Chefyota4x4's Ruby R3dRuM to "Suzy-Q the Silverback" Body Swap Thread!
Old Aug 4, 2014 | 12:46 PM
  #381
RBX's Avatar
RBX
Yes try that. U just need the frame level to the ground so wheels could stay on if you had sufficient jack stand height. You would just jack it enough to unload the suspension slightly.
Old Aug 4, 2014 | 12:58 PM
  #382
ChefYota4x4's Avatar
That's the problem. My frame is 26" off the ground.... I'll try to think a way out
Old Aug 4, 2014 | 01:15 PM
  #383
Toyota~Boy's Avatar
With further research I was able to clarify that there is no difference in the bodies of all 1st gen 4runners. With that said this means that the frame mounts are identical on IFS an SA 1st gens.
I compared both my 85 Runner and my 87 pickup and the front mounts all measure to be the same distance an height. Note my 87 is still IFS.
Sounds to me your frame is either bent downward in the front or your body is bent upward.
Try clamping a straight edge to your frame behind the front tires. Hopefully it's long enough to stick out the front. Measure the distance between straight edge and frame. Do same on other side. See what measurements you get compared to someone else
Old Aug 4, 2014 | 01:17 PM
  #384
Again,......... THANKS, RB! I really have trouble finding directions to look on many of my problems, and less and less outreach, both making it difficult. Largely myfault, not having been able to keep things up to date here anymore. Thankfully, this is a large part of your professional experience, so trust me, I realize you are "on to something"!
Old Aug 4, 2014 | 02:13 PM
  #385
Great idea! Thanks buddy!
Old Aug 5, 2014 | 04:23 PM
  #386
RBX's Avatar
RBX
At 26" could you stuff some wood under it to level the frame. Could probably use a jack to level it one the suspension. Would get you close.use the datum sheet I posted and do the math on 26" per point. Really just concentrate one the front. Good luck
Old Aug 6, 2014 | 01:19 AM
  #387
Gotcha! Thanks again bubba!
Old Aug 6, 2014 | 04:07 PM
  #388
Well, got the brand new V6 w/Detroit diff in the rear....
Local couple guys I have seen around here, yet never met in person, saw my request on Instagram for help and came over and spent hours just hanging out and talking truck and helping me hump this much heavier differential up in there. SO COOL OF THEM!
Pulled her out of the garage to prep for surgery! Lol.....
Got her up on stands.....
Yoinked the axles out....
Pulled the very recently done 4 cylinder differential with new / broken in G2 4.88's and premium install kit set up by Jay King at Yotamasters....
Pulled it with the Spartan in mid ratchet on purpose,.....
, and within a quarter inch turn of the pinion it popped right in.... ....
These are so quiet, the gears, and in mint broken in condition.... Going to sell with the Spartan, with the disclaimer that the spartan could be annoying... I would recommend just basically disassembling it reassembling it , which would allow to see if something is out of specs, because it was put together by a member on here a couple years ago, when I grabbed the 430 geared diff with this locker in it..... Honestly think what it is is that the springs are worn out in the Spartans, which makes it ratchet more often. As you can see from the pictures nothing is coming apart and there are no obvious signs of the pin being way out or something like that....
MINT! ....
First, I realized I had hamburger D one of the two longer studs, the one on the bottom around 5:29 on the clock.... Solved!
Draining before swap(4) Hamburgered stud:
Also, I had to do a little bit of filing in order to get socket over the drain bolt.... Got it!
Draining before swap(1):
Draining before swap(2):
I had to do quite a bit of grinding, meaning in four different spots(1:30, 4:30, 7:30 and 10:30) on the proverbial axle to differential meeting point clock! Haha, just to clear the outer bearing adjustment nuts...
Not the friendliest ABS PLUG! Pita, grrr LOL....
New Homie helping me that day, big_bad64 on IG.... And his cousin was there as well....
