Supra MAF
Old Jun 8, 2006 | 03:26 PM
dfoxengr's Avatar
Supra MAF
needing a Supra MAF that plugs directly into the 96 tacoma plug.
let me know.
Old Jun 13, 2006 | 05:41 AM
dfoxengr's Avatar
anyone?
Old Jun 13, 2006 | 06:51 PM
Elton's Avatar
so your going supercharged and upgradeing the ecu
Old Jun 14, 2006 | 03:04 AM
dfoxengr's Avatar
why do you think that?
Old Jun 14, 2006 | 05:55 PM
Elton's Avatar
search for supra maf it wont work with the stock ecu
Old Jun 14, 2006 | 06:07 PM
dfoxengr's Avatar
ok why not?
and can i switch to a 97 ECU?
if so would that also cure some problems when SC'ing a 96 tacoma?
if so, would there be any wireing harness issues to look at?
Old Jun 14, 2006 | 09:19 PM
yoda-g2's Avatar
Originally Posted by dfoxengr
ok why not?
Simply put, it allows considerably more air flow, so much that the stock ECU cannot add enough fuel to its base maps to compensate. Its just too far out of spec. As far as I konw, you HAVE to have some sort of controller to go with it, FTC, SMT, etc... I use the FTC that URD sells, but I am also S/C'd.
Old Jun 15, 2006 | 03:01 AM
dfoxengr's Avatar
right thats fine. ill be doing all that stuff at the same time too.
Old Jun 25, 2006 | 09:22 AM
dfoxengr's Avatar
help?
Old Jul 27, 2006 | 12:05 PM
dfoxengr's Avatar
sell me one.
Old Aug 25, 2006 | 10:19 PM
thefallman's Avatar
hold your ponys
the only time a supra maf would alow more air then the stock ecu might be able to handle MIGHT i say again is under full throttle conditions. and only if supercharged. if not supercharged there would be no problem using a supra MAF.
there is No way that a supra maf alone would let more air into the engine then a stock maf and supercharger.
the main reason for using a Supra MAF would be throttle response. not horsepower especially if you where supercharged. less restriction in intake = faster throttle response same as moving the stock maf up next to the TB. the restriction is then right next to the TB so it takes less time for the AIR MASS to Transmit suction past the Restriction
Old Aug 26, 2006 | 09:57 AM
thefallman's Avatar
BTW ebay it i got mine on ebay for under $40 shipped
Old Dec 25, 2006 | 05:49 PM
dfoxengr's Avatar
back to wanting one.
thank you.
jb451
7
Oct 7, 2022 06:58 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
creecher10
Sep 30, 2015 03:27 PM
93RedKrawler
Sep 29, 2015 02:50 PM
toyotasaurus
Sep 24, 2015 03:30 PM
