crazytoyota4x4's new 90 4runner build-up thread
Old Jan 19, 2018 | 05:54 AM
  #101
crazytoyota4x4's Avatar
Electric turbo prototype completed.
Old Jan 19, 2018 | 06:02 AM
  #102
Originally Posted by YOUNGIAM
A normally aspirated motor will only suck as much air as it needs has been my experience. I think you are barking up the wrong tree but I would be interested in before and after dyno results. Good luck with the project.
Thanks. I don't know if there's anyone close with a dyno i will have to check. If it works well enough im going to get methanol injection, dyno tune everything. Im not looking to have a race car, just looking for maybe a few extra ponnies. I've looked at a lot of systems out there, the phantom supercharger is a 24v system that I've based my design off of. It will be interesting to see how it all comes together. I have the turbo built, now I'm going to start on the electronics and battery setup. Stay tuned!
Old Jan 23, 2018 | 05:18 AM
  #103
quick video of the first test at half voltage
Old Jan 23, 2018 | 07:08 PM
  #104
YOUNGIAM's Avatar
I seen this dyno comparison and the results where shocking......
Old Jan 24, 2018 | 08:20 AM
  #105
[QUOTE=YOUNGIAM;52388349]I seen this dyno comparison and the results were shocking....
The problem with this design is it is simply an inline fan, that has proven time and again that it just does not work. My design uses a real turbo compressor. The motor I'm using puts out 2800w or about 3.8 hp. My plans are evolving and I am going to build a second 4500w unit. I will post up some videos of the phantom supercharger system I based mine off of.
Old Jan 24, 2018 | 08:24 AM
  #106
Old Jan 24, 2018 | 02:58 PM
  #107
YotaRick27's Avatar
SAS anytime soon?
Old Jan 25, 2018 | 06:50 AM
  #108
Originally Posted by YotaRick27
SAS anytime soon?
I will be doing an sas conversion in the near future. I've decided on a 3 link for the front, just don't know what kit I will be going with yet. I plan to do coilovers in the front. For the rear I'm going to get the front range offroad link kit, and put in fj80 coils and some custom shocks and limit straps. My goal is to stay with 33-35 inch tires with only 2-3 inches of lift over stock, basically where it sits now, just with a bigger tire.
Old Jan 26, 2018 | 04:05 AM
  #109
Testing the supercharger at 24v.
Old Feb 23, 2018 | 05:58 AM
  #110
Old Feb 23, 2018 | 02:42 PM
  #111
YOUNGIAM's Avatar
Have you hooked that thing up yet?
Old Jun 24, 2018 | 01:26 PM
  #112
Old Jun 29, 2018 | 12:28 PM
  #113
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
GoFundMe?
Do we need to do a gofundme thing to pitchin for dyno tests?
BTW, hope you're not more worried about out-running the fires! Stay safe.
Old Sep 29, 2018 | 08:10 AM
  #114
Currently sitting on 33s, after a wash.
Old Oct 1, 2018 | 03:11 AM
  #115
82 solid front axle
Old Oct 1, 2018 | 07:01 AM
  #116
coopster's Avatar
Truck is looking pretty sharp. Don't see a lot of these without huge cancer around those wheel wells! Where'd you get the axle?
Old Oct 1, 2018 | 12:22 PM
  #117
YOUNGIAM's Avatar
How did the turbo charger work out? 4runner is looking sharp.
Old Oct 4, 2018 | 03:35 PM
  #118
I'm still working out the bugs on the electric turbo. I had a clearancing issue that was causing the turbo to lock up. I'm redoing the electronics as well as bigger batteries. Right now everything's kinda on hold with a baby on the way. I will post pics and maybe a new video of the turbo soon.
Old Oct 22, 2018 | 04:28 PM
  #119
I'm going to do a 1 ton y link steering setup. Here's the tie rods part numbers#
es2233l
es2234r x2
es2027l
I picked all 4 up for about 32$ i just need to get threaded adapters and 1.5 x .250 wall dom.
The brackets are for the lower link frame mounts and the bumpstops I had lying around for years.
Old Oct 22, 2018 | 07:34 PM
  #120
MDST's Avatar
5 Year Member
Very nice build!!!
I want to see that turbo in action!
Do you adjust the kickdown cable?? How to do that? I ask you this because I have more cable on the butterfly, it's like loose!
