4RunnerKid's 1993 4Runner Build-Up Thread
Old Jan 13, 2007 | 12:18 PM
  #61
-TheBandit-'s Avatar
Originally Posted by 4RunnerKid
the axle is going back 1.5" or so. and i'm using 6" all pro springs with 14" shocks.
Only 1.5"? Go more! Give yourself enough room for 4Ds.
Did you see the cover 'runner in the December issue of Peterson's? That my friend is where you should be heading! Four tube doors and a chop top looks sick and you can almost mistake it for a 1st gen.
Old Jan 16, 2007 | 02:57 PM
  #62
99_Runner's Avatar
Looking really good. Can't wait to see it after the rear swap and the 37's. Did you ever get the longfields put in the front so you aren't snapping stockfields any more?
Old Jan 17, 2007 | 01:28 PM
  #63
Get that thing sprung so we can wheel! Are you gonna build a tractionbar? Did you take any pictures of your front D-shaft? Longfields for the front?
Old Jan 18, 2007 | 10:49 AM
  #64
idayota's Avatar
i'd be really interested in some pictures of your front driveshaft, too. the build looks good. keep the pictures/work coming!
Old Jan 18, 2007 | 02:28 PM
  #65
4RunnerKid's Avatar
i have some pics of the d-shaft, but my computer is down at the moment. i'll see if i can upload them on my roomie's computer. as for the birf upgrade, i'll be ordering bellfields when i get paid in a couple days. oh, and i'll be sticking with the 35s for a while. either 37s or 40s once these wear out...
Old Jan 21, 2007 | 01:43 PM
  #66
4RunnerKid's Avatar
finally got my computer working... so d-shaft pics are up:
Old Jan 21, 2007 | 03:06 PM
  #67
AH64ID's Avatar
Is that full droop? Thats a steep angle...
Old Jan 21, 2007 | 06:09 PM
  #68
4RunnerKid's Avatar
thats drooped out a little, but not full droop. i haven't had any problems with it binding up at droop...
Old Jan 21, 2007 | 09:26 PM
  #69
Flygtenstein's Avatar
How much does that shaft hate you?
Low pinion, square and single cased. 4wd over 2MPH must be sweet.
That being said, I caught hell picking up a CV core to make a square trail spare front.
Old Jan 22, 2007 | 08:31 AM
  #70
Shaft looks good. Did you use seamed or DOM tubing?
Old Jan 22, 2007 | 08:57 AM
  #71
Blizzard's Avatar
Arf... Makes me want to begin swaping my truck, but I've no money...
Why didn't you use your stock front driveshaft for the square mod? At least it's a CV...
David
Old Jan 22, 2007 | 10:06 AM
  #72
Looking at this again, I am amazed.
You have 5" front springs with real shackles, right?
With as much axle wrap as I get up front, and my modest springs and shackles, I am worried about binding a dual case CV'd shaft.
I don't think you can put a CV on that though and still get enough travel. It is just too short.
Old Jan 22, 2007 | 10:20 AM
  #73
Marc P's Avatar
And I thought my front d.s angle was bad....I run a lengthened driveshaft from an 85...CV on the t-case side...no vibes until 30mph
Old Jan 22, 2007 | 01:30 PM
  #74
4RunnerKid's Avatar
the shaft kinda works. it's loud, vibrates a lot, and is definitely short. my truck is usually sitting about an inch off the bumpstops. if you look at the pics, it's probably a good 4" above (doing leaf swap still). i'd say it's only slightly worse than Marc's angle. next time i take it out i'll see if i can get some pics at droop. as far as i know, it doesn't bind up... the High Angle flange is pretty well clearanced. i'll eventually end up running a round tube shaft once i'm dual-cased, but that'll be a while.
David, a stock CV just didn't have the clearance i needed.
Clint, it's actually seemless 2" and seamed 2.5" due to certain reasons...
Adrian, i am running 5" Trail-Gear springs woth 6" eye-to-eye shackles. i'll be swapping in the TG HD springs once the rear swap is done. hopefully that'll help with my axle wrap. the regular 5" TG springs are just too damn soft, especially for a V6 rig.
Old Jan 22, 2007 | 02:55 PM
  #75
Yeah, that is a lot more spring and shackle than I've got.
Travel in the CV's IFS to solid axle is pretty amazing. My front uses a goodly chunk of a stock solid axle CV. My rear is an IFS.
Any spring that flexes with a darn is going to wrap up there, being a steering axle isn't helping. This is even worse with a 3.4 and duals. I suppose that means links are only a matter of time. I doubt you will be pleased with anything stiffer for wrap.
Old Jan 23, 2007 | 04:16 AM
  #76
Ganoid's Avatar
I had a terrible angle as well using a modified 85 CV shaft with the TG 12" spline section (spin balanced). I took my truck into the local alignment shop and had them check the caster to see if I could rotate the axle forward raising the diff flange. The shop said I should be in the 1.5* range for caster and I was sitting at 5.5* with the TG 4" IFS elim kit. I added a 4* shim to roll the axle forward and reduce the caster this also improved my Drive shaft angle dramatically. I have no wobbles or any other goofy side affects due to caster and I have had my x-cab up to 95 Mph on the 35's in 2wd with the 1.5* caster setting. You can start to feel the front D-shaft once you get over 45-50 mph in 4wd but that only happens on mountain passes in the snow. I have no idea what the 5" springs do to the caster angle but I'm sure it can be improved.
Old Jan 23, 2007 | 06:59 PM
  #77
4RunnerKid's Avatar
yeah, i've been thinking about looking into shims... i'll have to have my caster checked one of these days.
Old Jan 26, 2007 | 11:25 PM
  #78
4RunnerKid's Avatar
well, all that's left is to weld the shackle hangers to the frame, mount shocks somehow, and lengthen the d-shaft... pics tomorrow.
Old Jan 28, 2007 | 02:57 AM
  #79
4RunnerKid's Avatar
Old Jan 28, 2007 | 10:10 AM
  #80
Blizzard's Avatar
Wow Mike! Your bumper is way more nice now with the hoops.
Wanting to see the finished truck, I'll be swapping the rear too.
David
