WTB: Factory 4.30's
Old Jan 30, 2007 | 01:49 PM
Albuquerque Jim's Avatar
WTB: Factory 4.30's
I am looking for a set of OEM 4.30 gears front 7.5" and rear 8".
These were found in Limiteds with Autos and an E-locker; probably some SR5's as well.
If you have upgraded to 4.56's or 4.88's and have your factory 4.30's please let me know.
Old Jan 30, 2007 | 06:31 PM
millertime_t1's Avatar
I have some I would trade for lower 8" thirds --- I will be doing an sas shortly
Old Jan 30, 2007 | 09:11 PM
I don't really have anything to trade, can I buy them?
Old Jan 31, 2007 | 01:45 PM
spaceycayce's Avatar
If you want the 4.88 v6 third, I may be able to work something out with Jim. I had to go get another 4.56 third today to re-gear. I can help out if needed, let me know.
Old Jan 31, 2007 | 05:22 PM
Cool, "let's make a deal"
Old Jan 31, 2007 | 07:27 PM
I suppose so? -- I don't really know what they are worth! --- Any idea?? Also if you guys want to work out somethin with the rear 4.88 -- I would be interested!
Email me --- Millertime_t1@msn.com
Old Jan 31, 2007 | 07:33 PM
UKMyers's Avatar
You want the thirds or just the R&P? I have the factory R&P out of my 2nd Gen. I'm about 95% sure they were 4.30's. You pay for shipping and you can have them.
Old Jan 31, 2007 | 07:46 PM
If you count the teeth on the ring and pinion there should be 43 on the ring gear and 10 on the pinion.
On a 2nd gen I could only use the rear, but yeah...it's a deal if they are correct.
I would bet they were 4.10's though, since you have a 5 speed.
Old Jan 31, 2007 | 07:49 PM
I have bought a few sets...I paid $50 for the first set and $75 for the 2nd set.
I broke some teeth on the first set and I am running the second set. They are getting harder to find so I want a spare.
So which do you have front (7.5" Reverse Rotation), rear (8" V6), or both?
Old Feb 2, 2007 | 06:41 AM
Mine is a set out of a 5 speed. 1994 4-Runner V-6 ----4.30 gear ratio! However, I am sorry to tell you that I won't take these out for $75.00! It will cost me a minimum of a couple hundred dollars per end to regear! So I would not even be close to sellin! I'm sorry man, I wish you luck in your search! If you would just like the front i would take $100.00 for it! That will put me that much closer to matching the rear.
Old Feb 2, 2007 | 09:26 AM
The front 3rd gens are reverse rotation due to the high pinion style diff, your fronts won't work.
If you ever take the rears apart let me know, I can always use another spare set.
Old Feb 2, 2007 | 09:31 AM
No problem -- I may do that sometime because i'm not dead set on 4.30 gears! I would kinda like to go lower. I would also like to apologize for the mix-up! 4.30's are so uncommon in later model Toys that i assumed they were for earlier model (even after you said reverse rotation). I was confused %^&%%> Sorry man, and good luck to ya!
kawazx636
Oct 6, 2021 03:03 PM
I8URSVT
Jun 21, 2016 01:31 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
kbpickens
Oct 2, 2015 03:37 PM
tysen86
Sep 25, 2015 11:15 PM
