1991 ext cab build
Old Jun 24, 2012 | 09:33 PM
  #121
RMP8080's Avatar
Dam that was fast....
Old Jun 24, 2012 | 10:41 PM
  #122
runs-on-4's Avatar
didnt have to much time,, i get 4 day weekends every other week. and i have plans on the next 3 4 day weekends.
still gotta move the steering box foward hopefully i can figure that part out, doing lots of research tonight, also ive decided to move the hanger foward 3/4" to fix that shackel angel
also gotta look into swapping in my ifs calipers my SA ones are seized cant find a thread on doing that swap though
Old Jun 24, 2012 | 11:42 PM
  #123
rustED's Avatar
That was fast! Looking good. Are you talking about swapping the ifs wheel hubs, and calipers, and using landcruiser rotors? That's what I did on mine to make the front axel the same width as the ifs rear, and to upgrade the brakes to the slotted rotors.
Old Jun 25, 2012 | 12:11 AM
  #124
runs-on-4's Avatar
im not sure yet, do you know if i can just put on my ifs calipers the sa ones dont work,
Old Jun 25, 2012 | 07:12 AM
  #125
rustED's Avatar
I've never tried it, the only difference in the two is just the ifs one is wider, it should work. Otherwise the swap I mentioned above you would just need the LC rotors ($50 at O'reilly's for the pair)then you just reuse the ifs wheel hubs and calipers. You have to drill the ifs hub bolt pattern into the new LC rotors, but its pretty easy, and you'd have to drill out the mounting holes in the calipers and the knuckles to 1/2" diameter and buy new bolts and locknuts... but for around $60 its worth it and cost less than buying wheel spacers!
Old Jun 25, 2012 | 01:27 PM
  #126
runs-on-4's Avatar
teaser aha rear shocks maxed out
HOLY FLEX!
Old Jun 30, 2012 | 07:21 PM
  #127
runs-on-4's Avatar
finally can drive my truck got new trail gear highsteer. my original highsteer, was some sketchy stuff.. if i hit a bump at 25 it would do a death shake. now.. 55 60 no shakes no nothing
Old Jun 30, 2012 | 08:07 PM
  #128
Terrys87's Avatar
Looks like you are making some great progress on your truck. Congrats, looking good.
Old Jun 30, 2012 | 08:22 PM
  #129
runs-on-4's Avatar
thanks man, its killing my bank account aha
Old Jun 30, 2012 | 09:13 PM
  #130
RMP8080's Avatar
Yea it's only money, better to spent it on what you want then the gov't....
Got any pics of the new high steer, doing it to my pickup...one day that money thing again....Bill
Old Jul 6, 2012 | 11:44 AM
  #131
Yopar's Avatar
Pics and updates?
Old Jul 7, 2012 | 06:24 PM
  #132
vang_22re's Avatar
Looking good! Is that a hy-brid RUF pack Or just stock? Good flex too
Old Jul 8, 2012 | 05:33 PM
  #133
runs-on-4's Avatar
Thanks man theyre Stock for now not sure what I want to do to them yet
Old Jul 21, 2012 | 08:20 AM
  #134
runs-on-4's Avatar
got the new trailgear driveline, still searching for a locker 488 diff for the front, i just wanna go wheeling. im putting a open 410 in the rear just so i can at least have 4wd.
if anyone knows of a locked 488 8inch diff LET ME KNOW!!!!!
Old Aug 5, 2012 | 12:29 PM
  #135
runs-on-4's Avatar
rebuilt one knuckle last night, also did new rotors and pads, spent most of the time cleaning grease , went threw 2 gallons o degreaser, also a lot of time finding missing parts ,, going to do the other side tonight will post pictures,
highly recommend using toyospearo's thread was a lot of help, pretty easy job to time consuming
Old Aug 5, 2012 | 07:58 PM
  #136
rustED's Avatar
How do you like the new driveline? I just got done fabbing up a temporary front driveline until I can afford a new long spline one. X2 on Toyospearo's front axel thread, helped me out a lot also!
Old Aug 6, 2012 | 01:21 PM
  #137
runs-on-4's Avatar
havent wheeled with it yet, but it better be nice, got over 300 into it! sure is pretty though
Old Aug 6, 2012 | 06:28 PM
  #138
runs-on-4's Avatar
new rotors pads calipers, wheel studs, and knuckle rebuild kit.
and the new driveline
Old Aug 6, 2012 | 07:25 PM
  #139
rustED's Avatar
Nice work, its looking good! So on the driveline, did you have to remove your double cargan joint from your old driveline and weld it onto the new TG driveline? Just curious what it comes with, or what is needed, thanks!
Old Aug 6, 2012 | 08:24 PM
  #140
runs-on-4's Avatar
ya you gotta weld the old joint on, i wish i would have upgraded to the creeper joint if i was going to spend a good chunk of change on a driveline
