blakefogt's 1987 4Runner Build-Up Thread
Old Jul 30, 2012 | 09:45 PM
  #541
ToyoTech559's Avatar
it can seize up. burn up the shaft and the housing
i dont know why i keep typing cant and not can. second time i did this
Old Jul 30, 2012 | 09:50 PM
  #542
blakefogt's Avatar
Yea I never thought it would sieze...
Old Jul 30, 2012 | 10:19 PM
  #543
ChefYota4x4's Avatar
Wow, sorry to hear, man! Just like a jealous old girl(pretty or not) to hear the 'PLANS' for SA'Surgery and throw a hissy!!!!!
Hope you can get it out, wrapped up quick and back in and on the road in no time, buddy
Has yer pop's listened to it? What's his thoughts? Seemed like a pretty apt Yotadude, haha.
Old Jul 31, 2012 | 05:00 AM
  #544
blakefogt's Avatar
He basically confirmed my suspicions... Said make sure the fluid levels are good and see what marlin crawler suggests. For now, i just have to deal with a noise.
Old Jul 31, 2012 | 12:25 PM
  #545
Yeah, you know..... when I had to drive my buddies rig out when he BROKE his CV up front on a mine road in the Sierras... he drove mine, and unfortunately knocked the bolt housing good and JUST PERFECTLY with a rock... This backed the screw out just enough to where it rattled close to OUT on this trail down... Didn't notice til getting home, and when I checked, it was VERY low.... The reason I checked is because it was making the STRANGEST SOUND... Lil bit of it was a whine, but more so a sound like..... a bunch of ball bearings in a bag, bouncing around on each other... Or like it would sound if you had a bunch of BB's in your mouth and were sloshing them around... Filled it up and NOT A PEEP since.. BUT, ... lots 4th Synchro in the process, hahaa. Odd thing was.. Before this, it was POPPING OUT OF 4th... After refilling, etc., ....it was NOT GOING INTO 4th,....with the clutch at least, without grinding all the time. Now I just dry shift into 4th every time... not a single grind! hahaha. I tell ya... I'd LOVE to have a brand new TOYOTA BUILT ORIGINAL/OLD-NEW STOCK Trans......... But I just don't think I'm willing to sign over both my children and their children as collateral! hahaha. Gotta be in the 2-3 THOUSAND range, right?
Best wishes, Blake... Sorry man... I hope it doesn't worsen, but at least you have the right job in order to deal with it expeditiously, RIGHT?
Old Jul 31, 2012 | 06:11 PM
  #546
blakefogt's Avatar
That would make me just slightly passive aggressive :p
It's true though, luckily I have tools and knowledge at my disposal.
I just need some time and experience to really make it a fun ordeal
heres a vid to help show the sound... 5th gear you can hear it the best. but if you really listen you here the whine quietly behind the exhaust noise 1,2 and 3rd gear.
http://www.youtube.com/watch?v=iVCLn...1&feature=plcp
Old Jul 31, 2012 | 06:15 PM
  #547
Redeth005's Avatar
Oh yea i hear it toward the end of the video. wow sounds scary
Old Jul 31, 2012 | 06:29 PM
  #548
blakefogt's Avatar
yea had a hard time describing the sound so i figured I'd just share.
if you turn the volume up you can hear noise in the earlier gears, but yea 5th is the most obvious.
Old Jul 31, 2012 | 09:25 PM
  #549
RMP8080's Avatar
My dad always had a saying, drive it when breaks you're know what to fix.....
Do not think that would help, but it's tried and true....
Old Aug 1, 2012 | 02:13 AM
  #550
YEAH, .... that's VERY annoying! hahaha... Sounds a bit ugly there in 5th... Bearing, eh? Makes sense. You'll find out, eventually, now wont ya hahaha.
Old Aug 1, 2012 | 02:26 PM
  #551
Philbert's Avatar
That sounds just like mine did when it kicked the bucket - the "grinding" noise under load, and the lack of noise in 4th (1:1 drive ratio is likely why).
The danger is that, with play in the bearings, your gears are left to their own devices, phsyics, torque, etc - it's a recipe for disaster for the whole transmission.
I drove mine in 4th as long as I could, thinking that would prolong the life (while I shopped for a used tranny), and eventually, 4th would start popping out and I couldn't drive it anymore till the swap.
I replaced mine, then took apart the old broken one to inspect it. The main input shaft bearing was toast - had a TON of play in it.
When shopping for a new (used) tranny, I would hand turn the shaft, in all gears, and listen for a "dragging" noise - that indicated to me bad bearings - the one I found and replaced with had no noise.
I recommend you shop for a used one and replace it soon, then take apart your current one and inspect bearings - your gears may be OK and you could get away with replacing just the bearing?
Or, if Marlin fixes it you're good!
Good luck!
Old Aug 1, 2012 | 04:28 PM
  #552
blakefogt's Avatar
aw poop. come on maaaan. You're supposed to tell me to just cruise with it and not worry about it. It's just a noise... :p dangit.
Old Aug 2, 2012 | 05:44 AM
  #553
liveoffroad's Avatar
i had one blow up on me on the highway, downshifted from 5th to pass somone and thought someone threw some quarters into my trans. now i keep a spare around.
Old Aug 2, 2012 | 07:03 AM
  #554
Redeth005's Avatar
Damn must be nice to be able to keep spare trannys or motors like some of you guys do. That's awesome. lol.
Old Aug 2, 2012 | 07:49 AM
  #555
blakefogt's Avatar
Yea seriously... At least I have my motorcycle so I can get back and forth to work. I'm sourcing out the Toyota pullers so I can get to work... At least ill have a chance to handle the rear main seal, and throw in a clutch too. Sas will have to wait...
Old Aug 2, 2012 | 09:38 AM
  #556
Philbert's Avatar
Well, mine was the "broken" spare, disassebled in several pieces, in my backyard/garage....not that cool, but glad I finally got it to a good home.
I agree, would be great to have space/time/money for a trove of spare Yota parts for when the need arises
Yes, do the rear main and clutch while you're in there - cheap insurance! I did the TG TC mount upgrade too (I have the OEM one if anyone wants to buy it).
Hint: Whatever used tranny you get, make DAMN sure it's sealed right. Mine wasn't, and leaked. I had to remove it again, take apart, and re-seal it with FIPG red (don't use black!).
Good luck bud!
Old Aug 2, 2012 | 10:25 AM
  #557
Redeth005's Avatar
Damn that must have sucked having to bring ot down again after installing lol I haven't had a situation like that yet. But I hope I never do
Old Aug 2, 2012 | 01:36 PM
  #558
Update, Blake? Any decision on whether you're just gonna head in there and swap one in? Etc.? Curious. Best wishes either way.. Hope you can get more out of it. But if not, I hope you catch it in time
Old Aug 2, 2012 | 04:11 PM
  #559
blakefogt's Avatar
so... I'm going to gather all the parts I need... and do it at work :x no help from the pops. should be a blast.
Old Aug 2, 2012 | 10:17 PM
  #560
WEEEEEEEEEE! hahaha... Nah.... do everything to the Micrometer... and you'll be fine! OH YEAH, ..don't forget that lil Continuum Transfunctioner Bearing when you put it all back together! AND DENNNNNNNNNNNNNNNN? lol....
You'll be having a more bearing whine free noise in no time!
