Cali '86 RTE 4Runner rebuild...
Old Mar 20, 2018 | 05:35 PM
  #201
old87yota's Avatar
Awesome work so far!
Your 22R-TE has to be the best looking 22R series engine I have seen!
I can't wait to see the frame-off restoration!
Old Mar 20, 2018 | 06:51 PM
  #202
TrailTrek2Fish's Avatar
Thanks old87yota, I appreciate the comments. I'm looking forward to the engine reinstall and future frame-off resto too. It's gonna be a long haul again but it'll definitely be a labor of love.
BTW y'all: In the near future, I'm planning to write up a separate post on my install experience with the LCEngineering CNC Turbo Manifold with theT/2 Flange (1041053) & the LCEngineering CT20 to GT25R Turbo Kit (1071013). It hasn't exactly turned out to be a simple bolt on experience. Don't get me wrong, the products are good but some further augmentation of components were required for it to fit nicely and aesthetically pleasing. I do have OCD so it's not surprising that I wanted it to operate properly and look good, LOL!
Old Mar 21, 2018 | 08:53 AM
  #203
RAD4Runner's Avatar
Wish I Got 22RE Perf. Rebuild
Beautiful work and engine! You're lucky to be so close to 22RE Performance. I wished I had opted for the when I had my engine rebuilt in 2013.
Old Mar 21, 2018 | 08:09 PM
  #204
Greg_Canada's Avatar
Originally Posted by Co_94_PU
89427-35010, discontinued
Good news is you don't need it unless your dash guage is crappy you plan on towing stuff up long hills with the AC running.
It is not discontinued, you can still order from Japan: https://www.megazip.net/zapchasti-dl...?q=89427-35010
Great build so far! How are you going to deal with Smog?
Old Mar 26, 2018 | 12:54 AM
  #205
I am definitely very fortunate for being somewhat near 22REPerformance's location. They're just about 3hrs away from my house.
Thanks Greg_Canada. You are my hero!!! Have you personally ordered from them before? As mentioned before, she would pass a smog sniff test but we're moving to a state that exempts vehicles 24 years or older from smog checks.
Old Mar 30, 2018 | 07:49 PM
  #206
I just finished mounting and plumbing my Derale 15551 oil cooler and oil filter relocation kit. Thankfully I have about 1.75" of space left between the fan and oil cooler. I cut passages on the upper fan shroud for the hoses and I split a section of spare heater hose to shield the oil cooler hoses from the fan shroud's edges but I'm still gonna add door edging to line the shroud'd edges for more protection. I had to use a few XRP fittings to make the hose connections. I fabricated an angle bracket to mount the oil filter unit and I'm using an existing threaded anchor point on the top of the frame rail. But before I set everything in place for hole drilling I made sure the filter was backed out to the last thread to make sure I could actually do filter replacements without having to dismount the bracket in the future.
Old Mar 31, 2018 | 07:36 AM
  #207
swerks's Avatar
where did you get your spark plug wire loom ??
Old Mar 31, 2018 | 07:58 AM
  #208
Whats up swerks. If you're talking about the bracket holding the spark plugs wires up, I fabricated it using a house framing bracket. I used the same framing bracket for the oil filter relocation unit. The funny thing is you're not the first person to ask, LOL!
Old Mar 31, 2018 | 09:11 AM
  #209
swerks's Avatar
I like is simple functional and clean
Old Mar 31, 2018 | 01:02 PM
  #210
Thanks, that's what I was hoping for. I'm currently working on my AC system. Once I get all of the components and o-rings swapped out I'll be completing a heater line flush.
Old Mar 31, 2018 | 02:25 PM
  #211
84 yota dude's Avatar
Clean as usual!
Old Mar 31, 2018 | 03:39 PM
  #212
Thanks bud, I try!
I finally got to remove my dashboard. WOW is it dusty up in there! I'm replacing the AC evaporator and expansion valve. I'll be doing my best to clean it all up in there.
Old Apr 2, 2018 | 05:55 AM
  #213
Those were the days before cabin air filters...ahhh
Old Apr 2, 2018 | 07:45 AM
  #214
. Yeah, I change the cabin filter out on my is300 every 3 months.
I finished cleaning the ducting yesterday. I need to remove the dash supports to get to the heater core and boost ventilator. Gotta get those things cleaned up before I button up the dashboard.
I'm gonna add this screen below the cowl to help prevent leaves from entering into the system in the future.
Old Apr 2, 2018 | 09:20 AM
  #215
RAD4Runner's Avatar
Actually most of that is from poor design of the cowl and its grille.
[QUOTE=TrailTrek2Fish;52394959]:...I'm gonna add this screen below the cowl to help prevent leaves from entering into the system in the future.
[/QUOTE
Yes, This^^^...
However, have you considered either of these? Plastic so no rust....
or...
I used the latter behind my grille.
Old Apr 2, 2018 | 10:29 AM
  #216
Yup, the grill in the photo is made of aluminum. We'll see how well it's done in say... Another 30 years.
Old Apr 2, 2018 | 08:30 PM
  #217
I installed the screen. Looks good! I also added screens to the 2 gaping holes beneath the cowl. I forgot to snap a photo of that, LOL!
Old Apr 2, 2018 | 08:44 PM
  #218
I had to remove the dashboard support in order to get to the ventilation booster and the heater core. I flushed it with CLR and water then used a compressor to dry it out a bit. It also gave me an opportunity to do some clean up beneath the dash area.
Old Apr 3, 2018 | 09:25 PM
  #219
terik's Avatar
does any know the stock ct20 turbo full specs..
Old Apr 3, 2018 | 09:54 PM
  #220
I don't know the specs.
