DIRTCO's 1986 4Runner Build-Up Thread
Old Oct 26, 2008 | 06:40 PM
  #181
DIRTCO's Avatar
And another
Old Oct 26, 2008 | 06:46 PM
  #182
DIRTCO's Avatar
Originally Posted by Hayes
If you come out one day and your 86 is gone...don't look at me
Your the first one I'm going after (I'm just joking, ... but seriously )
Old Oct 26, 2008 | 06:50 PM
  #183
Hayes's Avatar
Originally Posted by DIRTCO
I started up Chihuahua Gulch, had the hubs locked in and shifted into 4 low. Making my way up the trail I noticed that the transmission seemed to be slipping a lot, I hit a rock about 6" tall and the truck didn't want to move. I thought for sure that the tranny gave up the ghost, I was looking for a place to turn around and ran into a couple ATV's that I could hardly get around. After reversing a bit, I started back up the road and what would you know; 4 low for some reason was not working before, but now it was. This was after about 1/4 of a mile and several forward and reverse sections. Once 4 low was really working, the day went pretty smooth, besides for the bad shuttering when it's in reverse and the couple times the tranny seemed to be really slipping.
My transmission does the same thing. I will shift the shifter and it won't go into 4lo. I think it is an electrical issue, because if I shift it into 4lo with the ignition off, it will start in 4lo when I crank her up again. The transfer case is basically a 2 speed electrically shifted transmission, so you should be able to rig something up (that's what I am starting to work on).
Though I plan on running dual cases eventually...
As far as the slipping, have you checked the transmission fluid? Being low on fluid can cause slipping.
Old Oct 26, 2008 | 06:54 PM
  #184
Hayes's Avatar
When I get my heater working again, we should go hit up one of those trails by your place and I can check your rig out in person.
Old Oct 26, 2008 | 07:09 PM
  #185
ScottyC's Avatar
I always tell guys to plate the frame for these sliders. I have seen the side of the frame tweak and compress in that area from a hard hit. Normally I cut diamonds out and weld them on the frame in each location that a tube is. In your case it shouldn't be too bad since you added five arms on each one. But, its still something to think about. I would definitely gusset the top of each tube though.
FWIW, the All-Pro ones are made from .120 wall HREW. They are only 2" longer as well.
Old Oct 26, 2008 | 07:29 PM
  #186
DIRTCO's Avatar
Originally Posted by 86Toyrunna
wow im really glad that i got on here.. i was literaly about to order a set of the TG sliders.. i put a set of them on my brothers 83 he had and i liked them they seemed to have held up ok, he never really droped down on them hard or anything but they sure worked awesome for a lifting point for the hi-lift. yea i really .. really like the all pro sliders.. but my wallet like the TGs. but i will deff measure them out befor i order.. hell i may just make my own. i really cant wait for it to start snowin around here.. we are starting to get some cooler weather, just no moisture when its cold out
For the price it's a good deal. I just want people to know what they are going to get when they buy something. I need to get the 35's on before I make up my mind.
Old Oct 26, 2008 | 08:06 PM
  #187
DIRTCO's Avatar
I agree that extra plates on the frame are always a good idea. On the last truck I did not have plates (with 6 arms), and I did not run into any issues (after MANY hard hits). I actually mushroomed the bottom of the frame in several locations from hard wheeling. I plan on adding 90 degree gussets to the top of the arms if the sliders work well for me. Good info on the All-Pro sliders, as well.
Old Oct 26, 2008 | 08:24 PM
  #188
DIRTCO's Avatar
The last time I checked the fluid it was good. I've never wheeled an auto before, so it takes some getting used to. I also think that there is something wrong with the trans or torque converter, reverse and being stopped in drive causes some pretty bad shuttering (both wheeling and normal driving).
I'd love to show you around, but it better be soon. A couple more weeks and there will be too much snow. Let me know when you can make it up.
Old Oct 26, 2008 | 08:41 PM
  #189
bigarms23's Avatar
btw i got to test out a set of 37procomp extreme mts and they perform great on both rubicon and fordyce i ran them at 9psi so i think youll enjoy them
Old Oct 27, 2008 | 04:44 PM
  #190
DIRTCO's Avatar
Cool, that makes me feel better about getting them. They seemed like a good tire at a good price but I never really heard much about them. I can't wait to try them out
Old Oct 27, 2008 | 08:07 PM
  #191
881stGenRunner's Avatar
i ordered my sliders through WabFab and Brian gets his through 4xInnovations. They are DOM and .120 wall and have a rear kickout as well. Price was very good for what they are...http://www.wabfab.org/products/sliders/sliders.htm
Old Oct 27, 2008 | 09:00 PM
  #192
Hayes's Avatar
hmmm... he uses TG too.
Old Oct 28, 2008 | 05:19 AM
  #193
not his DOM Do-It-Yourself kits. Trail-Gear does not offer DOM sliders. he goes through 4xInnovations...
Old Oct 28, 2008 | 08:20 AM
  #194
Hayes's Avatar
Read the note about 58" sliders
Old Oct 29, 2008 | 05:10 PM
  #195
DIRTCO's Avatar
Mine are definatly DOM, ...it's just cheap DOM
Old Oct 29, 2008 | 08:35 PM
  #196
Hayes's Avatar
I've read a lot of reviews from people who beat on these sliders and have no problems. I will be using scab plates though.
Old Oct 29, 2008 | 08:42 PM
  #197
SpecialScottie's Avatar
You got told
Old Oct 29, 2008 | 08:44 PM
  #198
Hayes's Avatar
Originally Posted by SpecialScottie
You got told
It was a recent change. Marlin used to use DOM but now only uses HREW (last time I checked).
Old Oct 29, 2008 | 08:49 PM
  #199
You got told
No, I did not.
I got my sliders back in April of 2007 way before they made these changes. Brian told me IN PERSON as he was welding them on that mine were made by 4xInnovations.
Old Oct 29, 2008 | 08:51 PM
  #200
Im just playin with ya
