Vehicles - Parting Out Parting out a vehicle, post it here
FS[MidAtl]: 84 Pickup and 92 Pickup
Old Mar 7, 2019 | 08:08 AM
chowboy's Avatar
Steering column cover for 84?
factory center support bearing for 84?
Old Mar 7, 2019 | 12:31 PM
ttr125mar's Avatar
Sold a steering column cover for the 84. No center support bearing.
Old Mar 9, 2019 | 09:59 PM
chowboy's Avatar
Thanks for the reply..,glws
Old May 28, 2019 | 05:43 PM
Sundj01's Avatar
Hey, I’m looking for wire harness for my 1989 pickup 4wd 22re. Do you have?
Old Jun 13, 2019 | 07:12 PM
  #25
I8URSVT's Avatar
‘84 core support in good shape?
Old Sep 15, 2019 | 06:21 PM
  #26
Mwhite49's Avatar
Originally Posted by ttr125mar
Hello, I have numerous parts left over from a build project. I was holding on to a lot in case I needed material to make something but I never did.
Entire dash assembly from 84 (grey) let me know what piece you need.
​​​​​​Entire dash assembly from 92 (grey) missing the trim around cluster.
Sr5 cluster from 84 4cy with speedo cable
Multiple non sr5 clusters (84 and 92)
Grills from the 84 and 92
Kickpanels from the 84 (have one been painted black) 92 (grey)
Grap handles, 92 (grey) 84 (painted black)
Grey door panels and interior handles from 92
84 arm rest (both been painted black)
Ebrake lever assembly from 84 and 92
​​​​​​Rear view mirror 84 and 92
Some window trim for 84
Airflow meters from 84/92
Shift knobs/levers
Headlight buckets from 92
Clutch/flywheel from 92
Fan blade/clutch from 92
Egr complete from 92
Stock knuckle arms and draglink from 84
Rear axle housing from 92 (was rotted under leaf spring perch)
Multiple front/rear driveshafts (84/92)
Wiring harness from 84, 92, 89 pickups.
I also have multiple top shift t-cases (housings, parts, complete. A g54 transmission. Multiple sets of leaf springs. Perfect rear axles from the 84 with no rust on original backing plates. Also have two really nice steel 15" wheels off a 89 pickup.
I'm sure I'm forgetting things, just shoot me a pm with anything to look for and price. Can take pictures at request.
Thanks,
Mario
What condition is the 84 wiring harnes? Is at off a 4x4?
Do you know if it's a California truck?
And how much shipped to zip 93010?
Old Sep 20, 2019 | 06:48 PM
  #27
chroad's Avatar
Do you have the front mud flaps from either truck?
Old Sep 20, 2019 | 07:37 PM
  #28
I8URSVT's Avatar
I may have front mud flaps. Will check this weekend and let you know
Old Sep 21, 2019 | 04:35 AM
  #29
chroad's Avatar
Thanks.
Old Oct 24, 2019 | 11:22 PM
  #30
Amethyst_Spark's Avatar
Reservoir
I need the windshield washer fluid reservoir and the pump for my 1991
Old Jan 21, 2020 | 09:51 PM
  #31
Eber Chacon's Avatar
do you have a combination switch for the 84?
Old Nov 17, 2020 | 04:42 PM
  #32
Lando's Avatar
Do you have the 84 grill?
Old Nov 17, 2020 | 05:56 PM
  #33
NYHumpinUtah's Avatar
I have the old grill, I bought a new one online. If I didn't want my grill I'm sure you don't
Check on ebay, they have them
Hump
Old Nov 23, 2020 | 03:33 PM
  #34
tyvanwie's Avatar
Do you have grey door panels from the 84? Or know if the 92 panels will work on an 86?
Old Nov 25, 2020 | 04:44 AM
  #35
ebakley's Avatar
throttle accelerator butterfly bracket
Looking for the 22R throttle accelerator butterfly bracket.
Old Nov 25, 2020 | 05:18 AM
  #36
ebakley's Avatar
22r throttle butterfly bracket linkage
This is what I'm looking for. Don't know why I can not add in PM.
Old Dec 2, 2020 | 11:13 AM
  #37
blu911's Avatar
Hi Mario,
You wouldn't happen to have a right rear backing plate thats in good condition would you?
My truck is a 1988 single cab 4X4 with a 22RE fuel Injection
Thank you,
Todd
Old May 12, 2021 | 11:38 PM
  #38
PNWventures's Avatar
5 Year Member
I know it was a while ago but anyway you still have those wheels? Are they BORLEMS? If they're still available, and are Borlems I'm in the market. My wheels say :MADE IN BRAZIL DOT 8JJ X 15 BORLEM NE 04 6/84 . I am missing 1, and a spare would be nice too.
Old Oct 18, 2021 | 02:08 PM
  #39
nickdaq's Avatar
Do you have any power steering stuff for the 84?
Old Oct 25, 2021 | 12:31 PM
  #40
Boyd’s Auto's Avatar
Are the shift knobs available for the’84? My dog ate the “J” shift knob.
Mike
