4RunnerKid's 1993 4Runner Build-Up Thread
Old May 4, 2008 | 04:42 PM
  #261
4RunnerKid's Avatar
ask and you shall receive...
before with 35s:
now with 37s:
Old May 4, 2008 | 04:44 PM
  #262
LTrunner's Avatar
....mmmmm beefy
Old May 5, 2008 | 10:31 AM
  #263
YeloSub7's Avatar
NICE! Looks like that rear is gonna rub when its all flexy, hows it stuff?
Old May 5, 2008 | 10:38 AM
  #264
YeloSub7's Avatar
Old May 5, 2008 | 11:20 AM
  #265
4RunnerKid's Avatar
haven't flexed it out yet, so we'll see... i plan on bring the axle forward an inch on the perches, so that should help a little. more cutting might be in order.
Old May 5, 2008 | 12:57 PM
  #266
yotasavg's Avatar
wow great pics from the hammers.........once college is done.....i can't wait!
Old May 5, 2008 | 01:09 PM
  #267
UKMyers's Avatar
Mike I moved my axle forward an inch and I still rub in the back of the rear fenders at full stuff and thats with a 2" BL. I cut the seam all the way out too.
Old May 11, 2008 | 03:45 PM
  #268
4RunnerKid's Avatar
well if cutting was necessary before... it's even more necessary now.
redid the front leaf pack this weekend. ended up bringing the front down 2" or so, which was my goal. spring rate feels pretty good so far too, maybe a little softer than before. shackle angle is pretty lazy now, so the front hanger might need to be cut off and moved forward... leaving it for now though. leaf pack goes as follows:
TG 5" HD 1st
TG 5" HD 2nd
Toyota rear 1st, cut down
Toyota rear 2nd, cut down
TG 5" HD 5th
TG 5" HD 6th
before:
after:
also added some D-rings to the front bumper a few weeks back...
next weekend that rear gets some attention...
Old May 11, 2008 | 11:59 PM
  #269
-TheBandit-'s Avatar
Those tires are lookin' right at home. Bring out the sawzall!
Old May 12, 2008 | 11:42 AM
  #270
4RunnerKid's Avatar
thanks Clint. i'm pretty happy with how it sits now. i'll be cutting a little, but less than i had originally thought...
Old May 12, 2008 | 12:29 PM
  #271
YeloSub7's Avatar
sits perfectly now! I like it. What is your axle to fender measurements now? Or top of rim to fender...
Old May 17, 2008 | 04:47 PM
  #272
4RunnerKid's Avatar
i'll try and get those measurements for you ASAP. as for frame height, i'm at 25.5" now. pulled a leaf out of the rear pack today and pulled the axle forward on the perches. wheelbase is now right around 107"... next is to add more bleed to the Foxes and weld on the new lower shock mounts. then next weekend i'll be taking it to the Con.
i'll try and get pics up of the new stance tomorrow.
Old May 18, 2008 | 05:33 PM
  #273
YeloSub7's Avatar
Great! Lookin good... wish my runner was done for the con this weekend
Old May 18, 2008 | 07:59 PM
  #274
4RunnerKid's Avatar
the new stance...
(sorry for the dark pics)
need to take care of bumpstops at some point, but for now they'll do. just need to do some preventative maintenance and install my new rock lights and this thing is ready for the Con...
Old May 27, 2008 | 01:09 PM
  #275
4RunnerKid's Avatar
the new lower rear shock mounts:
(don't mind the paint, my friend's doing)
wheeled part of the con this past weekend. froze our asses off the whole time, had a couple trucks break in the group, was stuck there an extra day... had fun though. a few pics i took:
hopefully more show up... if they do i'll get those posted up.
Old May 27, 2008 | 06:12 PM
  #276
fillsrunner4's Avatar
Dude I wish I could wheel out by you. The trails look amazing compared to here in Washington. Ill have to make it out there soon someday.
Time to cut those fenders I bet those 37's rub hella. I cut off 1" off the rear then tacked the body back together and bent the fender lip in to the same 90Degree angle as before with a sledge to hold its shape better. I flexed out with no rub front nor back this last weekend perfectly.
Looks great
Old May 28, 2008 | 11:47 AM
  #277
4RunnerKid's Avatar
thanks man. you should definitely try to make it out here one of these days... hopefully before all the trails are closed. if you do, hit me up and we'll plan a trip.
the 37s only rub up front, so either some firewall work is in order or the front hanger is getting moved forward a bit... or both. 2wd oil pan is on the to-do list as well... the rear tucks pretty good as is, but it'll tuck even more once i redo the bumpstops, hopefully this weekend.
Old May 28, 2008 | 12:20 PM
  #278
Ya I only had minimal front rubbing on the body. I still need to add some bumpstops and also I plan to move the axle farther forward and same with the steeringbox to accomidate. I think im pretty much good with the rear now as it didnt rub at all after i cut it up. My 35's fit perfectly before but the 37's would have had major rubbing if I didnt cut them.
Looks good and Ill be sure to hit you up if I make it out there
Old Jun 7, 2008 | 07:59 PM
  #279
4RunnerKid's Avatar
only update i have...
picked up another tailgate at the junkyards yesterday and got it installed today though.
Old Jun 8, 2008 | 02:49 AM
  #280
Blizzard's Avatar
What happened, Mike? Glad to hear you're in the way of repairing it.
David
