I'll have it done in time , I'll post pictures of the progress later in the week.
