79 20ret
Old May 6, 2015 | 09:05 AM
jabrown1095's Avatar
79 20ret
hey, i have a 79 toyota two wheel drive that im building. here is my list of parts im using
20r block rebuilt
pre 84 22r head
94 22re intake and wiring harness and computer
i have a t25 turbo
i also have a 22ret stock manifold
i need to know what i need to make the computer work for the fuel injection and timing
Old May 7, 2015 | 04:37 PM
slacker's Avatar
mega squirt will help in those computer duties , but you do know that the intake wont bolt up to that head .. right ?
Old May 7, 2015 | 04:40 PM
yup
Ya i know. I will have to drill and tap holes for it. I would love to use mega squirt if i had 1000 to drop on juat the computer system
Old May 7, 2015 | 04:42 PM
slacker's Avatar
Toyota computers cant be reflashed .. at least not to my knowledge
, you will need some sort of piggy back
Old May 7, 2015 | 04:45 PM
What about a 22ret computer. And do they make one thats a two plug
Old May 8, 2015 | 02:05 PM
rick8282's Avatar
Have you looked into turbo on propane? That's what I would do if I was you. Also eMS-Pro $430 shipped to your door. It's a standalone that's mega squirt based.
Old May 8, 2015 | 02:13 PM
propane
Im almost done with the build and i want to stay gas. Ill be running 10lbs of boost for now. Ill be building a 22r botom end for the engine but illbe hoping for 400+ hp with that build.
I just dont know much about ecu fuel injection at this point. Will that ecu control timing too or is it just a fuel map base
Old May 8, 2015 | 03:22 PM
rick8282's Avatar
400hp with a 22r that's going to be hard and a lot of money.
Yes the Ems-pro does it all.
http://www.efisource.com/shop/ems-pr...ith-8-harness/
Old May 8, 2015 | 03:34 PM
Yea. Ive seen 350 out of a 22r on a dyno at the wheels. Its gonna be cammedand bored with total seal rings and about 20lbs of boost.
Im building the truck for autocross. The 20ret build im doing has cost me a total of about 400 right now and all i need is a computer so ill be into it a 1000 i think
