8T8 4RUNNER's 1988 4Runner Build-Up Thread
Old Mar 15, 2011 | 04:21 PM
  #681
92 TOY's Avatar
degreased massively......it's Grabber Green engine paint
Old Mar 15, 2011 | 05:37 PM
  #682
ChefYota4x4's Avatar
Ahhh, ok. Grabber Green ,...... and I've done Hugger Orange before. Cool. Well, nice paint job. Is that the shape of the V6 Pan?
Old Mar 15, 2011 | 09:30 PM
  #683
86 TOY's Avatar
Haven't posted in a while, but been following...great to see it's coming along! Can't wait to see this come together when the weather breaks! Great job Joe!
Old Mar 16, 2011 | 02:06 AM
  #684
92 TOY's Avatar
thanks guys.
needed to get the pressure washer connected for another purpose, but getting the pan off has been something we've been wanting to do. Joe is happy to finally be starting to work on it again. although, like i said, it snowed on us for about 10 minutes while i was scrubbing.
yeah the pan has some funky shapes to it....but it's in great shape.
when we took the pan down, he siphon still had oil in it.....nice golden oil too, nice and clean but there was some oil in the pan that was lumpy and like sludge, guess it was stuff that never made it out of the pan. ever.
Old Mar 16, 2011 | 06:42 AM
  #685
Lumpy's Avatar
Nice work Joe!!! and I guess I have to give a props to the old man as well. Keep him close Joe you'll see that he's a good helper and tool hander.
Hahahaha.
Old Mar 16, 2011 | 06:45 AM
  #686
xxxtreme22r's Avatar
I guess that green will grow on me.
  #687
92 TOY's Avatar
hahahahahah
ya know...it's killing me. i want to go out there and do this and that and the other thing, but Joe knows this is his build and he does the wrenching.
i was parts cleaner and painter yesterday. I only helped with 1 bolt for the oil pump.
Old Mar 16, 2011 | 06:47 AM
  #688
92 TOY's Avatar
it's certainly a better GREEN in person. just like my RED on my truck looking ORANGE on the computer, this is looking quite light and "minty" in the pictures.
Old Mar 16, 2011 | 01:54 PM
  #689
92 TOY's Avatar
so today's episode was to try to do 3 things.
1)get the "baffle" plate off (just above the oil pan and between it and the crank)
2)get the oil pump off
3)get the water pump off
we, or should i say, Joe, accomplished all three.I didn't turn a wrench. I did, however have to help getting the crank timing gear off. was on there and didn't want to budge. we used the pry-areas like in the FSM and PB Blaster and on and on and finally got it. That task took the most time.
here's the baffle plate
here's what we had to wiggle off
and with it and the oil pump removed
and the "why do you keep taking pictures of me?" picture. ANSWER: because I had nothing else to do.
the last picture of it wearing it's old (but kinda new) water pump
and a FULL FRONTAL NUDITY shot
That's it for today. have to go to a school board meeting. gotta shower 1st though.
Old Mar 17, 2011 | 02:41 AM
  #690
92 TOY's Avatar
so, pretty much dodged a bullet with work, so now i am STILL off today....almost wasn't.
anyway, the next logical step / project, is to do the rear-main seal. had been wondering if that was something we should do while the oil pan is off. the answer is YES. when the Haynes book says (and I quote page 2B-13) "if you want to take the chance......." regarding doing it with the pan and retainer in place. so, no , I don't want to "take a chance".
so, today, after Joe gets home from school, we will probably put the motor back on the hoist so we can separate it from the motor stand and do the rear main seal.
since I am only the helper on this build, I can do the clean-up work and scrape and acetone the front of the block to make a good sealing surface for both the water pump and the oil pump.
one area of concern with the oil pump is a small o-ring seal that either went flying somewhere(doubt it) or did not come free. I don't see it on the oil pump itself, but my old eyeballs think it may still be on the block. i'm going to have to confirm this but i believe there is supposed to be some sort of indent where it mates up on the block and I cant quite tell if it's there or not (my work light bulb broke....and let me say, the new fangled light bulbs are kinda a pain in the butt in those when it's cold and they certainly aren't intended to be knocked around.....so i have to see if i have a normal light bulb left in this house to exchange into it)
I will also clean up the baffle plate and the mounting area on the block for it and the pan.
