312necro213's 1990 4Runner Build-Up Thread
Old Mar 3, 2008 | 09:46 PM
312necro213's Avatar
hmmm alright I will get to work on that tomorrow after I fail with these magnets lol.
Old Mar 3, 2008 | 11:22 PM
CC_yota's Avatar
I was looking on the Mitchell OnDemand program at school the other day on how to drop the oil pan because my gasket is shot.
It said you ave to remove the front diff cross member, lower the diff, and then drop the pan. With everything else that has to come out to do so it estimated, I think, 4.5 hrs. for R&R.
Old Mar 4, 2008 | 04:21 PM
Well in an hour I dropped the entire diff today, Perhaps I will find my socket tomorrow, Thanks for the info though I might end up paying a shop to finish this, because I have no clue where to even start with timing >.>, I know you set the engine to top dead center, and the cap and rotor to the number one firing position but the part with the cams is where I get lost :x
Old Mar 4, 2008 | 06:46 PM
I can't find any specific thread on exactly how to do this... anyone help?
Old Mar 4, 2008 | 08:14 PM
  #25
Well I guess Ill just keep researching the timing thing, I have stuff to do for now until the timing becomes more of an issue, Dare44 showed me a thread on pirate that looks exactly like the 4runner I want to build so I have some basis now im not just crazy...
http://www.pirate4x4.com/forum/showt...t=mossy&page=9
Old Mar 5, 2008 | 02:55 PM
  #26
gte718p's Avatar
You happen to know what gears you have in that front end. I'm in monterey I might be willing to take it off your hands?
Old Mar 6, 2008 | 01:14 PM
  #27
I have no idea what gearing it is, I also won't be selling it for quite some time, a couple months or so, I need to buy the wabfab kit and then I can sell the axle with the rebuild kit.
Old Mar 6, 2008 | 08:47 PM
  #28
Dropped my oil pan to get that socket today, pictures of dropping the diff as well, I am painting my oil pan tomorrow so we will see how that comes out
As you can see in the pictures the coolant is all in the oil from the blown head gasket... Im actually glad I had to drop the oil pan... probably good to clean it all out.
Old Mar 8, 2008 | 09:07 PM
  #29
I will be finishing my grill finally tomorrow, gonna get the mesh and paint to finish it, hopefully it will look good, Ill put it in on monday.
Edit: Oh and I finished painting my oil pan just forgot to get some pictures of it, Ill post the pictures monday, hopefully my oil pan will go on monday. Anyone know how to set my cams to proper timing for tdc?
Old Mar 9, 2008 | 04:08 AM
  #30
91 4Runner's Avatar
The question is, did you find the socket?
Old Mar 9, 2008 | 04:54 AM
  #31
SEAIRESCUE's Avatar
Cam arrows go straight up...you will see them. Crank has mark that aligns with a mark on oil pump. Search this site for photos.
Hope the blown gasket, and coolant, did not trash any bearings like it did to my 3.0. Did you run engine before tear down? Check each piston to make sure none have been hitting the head. When rod bearings go, the slack allows the pistons to slap the head. Unfortunate pi$$ poor design by toyota, again. The stupid main cradle makes checking any of the bearings impossible. Another stupid design by Toyota. I strongly recommend replacing the oil pump now. Can't do it later without dropping the pan, another stupid toyota design.
Good job with the work so far....you are hard core.
My $0.02
Old Mar 9, 2008 | 11:30 AM
  #32
hmm how hard is the oil pump install... scratch that Ill do some searching thanks for the advice I really appreciate it and thanks, I am hoping to do a lot more work then I have listed really, because I am looking at a lot of interior mods as well but those can be done at my house without the use of the shop so they just aren't listed yet
Edit: and yes I found the culprit socket!
Old Mar 9, 2008 | 11:42 AM
  #33
foot0069's Avatar
Have you seen this yet? It should help you a lot. Good luck. Ambitious project you have going there.
Jim
http://personal.utulsa.edu/~nathan-b...fsm/index.html
Old Mar 9, 2008 | 12:01 PM
  #34
Yea I have a pocket pc so its on my phone but i find its a little hard to use and not because its on my phone...
Old Mar 9, 2008 | 12:36 PM
  #35
SEAIRESCUE's Avatar
You should strain what comes out of the pan through some window screen material to see what you catch. I see a lot of reflective surfaces in your photos of the pan. I would hate, and you would too, to find out that the bottom end is bad after engine reassembly and initial firing. Nothing worse than doing it twice. If you got the time an a few bucks, take that block to a shop, let them clean it and you may be able to knurl the pistons, turn the crank and install some Hastings iron rings and call it an overhaul. I've done it for years with excellent results when a shop does the work.
My $0.02
Old Mar 9, 2008 | 10:14 PM
  #36
I might end up doing that.... but thats more money... and I didn't want to unbolt it from the transmission...
Old Mar 10, 2008 | 04:52 PM
  #37
I finished painting my grill today... Ill post up pictures once I finish putting it back together.
Old Mar 10, 2008 | 07:13 PM
  #38
Heres the pictures of the painted grill, Toyota and V-6 are taped up I am deciding whether to leave them chrome, which would make them the only chrome on the truck, or to paint them white to continue the color scheme. Probably decide weeks from now on that.
Old Mar 10, 2008 | 07:47 PM
  #39
Heres the grill finished just peeled the tape off the toyota and V-6 emblems I think it actually looks really good chrome... And I HATE chrome... Might leave it or tempt fate... heres the pictures, Ill install it in the morning.
Ill take pictures installed in the morning.
Old Mar 10, 2008 | 08:16 PM
  #40
904_runner's Avatar
Looks good!
What tires and size do you plan on running after your done?
After my lift i just plan on getting some truxus, $136 a tire for 33's.
Seems like a good deal to me!