Hahaha, dude was freaking hilarious, and he cracked me up all day! Lol... I just finished grinding and he insisted to help lift the diff and have me mark stuff as I was grinding after two test fits ( he didn't want me to blow out my back )... VERY cool ppl!
Got it installed....
Draining before swap(5) Hamburgered Zerk:
Called it quits for the night, ....
Got out as soon as I could today and fill it up.....
And now I begin to break them in... ;-)
Old Aug 6, 2014 | 04:09 PM
  #389
Thanks again for the two guys that came over on a moment's notice and the other two, Dat_yota and @3lb00gi3 of IG (Met @3lb00gi3 in person, he was on the Big Bear trip last time, where Garrett rolled the Jeep)..... Really appreciate you guys offering to help!
Draining before swap(6):
Old Aug 6, 2014 | 04:28 PM
  #390
rustED's Avatar
Sound like some cool guys, nice of them to pitch in and help you out, I bet your back was happy the next day, lol! nice work on the diff swap, look forward to hearing how you like it after putting some miles on it! Wish I had the coin, I'd buy your old setup, I'd like to go to 4.88's someday if I ever step up to 37"s...
Old Aug 6, 2014 | 10:51 PM
  #391
Very solid dudes!
Old Aug 7, 2014 | 03:57 AM
  #392
RBX's Avatar
RBX
Did you show them the body mount issue? I quiet rear diff is a must for anyone that drives their rig on the street.
Old Aug 7, 2014 | 08:37 AM
  #393
Yeah, i did, they will be back to bring some mango stands they have. ;-) lol. I have that huge jack too, and couple more stands for the front axle. It's a weird 1/4" of alteration! Haha.
Weird thing I remember; all the 1st gens have 2 longer bolts.... Thought they went in the front. Anyway, curious why, but think they're in the rear, cuz of body thickness... Maybe it was for the front though? The kit seems to have 2 taller bushings, but maybe it's an optical illusion, hehe.
Still have to clear the rod links, heims and arms with some more cutting on the tunnel.....
Also, in the leftovers of body mount stuff, looks like i have 8 less tall bushings not being used. Maybe they need to go in the back 8...
Measurements first, but i also need the bushings out to take a closer look.
Old Aug 8, 2014 | 02:31 AM
  #394
Terrys87's Avatar
I am totally clueless when it comes to gears. I was wondering when you had to do the front end repair due to something being bent if like what Toyota Boy mentioned as well.
Old Aug 8, 2014 | 04:06 AM
  #395
Toyota~Boy's Avatar
I'd like dibs on the 4.88 whatcha asking for it shipped to 25248.
Old Aug 8, 2014 | 12:38 PM
  #396
Not quite sure what ur Askin buddy.....Could you ask again, reworded? Sorry man, having lots of brainfarts today. Lol
Not sure just yet what to ask.... And 3 people locally are interested, so I'll letcha know if the "local pick up" falls through.
Old Aug 8, 2014 | 12:41 PM
  #397
Oopsie
Old Aug 8, 2014 | 12:50 PM
  #398
Stopped by Yotamasters trying to put some miles on the new diff, and cuz the pinion seal must have been damaged during install(Eric said to just come out and they'd slap a new marlin eco-seal)....
Also had the new larger diameter fill plug Journal trail-gear rear armor slapped on....
Thoroughly cleaned up the axle and new v6 differential......
Then, went all hammered black with it all! Lol
NOW, onto the tunnel mod/fabbing, to clear things after removing the body lift!.....PRAY ON THIS! Lol
Old Aug 8, 2014 | 07:47 PM
  #399
kornhuskerwizard's Avatar
Looks sick!!wish I could hang out randomly in front of yotamasters too...
Old Aug 9, 2014 | 10:58 AM
  #400
Thanks buddy! And yeah, they are really NOT stick up the rump type guys, none of them! Eric, the owner, is really a good dude that never pads anything and has great prices!
