richf 1985 4runner build-up thread
Old Jan 20, 2011 | 06:21 PM
  #101
richf's Avatar
I think the speakers I have for behind the front seats are 6x9. I'm mainly trying to avoid a box or a big speaker in the panels behind the rear seats. I don't want something that I'm going to have to watch out for every time I put stuff in the back. My 150 sounds pretty much like any other stock truck.
Old Jan 21, 2011 | 12:05 PM
  #102
richf's Avatar
Got the transfer case mount cleaned and painted. Looks almost brand new. I assume it's still good to use because the rubber still looks good and it's still attached to both pieces. I wanted to get a new one to see if it will help with vibrations but they are a lot of $$$.
Old Jan 21, 2011 | 07:55 PM
  #103
TinMan's Avatar
Looks good man.
Old Jan 22, 2011 | 12:38 AM
  #104
Swimmerboy2112's Avatar
Figured i'd pop in here and check it out. Looks great man keep up the good work!
Old Jan 22, 2011 | 05:06 AM
  #105
yotarob2005's Avatar
I need a new mount all together, my rubber is split and it is clearly sagging in the middle. Yours looks great!
Old Jan 22, 2011 | 07:18 AM
  #106
Bojangles's Avatar
I just read through the whole thread, Your build is coming along a lot better than mine haha.
Did you ever figure out your headgasket issue? I may have missed it...
But it looks awesome! Ill keep watching.
Old Jan 28, 2011 | 01:59 PM
  #107
richf's Avatar
Thanks guys. I actually didn't have head gasket issue. It was me being a little over reactive I guess. All is good on the head gasket.
Anyways got my stuff for MC and TG this week. MC actually came in before TG. That was a first. I installed the other shift spring and detent bolts, TG flanges, and MC rear out put seal on the front drive shaft output. Also I went ahead and placed a order for a new transfer case gasket at the dealer and they got the wrong one. So I went with the FIPIG. Is this stuff ok to use or should I use the Ultra Grey? Should I use this on the output flange nuts?
New detent bolts. The shift spring and detent ball are located inside the bolt hole.
New front and rear output flanges
I assume I need to apply the FIPIG or Ultra grey around the base of the threads on the output flange. Does that sound right??
If I can get away with using the FIPIG or Ultra Grey this thing should be back on the road this weekend.
Old Feb 7, 2011 | 01:12 PM
  #108
richf's Avatar
Alright after a little research I decided to go ahead and use the FIPIG. So far so good. I do have one problem and it's the fitment of the twin shifter in the stock hole cut into the tunnel. The right stick rub right up against the tunnel. When I turn the truck on it sounds horrible cause of the vibrations. Anyone have any idea on what's going on? I'm thinking it's normal and I'm just going to have to do some trimming.
forgot to mention that I can not pull the right stick all the way back without cutting up the tunnel.
Old Feb 7, 2011 | 07:18 PM
  #109
TinMan's Avatar
I figured we were going to have to do some trimming to get that second shifter to fit. Doesn't look like you are going to have to do much though. I would trim enough to allow for the body to clex also.
Sorry man forgot to post about the FIPG. It will be fine. I also use it on the splines. Just to be sure it doesn't leak throught them.
Later
Old Feb 7, 2011 | 08:26 PM
  #110
richf's Avatar
Good to hear about the FIPIG. I'm a little pissed I have to trim to make this fit. I might go at it tomorrow if I get some free time. I do know that it's going to look like crap and may have a gap on the driver's side. I did some test fitting with the boot and it doesn't cover both side with the way they are positioned now. I'll see if I can use the old metal trim ring and boot to cover up the gap.
Old Feb 8, 2011 | 05:07 AM
  #111
RBX's Avatar
RBX
can you flip the arms, or bend them instead of trimming? Just a thought.
Old Feb 8, 2011 | 05:33 AM
  #112
irab88's Avatar
there's also this twin-stick set-up, which might fit better in your tight confines
or this one
Old Feb 8, 2011 | 05:35 AM
  #113
richf's Avatar
The arms are curved the same so swamping them wouldn't do anything and I don't know if I could bend them with out messing them up.
Old Feb 8, 2011 | 05:46 AM
  #114
richf's Avatar
ya to late now to switch sticks. Plus I got the one from TG when it was on sale for $100 bucks. I think I can live now with having to cut the tunnel.
Old Feb 8, 2011 | 05:52 AM
  #115
irab88's Avatar
well, yeah, for that price it does make sense
and i also wanted to bookmark them myself
Old Feb 14, 2011 | 12:11 PM
  #116
richf's Avatar
Well after a 2 month wait I got my no side windows soft topper in (maybe the only no side window soft topper for a 4runner in the world WoooooooooooooooooooooooW). Had it installed in about 2 hours. The top was really taut and it all most seemed like I was going to break it while I was snapping the last couple buttons. Any ways I'm pleased so far with it. I'll be able to really score it come spring time. Here are some pics. I think it looks cool also.
Old Feb 14, 2011 | 12:29 PM
  #117
87hillbillyoter's Avatar
damn that things sexy
Old Feb 14, 2011 | 12:34 PM
  #118
irab88's Avatar
wow! that looks really good!
how's the noise level on the road?
Old Feb 14, 2011 | 12:42 PM
  #119
RBX's Avatar
RBX
dig the black on beige.
Can't wait to put my soft top on!
Old Feb 14, 2011 | 03:01 PM
  #120
Z's Confederate Toy's Avatar
Looks good! I like that topper
