BowhunterBen_93_pickup
Old Apr 8, 2013 | 07:20 PM
  #41
BowhunterBen's Avatar
I have to go double check in the engine compartment before I can be certain but the previous owner had spliced some wire in to make it longer. Maybe he forgot to put it in the proper spot and was too lazy to do it right?
Old Apr 8, 2013 | 10:25 PM
  #42
SlowlyButSurely's Avatar
I really like how your build is coming along. Im anxious to see it done and driving again. I noticed you guys live in North Idaho. Im in Sandpoint actually and it would be sweet to go wheelin sometime!
Old Apr 9, 2013 | 03:52 PM
  #43
Yeah, once I get the motor broke in and running good I want to go wheeling
Old May 1, 2013 | 09:02 PM
  #44
I haven't been able to get any time to work on the truck since I'm working out of town. But here is some things from a bit ago that I never shared.
I painted up a few more parts.
Here is my block off plate installed.
I still need to tear down my engine again and move that knock sensor wire
Old May 16, 2013 | 08:50 PM
  #45
I finally had a bit of time so I relocated my knock sensor wire.
Old Jun 19, 2013 | 08:47 PM
  #46
I finally got a few evenings to work on the truck...
First two evenings went to detailing in the engine compartment.
Then the final evening I had, I pulled the engine out of the shop and dropped it in the truck. I have four bolts holding it to the tranny and I need to take the wheels off yet to get the top ones in. The hardest part of installing the engine was getting the starter in the right spot. I dread having to ever change a starter on this engine. I had to have the engine lifted an inch or more and swung away from the starter to get it into place.
I'm a little concerned about the exhaust on the passenger side. It looks pretty tight at first glance, but since others have done it, I guess it should work. Here's the look from underneath.
I also noticed that some little wasp like bugs made mud nests in a lot of my tubing in the engine compartment. Now I will have to blow everything out as I hook it up. Frustrating!
Hopefully I can start hooking things up before they make any more.
Old Jul 20, 2013 | 11:18 AM
  #47
I got a good portion of the components on the engine connected. I still have a lot of work before its ready to fire up though.
Old Jul 27, 2013 | 09:15 PM
  #48
I am getting closer to finally finishing this engine replacement. I got the last of the vacuum lines hooked up and installed the alternator and the distributer. I put a new cap and rotor on the distributer. The spark plug hole on #1 cylinder is just out of reach so I built a hose with a latex glove finger taped to the end. Then as I turned over the motor with a wrench I could watch for compression in that cylinder. Worked like a charm. I also flushed the old green coolant out of my overflow bottle. Installed the fan clutch and pulleys. Now I just need to pick up some new belts.
Here is my compression tester...
Old Jul 4, 2014 | 05:20 PM
  #49
In case anyone noticed, I haven't worked on my truck in a year Due to major life changes, which sadly included divorce and selling the house. I bought a new house, which has a small garage for my projects! However, the house is a huge project and it is taking all the time that my job and kids don't. So, to celebrate the 4th of July, I worked on my truck I got the belts on, I don't have a belt tension gauge so I'm a little worried I don't have them right but I hope I'm close.
I went to install the spark plugs and 5 went in really smooth. Number 5 went in half way and got really hard to turn. I went in a bit more but it got really tight and I could still see it wasn't in far enough yet. I backed it out and it stuck when I was almost out, then it spun a helicoil out! Now what? I'm not very happy with the engine builder right now, but I hope it's not a major thing to fix. I really do NOT want to pull the head again!
Old Jul 4, 2014 | 11:01 PM
  #50
I miss-labeled that cylinder number... the bad one is actually #4. Thank God its not on #5! You can not even see the spark plug for #5, I had to install it by feel. I guess if any one was going to have an issue, the #4 is the easiest to access.
Old Jul 5, 2014 | 06:10 AM
  #51
Roark's Avatar
Life works out in the best and worst ways sometimes..
Have you tried contacting the engine builder yet about the busted threads? Considering the engine hasn't even been ran yet, it should be well within the warranty.
Good luck!
Old Jul 5, 2014 | 09:00 AM
  #52
I'm going to contact the engine builder on Monday and see what he wants to do about it. I guess it would have been easier if I had bought local... I guess sometimes you learn the hard way.
Old Jul 29, 2014 | 11:33 AM
  #53
Well I talked to the engine builder and he will fix it if I send him the head. I didn't want to pull it apart again, so I talked to a local guy and he said he won't use a helicoil since they always seem to come out. Now I am depressed! I guess I have to pull the head off again
Old Sep 30, 2014 | 12:09 AM
  #54
This is supposed to fix all my problems...let's hope so. Now I just have to find time to do the work. Name:  E66AA006-CFE2-46C7-BABF-FB728A2204F7.jpg
Old Sep 30, 2014 | 04:10 AM
  #55
kornhuskerwizard's Avatar
Great work man!!!that kit looks nice!!!you'll get it fixed.take your time and DONT drop nothing down the hole!!
Old Sep 30, 2014 | 05:10 PM
  #56
bone collector's Avatar
I used a similar kit to fix a stripped bolt in my cylinder head. worked well. good luck
Old Sep 30, 2014 | 11:29 PM
  #57
Thanks for the encouragement! I'll post how it goes.
Old Oct 19, 2014 | 10:20 PM
  #58
So, after a couple late night work sessions, I finished the spark plug insert.
I was able to borrow a garage for this which was wonderful!
I drilled it out first. Make sure your piston isn't too close to the top before drilling, I had to rotate the engine to get it down.
It instructed me to use grease instead of the tapping fluid, since it was an "in frame" repair.
As you can see in the picture, I should have drilled part way and regreased the bit.
I test fit the insert on the plug prior to drilling and tapping.
The instructions also said to keep tapping in once started and not back and forth like usual. It worked but you can see it was partly dry by the end. I tapped it again after cleaning and regreasing the tap, just to help clean out the threads.
Then you have a greasy mess to clean up. I used little rolled up paper towels with brake cleaner to clean it. I blew air through a small hose stuck down into the cylinder to get the aluminum shavings out. I took my time and hopefully I got everything.
After cleaning...Name:  626FFCB8-352B-4272-8229-55CA7020B7BA_1.jpg
Insert installed Name:  68215033-A3BB-48ED-9823-7A139E80B98E_1.jpg
Happy happy happy Name:  499DF30B-684B-46E5-BFEC-C501FB08DA39_1.jpg
Then I installed the radiator, fan, air filter, air intake piping stuff, and the battery. Name:  86FC78C1-9AB8-4A1A-9DC5-A08BA4587986.jpg
Then I had to watch YouTube videos and run to the store for a remote battery before I was able to figure out how to reset the car alarm so I could actually open the doors without hearing sirens.
I pulled the fuel filter out but I was hoping to use the fuel pump to pump the old gas out of the tank before I install the new one. I turned the key to on but the pump doesn't run, any ideas to run the pump?
Old Oct 20, 2014 | 02:46 AM
  #59
I think you can jump the b+ and FP+ in the diagnosis port and the fuel pump will run.
Old Oct 21, 2014 | 10:15 PM
  #60
Thanks bone collector! I wasn't sure where to find that, but I figured out that its called a data link in the book. Worked very well. I'm still hoping to fire it up before the end of the month.
Last edited by BowhunterBen; Oct 21, 2014 at 10:16 PM. Reason: Unsupported characters
