Supra MAF
so your going supercharged and upgradeing the ecu
search for supra maf it wont work with the stock ecu
ok why not?
and can i switch to a 97 ECU?
if so would that also cure some problems when SC'ing a 96 tacoma?
if so, would there be any wireing harness issues to look at?
Originally Posted by dfoxengr
ok why not?
hold your ponys
the only time a supra maf would alow more air then the stock ecu might be able to handle MIGHT i say again is under full throttle conditions. and only if supercharged. if not supercharged there would be no problem using a supra MAF.
there is No way that a supra maf alone would let more air into the engine then a stock maf and supercharger.
the main reason for using a Supra MAF would be throttle response. not horsepower especially if you where supercharged. less restriction in intake = faster throttle response same as moving the stock maf up next to the TB. the restriction is then right next to the TB so it takes less time for the AIR MASS to Transmit suction past the Restriction
BTW ebay it i got mine on ebay for under $40 shipped
creecher10
Sep 30, 2015 03:27 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
