Big Red - 1987 4Runner Build-Up Thread
Old Feb 25, 2012 | 03:17 PM
  #41
jaredbishop's Avatar
Here is 4 hours worth of work. I've got a lot more but there are a few worth showing
Old Feb 25, 2012 | 03:53 PM
  #42
racerflea's Avatar
Yep bad head gasket lol hope the head isnt warpprd!!
Old Feb 25, 2012 | 09:03 PM
  #43
RMP8080's Avatar
Jared glad you get her out, nice work sorry to hear the bad head gasket. But the block looks good.
Old Feb 26, 2012 | 04:32 AM
  #44
I'm not worried too much about the head yet. Ive got a great machinist that specializes in heads. He'll get it looking and working great. One of the cylinder head bolts. I think stripped some threads off the block. Some of the threads was left on the bolt. When I tipped the block upside down and blew some air into the hole a lot of fine dust came out.
Other than that the cylinder walls look and feel very smooth. We made a mistake and forgot to remove the crankshaft bolt so we have to take it off the stand and put the flywheel back on to loosen the bolt. We kind of got in a grove and were moving very fast.
Old Feb 26, 2012 | 08:05 AM
  #45
I've decided that I'm going to need to do some electoral work. Looking at the wiring harness there are lost of wiring looms or wire wraps that have melted away. A few are just dry brittle and cracked. Others are melted down to the wires I need to buy a soldering iron and some and some wire looms to protect the wires from heat and water. Most polyethylene wire loom can't take much than 200º F. I did find some chrome corrugated wire loom that can take up to 1000º F. It is designed for use in engines. About $10-$15 from Cable Ties And More in Canada. No sale tax for us in the States!
Old Feb 26, 2012 | 03:40 PM
  #46
Looking for locker, elocker specifically for my rear axle. I've been doing some reading up on a lot of info. There are lots of axles sold here local and I'm hoping to find one that will work for me.
I'm not sure on the gear ratio bit. How much work is involved in changing the gears, how do I avoid having to do this? I'd love to find a rear axle with elocker that I can just swap out and hook up the electronics for it. I think that may be the easiest for me as I can't do any welding/fabricating or change gear ratios.
Old Feb 26, 2012 | 03:54 PM
  #47
racerflea's Avatar
Maybe a bewer model 4runner will have the ratio you want i know some of them have elockers in them dont know what models or ratioa are in them though
Old Feb 26, 2012 | 07:00 PM
  #48
3rd Gen 4Runners Parts List:
Toyota E-locker
4.56 ratio -> #41110-3D010
4.30 ratio -> #41110-3D080
4.10 ratio -> #41110-3D030
Old Feb 26, 2012 | 07:46 PM
  #49
I found a rear axle with elocker from a 98 Tacoma. It's got a 4:10 gear ration which is what I think my 87 4Runner has. I'm not sure how much work is involved in swapping rear axles.
Old Feb 27, 2012 | 07:45 AM
  #50
racerflea's Avatar
I think the rear locker is ment to engage in 4lothe only in stock configuration but i would wire it to a switch so u could use it in any gear as far as axel swap id swap the ehole housing that way all u moght need to do is weld on some new perches
Old Feb 28, 2012 | 07:40 AM
  #51
2 hours more of work tonight and I finally broke everything down and took a lot of parts over to Clegg's to be cleaned and machined. I should know tomorrow what needs replacing and what I can reuse. He looking over my camshaft real quick, he noticed some excessive ware marks and said I many want to just replace it.
I'll be I've got about 10 pounds of grease build up on the block alone.
Old Feb 28, 2012 | 08:53 AM
  #52
I use to own a 99 4Runner with lockers. You are correct in that it has to be 4 low. I believe that if you go over 5mph it will disengage. I don't see much use for lockers it if I'm going very fast. I guess if I was in snow or mud it could be help full in a higher gear. I'll end up wiring it to run in any gear.
Old Feb 28, 2012 | 09:02 AM
  #53
racerflea's Avatar
Yeah not going over 5 in the mud does nothing but dig ur trucks grave... specially in the south
Last edited by racerflea; Feb 28, 2012 at 10:29 AM. Reason: dumb phone putsphone wrong ˟˟˟˟ in
Old Feb 28, 2012 | 09:45 AM
  #54
Terrys87's Avatar
I dont know much about lockers so cant help you there. Making great progress on tear down.
Old Feb 28, 2012 | 10:49 AM
  #55
AHHH
Clegg's called not good news:
Cylinder head is cracked New head $305
Block needs a shave and bored out $295
Master rebuild kit $250
Old Feb 28, 2012 | 06:59 PM
  #56
racerflea's Avatar
Yikes!!!
Old Mar 1, 2012 | 07:11 AM
  #57
I gave my truck and optical lift by removing the side bars. I'll put sliders on latter. I've also take some measurements for the wire loom. You can see the melted plastic. I'll be replacing it with high temp wire looms that are good up to 1000ºF
Old Mar 1, 2012 | 07:33 AM
  #58
wannaBwheelin''s Avatar
About the Elocker, If you do the Grey wire mod it will allow the locker to be engaged at any time you press the button. Ive read on here in a couple places of how quick and easy this is to do to have your locker work both in 4wd and even 2wd
Old Mar 1, 2012 | 07:39 AM
  #59
racerflea's Avatar
I dont think 87s had a wire in the harness for the elocker lol
Old Mar 1, 2012 | 08:09 AM
  #60
Here is the write up I found on how to set up the elocker. I don't have the elocker yet, I hope to get is sometime next week.
http://www.4x4wire.com/toyota/tech/electric_locker/