definitely need to use more FIPG on this motor than my own motor because as far as i can tell, right now i need it for, the oil pump (no gasket, just FIPG), the retaining plate for the rear main, the baffle plate (which gets sandwiched in between the oil pan and the block and is ONLY held on by FIPG)and the oil pan. i will also need some down the road for the valve cover gaskets.
that is all.
c-ya's
Old Mar 17, 2011 | 05:25 AM
  #691
92 TOY's Avatar
do you like guessing in games?? me neither.
but this game is called "Lets figure out what all these unlabeled things go to."
needed to find the gasket that goes from the oil pump to the siphon.
the choices:
the winner:
need an O-ring for the oil-pump-to-block connection
my choices (metal ones are here too because there is one metallic one with a BLUE coating on it....again, don't know why)
bottom right are the 2 most likely choices (rubber one on left, BLUE metal one on right)....my vote is for the rubber one
and then we have the LABELED front seal for the oil pump.......1 I had ordered on my own and actually have a 2nd one that came with the gasket kit (guess my OCD missed that one)
Old Mar 17, 2011 | 05:35 AM
  #692
I am only guessing here, but my guess on the copper metal o-ring would be some sort of fuel line bango bolt. Then your 6 o-rings on the right side should be for maybe the intake plenum somewhere.
One of those gaskets in the top is probably gonna be for the oil pickup tube my guess there is the top left one.
Let's see if I am right. Can't really help out on this one.
Better label that photo as you go. Maybe arrange them exactly how you have them on the carpet onto cardboard and superglue them down so they don't move.
Old Mar 17, 2011 | 05:44 AM
  #693
92 TOY's Avatar
my guesses are:
#1 EGR
#2 Cold start Injector
#3 ___________ (probably something fuel)
#4 ___________ (probably something cooling system related)
#5 Oil Pump to siphon (and it HAS to be, as it is the only one that fit correctly)
Old Mar 17, 2011 | 06:16 AM
  #694
Lumpy's Avatar
You better quit going through his goody bags!!! I'm telling Joe you're playing around!!!
Old Mar 17, 2011 | 06:34 AM
  #695
92 TOY's Avatar
there's enough for everyone....don't worry
Old Mar 17, 2011 | 12:44 PM
  #696
92 TOY's Avatar
Ok....i did some work until Joe got home, then he took over.
as I've said before, make a list and expect to get about 1/2 of it done. so it was.
as far as what got done:
cleaned the baffle plate.....did NOT scrub it and pressure wash it as I was going to. I had left it outside last night and it got frosted and I notice a little rusty buildup on some spots....so I figure that if frost did that, pressure washing would do worse. so i wiped it all down, then used acetone on the gasket surfaces (in this case, both sides of the plate)
cleaned the font of the block with acetone and razor blade and blew it off with compressed air (what a GREAT toy).
painted the water pump........silver....go figure...it's actually the ALUMINUM colored engine paint. thermostat housing RED (as per Joe). bolts cleansed, degreased, scrubbed and painted.
work station 1
work station 2
and, installed
Old Mar 17, 2011 | 12:58 PM
  #697
Lumpy's Avatar
All this 3.0 stuff is making me want to play with the runner again!!!
Old Mar 17, 2011 | 01:01 PM
  #698
Didn't Joe say he wanted the water pump green?
Old Mar 17, 2011 | 01:05 PM
  #699
92 TOY's Avatar
nah. he said "too much green" when I suggested it.
LUMPY...I gotta tell ya, it's probably because I'm working on the motor out of the vehicle, but this has been pretty OK so far. of course, I've only done easy stuff so far.the water pump was the 1st new thing to be put on.
up next....the rear main seal.
still need to get that steamer to clean the engine bay.
Old Mar 17, 2011 | 01:37 PM
  #700
92 TOY's Avatar
OK...1 more pic. cuz, I'm out of time allotted to do anything fun.
Old versus new (and painted)
