FS[MidAtl]: 84 Pickup and 92 Pickup
Hello, I have numerous parts left over from a build project. I was holding on to a lot in case I needed material to make something but I never did.
Entire dash assembly from 84 (grey) let me know what piece you need.
Entire dash assembly from 92 (grey) missing the trim around cluster.
Sr5 cluster from 84 4cy with speedo cable
Multiple non sr5 clusters (84 and 92)
Grills from the 84 and 92
Kickpanels from the 84 (have one been painted black) 92 (grey)
Grap handles, 92 (grey) 84 (painted black)
Grey door panels and interior handles from 92
84 arm rest (both been painted black)
Ebrake lever assembly from 84 and 92
Rear view mirror 84 and 92
Some window trim for 84
Airflow meters from 84/92
Shift knobs/levers
Headlight buckets from 92
Clutch/flywheel from 92
Fan blade/clutch from 92
Egr complete from 92
Stock knuckle arms and draglink from 84
Rear axle housing from 92 (was rotted under leaf spring perch)
Multiple front/rear driveshafts (84/92)
Wiring harness from 84, 92, 89 pickups.
I also have multiple top shift t-cases (housings, parts, complete. A g54 transmission. Multiple sets of leaf springs. Perfect rear axles from the 84 with no rust on original backing plates. Also have two really nice steel 15" wheels off a 89 pickup.
I'm sure I'm forgetting things, just shoot me a pm with anything to look for and price. Can take pictures at request.
Thanks,
Mario
Shift knobs/levers
Thanks,
Mario
Sorry, I should've specified. The dash pad from the 92 in the 3rd pic and driver's side mirror from the 92. Also, if I could get a price on that 92 grill shipped, that would be great as well.
Are these the same set of seat belts? If not I am interested in the top set price with shipping to 97078 (they recently switched our zip code, if it doesn't work try 97007) might fit in a flat rate padded envelop.
Retractors work as they should?
its not pictured but im going to ask anyways, do you have the grey passenger side vent louvre for the 84? im not sure if it is the same for the 92 but if they are interchangeable shoot me a price with shipping to 70810
