cascades 1979 4x4 build thread
Old Aug 24, 2021 | 08:13 AM
  #101
swampedout's Avatar
5 Year Member
Shiny!!!
How much did it get bored out?
Old Aug 24, 2021 | 04:09 PM
  #102
cascades's Avatar
5 Year Member
Originally Posted by swampedout
Shiny!!!
I'm at 93mm - so 0.40 over total.
Old Aug 24, 2021 | 04:53 PM
  #103
swampedout's Avatar
5 Year Member
Sweet. Youll get a some extra horses there. Are you doing anything with the cam or keeping it close to stock?
Old Aug 24, 2021 | 06:56 PM
  #104
cascades's Avatar
5 Year Member
Keeping it near stock at this time. Not much budget to do anything different and what I have is in good shape.
Old Aug 24, 2021 | 07:33 PM
  #105
swampedout's Avatar
5 Year Member
Just curious. I always thought the stock cam had a smooth power band but I dont have huge tires on any of my trucks.
I just got a 22re rebuilt last winters. Its still got a little Toyota valve tick but once its warm, you can stand next to the truck while its running and not hear anything. It feels kind of wrong but its got some pep and Ive been enjoying driving it recently.
Old Aug 24, 2021 | 07:41 PM
  #106
cascades's Avatar
5 Year Member
Engine bay looks mint!!!!
Old Aug 28, 2021 | 04:20 PM
  #107
cascades's Avatar
5 Year Member
Got the crankshaft installed today. Torqued to 75 ft/lbs in three steps as per the sequence in the fsm.
Old Aug 28, 2021 | 05:08 PM
  #108
swampedout's Avatar
5 Year Member
Where are you getting all your parts from?
Old Aug 28, 2021 | 07:42 PM
  #109
cascades's Avatar
5 Year Member
LC Engineering, 22RE Performance, Yotashop, local dealership, Napa. I've been trying to get OEM for most parts....seals, bearings, sensors. I don't really have any allegiance to one vendor, I just like stuff to be in stock and good customer service. If there is something you see in particular ask away, I'll post a link.
Old Aug 29, 2021 | 05:03 AM
  #110
swampedout's Avatar
5 Year Member
I was curious because I never heard of that brand of the bearings. I might ask you in a year or 2 when I rebuild my 20r.
Old Aug 29, 2021 | 05:19 AM
  #111
cascades's Avatar
5 Year Member
Taiho is manufactured in Japan. Supposedly OEM.
Old Aug 31, 2021 | 03:57 PM
  #112
cascades's Avatar
5 Year Member
Set the rings and installed one of the pistons today to check height clearance. Does not appear to be an issue thus far.
Old Sep 4, 2021 | 03:32 PM
  #113
cascades's Avatar
5 Year Member
Pistons, freeze plugs. rear main seal, timing chain and timing chain cover installed today.
Old Sep 5, 2021 | 07:03 PM
  #114
cascades's Avatar
5 Year Member
Oil pickup and pan, oil pump, valve springs and smoked ribs today!
Installing an oil pan on the stand is the only way to go.
Old Sep 6, 2021 | 02:16 PM
  #115
cascades's Avatar
5 Year Member
Camshaft installed, various other parts, transmission to block braces (previously missing), engine mounts, alternator, water pump and crank pulley.
Decided to replace the rocker shafts, so head will have to wait until the parts come in.
The parts pile is getting smaller!
Old Sep 11, 2021 | 03:08 PM
  #116
cascades's Avatar
5 Year Member
Rebuilt the rocker assembly (new shafts and adjusting screws), installed cometic head gasket, installed head, adjusted valves, installed distributor, mounted fuel pump and got the intake bolted up.
Old Sep 11, 2021 | 04:55 PM
  #117
cascades's Avatar
5 Year Member
And got Weber and spiral adapter installed. That's it for today.
Old Sep 11, 2021 | 05:02 PM
  #118
Enzothehound's Avatar
5 Year Member
Nice progress!
Old Sep 17, 2021 | 03:17 PM
  #119
cascades's Avatar
5 Year Member
Power steering bracket puzzle and fan clutch mounted today.
Old Sep 26, 2021 | 06:19 AM
  #120
swampedout's Avatar
5 Year Member
This is a little random considering all the work youre doing but do you have any photos of the front bumper?
