Other Makes Cars/Trucks Own a different car or truck other than a Toyota?
Chevy sometimes just shuts off.
Old 04-09-2014, 11:41 AM
turkeykiller365's Avatar
So, i have a 2003 chevy silverado z71 extended cab 4x4 with the vortec 5.3 liter engine.
On this truck, everything is electronic. I have electronic throttle, brakes, ignition, timing, everything. I hate it.
So sometimes when im driving around, at low speed usually, the engine will just shut off. This happens usually if im turning and on the breaks at the same times, but the engine does not bog down first, just cuts out suddenly. The radio, lights, etc stays on but the engine quits. I have replaced the o2 sensors, spark plugs and wires, cleaned the MAF sensor, everything and I just can't figure it out.
Also, i did recently replace all of the fuel lines from the rails to the tank, as well as all of the brake lines with stainless (the old ones were gone), but i dont think the pressure is bad because it runs fine when im driving faster than 15 mph. It also has a rough idle sometimes at stop lights and such.
If anyone has any ideas, let me know. Im no good with electronics and im stumped.
Thanks!
Old 04-09-2014, 09:22 PM
totally a bro
Staff
vital22re's Avatar
get a guage on the fuel pressure... these things are super finicky about fuel pressure.
Old 04-10-2014, 08:18 AM
toyota4x4907's Avatar
Do you have a lot of things on your key chain?
(I know, the Silverado isn't effected by this. I was just being facetious)
Old 12-01-2014, 08:48 PM
RyanV's Avatar
Check your negative battery cable for high resistance OR just replace that negative cable
Old 12-10-2014, 07:23 PM
JPW
JPW's Avatar
I would bet money it's your crank positioning sensor -- Had the same problem with an 02 Tahoe -- the sensor is located on the right side of the engine block behind the starter
Old 12-10-2014, 07:30 PM
JasonYota's Avatar
Don't want to state the obvious… but is your check engine light on? Checked for codes?
Edit. Just noticed this is 8 months old. Can't stand threads without closure
Corvoid
12-11-2015 11:21 AM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
JookUpVandetti
09-30-2015 08:58 AM
beltcutter
09-30-2015 06:14 AM
voiddweller
09-28-2015 11:21 PM
Quick Reply: Chevy sometimes just shuts off.
