312necro213's 1990 4Runner Build-Up Thread
Old Apr 22, 2008 | 07:09 PM
  #61
312necro213's Avatar
Well, Cleared all the plastic in the back and removed the head board in preperation for the chop. I suspect it will happen sometime this week. I will have more pictures tomorrow.
Old Apr 22, 2008 | 10:38 PM
  #62
machabees's Avatar
Idea for where to mount my fire extinguisher. officially stolen from Necro.
Old Apr 23, 2008 | 06:28 PM
  #63
haha its all good thats what the forums are for
Old Apr 24, 2008 | 08:55 PM
  #64
more pictures tomorrow removed all the glass. Chopping it tomorrow.
Old Apr 26, 2008 | 04:06 PM
  #65
Moved it inside the shop and took out all the glass getting really close to chopping this. The roof will be off this week.
Old Apr 28, 2008 | 09:01 PM
  #66
The chop is done... now to repair the damage :)
Kinda pushing forward... nobody is really responding to my posts but I'll keep posting pictures for those that are looking... Chopped the back off today still need to take a couple more inches off not satisfied with how small the bed is going to be at the moment. Going to put the old rear window back on for the rear window and that way I can retain my rear window defogger as well. I am also going to put back the spoiler to keep the back window a little cleaner on the trails. Anyways heres the pictures...
Old Apr 29, 2008 | 09:07 AM
  #67
artinge3's Avatar
Sooooooo.....what's happening now???? where is, what's it look like??? head gasket done?
Old Apr 29, 2008 | 10:23 AM
  #68
TFJ-4runner's Avatar
Nice work man it will be a beast when your done
Old Apr 29, 2008 | 01:22 PM
  #69
barrolde's Avatar
You are a ninja!
Old Apr 29, 2008 | 04:22 PM
  #70
I welded in the reinforcements for the back to attach to today, planning on putting the old window back in and sealing it up and holding the bottom in with some angle iron... then using the sheet metal from the roof piece that i Removed and I am going to use that for the lower part of the window to the bed. Probably be done and ready to paint in another 2 weeks. Ill post more pictures tonight when I get home.
Old Apr 29, 2008 | 09:17 PM
  #71
New mirrors... black to get rid of all the chrome... didn't feel like painting the old ones...
Before:
After:
Few more pictures of the chop...
Old Apr 29, 2008 | 09:22 PM
  #72
Dare44's Avatar
looking good, should be a really fun time getting everything lined back up
Old Apr 30, 2008 | 10:03 AM
  #73
Yea I dont think it will be that big of an issue.
Old Apr 30, 2008 | 11:18 AM
  #74
Ardent's Avatar
What did you use to remove the stripes? I'd like to get rid of what's left of mine...
Old Apr 30, 2008 | 09:24 PM
  #75
They make these eraser wheels that work really well, you can get them at a local body shop, couldn't find one at an autozone or anything like that. Im sure you can find them online, hooks into a drill. You could also use a hair dryer heat them up and peel them off and then work the glue off with a very mild solution like soapy water or something like goo gone. I used laquer thinner but it does mess with the clear coat if you use to much.
Old Apr 30, 2008 | 09:50 PM
  #76
Jay351's Avatar
Can you show me how you attached your emblems to your new grill? I want to do the same mod (different mesh mind you) and Im drawing a blank there.
Old Apr 30, 2008 | 10:04 PM
  #77
JonnyBoy's Avatar
Hey, not to make ya do more work, but I'm pretty sure one of your cam sprockets is on backwards, if they're still like they are in the picture. Ya should have one on so that the belt can't rub against the engine or the timing cover. The project rocks though!
Old May 1, 2008 | 09:25 PM
  #78
I just put a small piece of metal behind the mesh and put the screw through it and the mesh and into the emblem. Holds on well but this thin mesh doesn't hold up well I am going to upgrade to the mesh you often see on the headache racks. And thankyou for that tip on the timing sprockets, I have to take apart a lot of the engine again to put my headers on whenever they get here so I will do that then, on the upside I got the back end of the roof welded on today, despite me trying to be really careful of the heat, it warped so I will have to fiberglass it and sand it smooth... Luckily it doesn't do that wierd bend thing, its just permanently bent and won't move... I will post pictures tomorrow forgot the camera at the gf's house.
Old May 6, 2008 | 09:36 PM
  #79
Some more pictures back is welded in and the window is in its permanent position time to work the sheet metal... : /
Old May 6, 2008 | 10:17 PM
  #80
shaw_j's Avatar
Quite the impressive build you have going here!
I wish my high school had a legit auto program...
