o2 sensor
Old Apr 11, 2007 | 12:22 PM
86toysr5's Avatar
o2 sensor
i need a o2 sensor for a 97 toy tacoma 2.7
Old Apr 11, 2007 | 05:54 PM
Elton's Avatar
www.sparkplugs.com
Old Apr 11, 2007 | 07:14 PM
86toysr5's Avatar
those r pretty good prices....i no theres one infront of the cat i was told the other is on the manifold but couldnt c it.....and which do u think went bad cuz im thoughing the p0420 i believe so thats the one on the manifold but i couldnt c it
Old Apr 11, 2007 | 07:32 PM
Elton's Avatar
with that code have you tried cleaning the maf sensor and resting the ecu ?
Old Apr 12, 2007 | 02:45 PM
86toysr5's Avatar
i did reset the ecu and i went off for 2days it didnt come on the first time until the day after i checked the air filter....it was pretty dusty it was a grayish instead of white so today i went and got a new filter and sum maf cleaner and reset it and we will c what happens
Old Apr 13, 2007 | 07:12 AM
86toysr5's Avatar
well it came back on today.....all 3 times its came on was on the interstate
Old Apr 13, 2007 | 07:29 AM
NaeSLaS's Avatar
P0420 specifies catalyst efficiency (as measured by the 02 sensor). Either the sensor is bad, or the catalytic converter died (which is unlikely on that new a truck).
But if i remember correctly, P0420 specifies pre-cat'd emissions, so it would have nothing to do with the catalytic convertor. This sensor should be on the exhaust, before the cat.
To help you look, most sensors are mounted about 1 o clock on the exhaust collector/manifold, so start there.
Old Apr 13, 2007 | 07:35 AM
86toysr5's Avatar
i found the one by the cat people were telling me there is a 2nd one also
i was told a bad cat will give off a bad smell which i dont have
Old Apr 13, 2007 | 08:02 AM
NaeSLaS's Avatar
did you find the one downstream of the cat, or upstream?
Old Apr 13, 2007 | 04:51 PM
86toysr5's Avatar
ok i found the other one i got one right before the cat and one between the cat and muffler
moparbay
Mar 10, 2023 03:50 PM
jb451
7
Oct 7, 2022 06:58 AM
Kreedy1
Sep 8, 2015 06:33 PM
zz_denis
Sep 6, 2015 03:43 PM
moparbay
Sep 3, 2015 12:48 PM
