the list: misc parts
Old Feb 2, 2011 | 08:35 PM
uhohhotdog151's Avatar
once again making a list of everything that i have that i want gone. as always all prices are obo, and im open to trades. (509)607-9111 more pics available on request. ill be adding more to the list next weekend.
located in ELLENSBURG, WA.
-10" sub in box(13.5"x17"x16") $20.00
-2" receiver "tow package" was off of a 97 f350 looks adjustable $40.00
-misc trailer lights& reflectors $make offer
-losi crawler with aftermarket tube chasis and a few other upgrades $300.00
-85 toyota efi head $45.00
-85 22re crank $25.00
-top shift case $150.00
-forward shift case $100.00
-84 carbed intake manifold with sensors and fuel pump $65.00
-83 carbed intake manifold with sensors $55.00
-22r/e alternator 20.00 x3
-22r/e alternator (new) 45.00
-22re distributor 35.00 x3
-2rz aluminum radiator with mounting brackets $50.00
-22re valve cover(square) 15.00
-22r valve cover (round) 15.00
-85 22re exhaust manifold w/O2 sensor $20.00
-22re intake manifold and plenum with sensors $65.00
-22r air filter housing $15.00 x2
-22re plenum $40.00
-complete 3.0 intake $20.00
-22re airbox top with maf $20.00
-22r intake tube $25.00
-22re intake elbow $10
-22r carb spacer $8.00
-22re timing cover $20.00
-22re oil pump $5.00
-dip stick tube $5.00
-22re oil pickup $5.00
-22re fuel rail with filter $10.00
-22r fuel pump $10.00
-22re/v6 coolant overflow tank $10.00
-91 3.0 coil $20.00
-80 20r voltage regulator $20.00
-87 22re harness with some broken connectors $15.00
-22r/e ac pump $25.00 x2
-22r carbed distributor $10.00 x2
-22re throttle cable bracket $5.00
-22re front lifting hook $5.00
-22re upper alt. bracket $10.00 x2
-22re lower alt. bracket $10.00 x2
-22re bellhousing exhaust bracket $10.00
-22re power steer pump bracket $20.00
-22re motor mount $10.00 x3
-22re engine to trans brace x4 left x2 right $5.00
-motor mount stiffener tubes $5.00 x2
-2 belt crank pulley $5.00
-5" pulley $5.00
-4.75" pulley $5.00
-5.5"pulley $5.00
-plate that bults to the back of the engine $5.00 x2
-22re cover for inspection cover on auto trans $5.00
-22r egr $10.00
-22re egr $10.00 x3
-22re metal fan shroud $25.00
-22re egr modulator valve $5.00 x3
-89-95 22re egr heatsheild w/sensors and manifold $15.00
-22r egr manifold $5.00 x2
-22re egr exhaust manifold pipe $10.00
-22re egr exhaust manifold pipe with back pipe $15.00
-22re intake side egr pipe and box $10.00
-22re lower radiator elbow pipe $10.00x 3
-22re pass side waterpump outlet pipe $5.00 x3
-22re drivers side waterpump outlet pipe $5.00 x2
-22re coolant/vacuum switch $10.00x3
-coolant tube intake to heater core $5.00 x3
-89-95 egr back pipe intake to exhaust $10.00
-upper alt bracket $10.00
-lower alt bracket $10.00
-22re bellhousing exhaust bracket $5.00
-power steering pump bracket $20.00
-motor mount x3 $10
-engine trans brace 4x left 3x right $5.00 each
-motor mount stiffener tubes x3 5.00 each
-2belt crank pully $5
-5" pully$5
-4.75" pulley $5
-5.5" pulley $5
-back engine plate $5
-toy auto inspection cover $5
-22r egr $10
-22re egr x3 $10
-22r metal fan shroud $25
-22re modulator valve x3 $5
-22re heat shield manifold and sensors $15
-22r egr manifold x2 $5
-egr exhaust manifold pipe $10
-egr exhaust manifold pipe with back pipe $15
-intake side egr pipe and emission box $10
-metal elbow lower radiator hose x3 $5
-pass side waterpump outlet pipe x3 $5
-drivers side waterpump outlet pipe x3 $5
-coolant/vacuum switch with housing $5
-coolant to intake manifold to heater core x3 $5
-22re egr back pipe intake to exhaust $5
-harmonic balancer bolt $5
-fuel filter bracket $5
-knock sensor cover/wire $5
-oil pressure sending unit $5
-02 sensor $25
-coolant temp sending unit $10
-4wd sending unit $10
-22re cold start injector $10
-starter relay $10
-battery tray $5
-fuel line with banjo fitting $5
-22re exhaust manifold w/ headpipe $50
-tcase main bearing $5
-tcase/pinion flange $10
-sas long side inner x2 $20
-sas short side inner $20
-sas housing 82 and 85 $80
-tcase shifter $5
-clutch fork $15
-1.5" spyder traks wheel spacers $40.00
-07.5 chevy 2500 hd diesel fuel tank $20.00
-07.5 chevy 2500 hd 11.5" american axle rear end $250.00
-07.5 chevy 2500 hd ifs front end $200.00
-93 4.3 liter vortec $400.00
-97 f350 headlight and marker light ass. $50.00
-97 powerstroke cpu $60.00
-97 f350 powerstroke airbox $15.00
-97 f350 powerstroke starter solenoid 20.00
- 97 f350 powerstroke washer fluid res. $15.00
- 97 f350 powerstroke radiator $70.00
-97 f350 powerstroke drivers side door(blue) power windows/locks $60.00
-97 f350 powerstroke passenger wing window $15.00
-97 f350 powerstroke solid rear window $70.00
-97 f350 powerstroke head unit $60.00
-2002 f250 tailgate (white) $100.00
-07.5 dmax washer fluid res. $30.00
-factory toy tool kit $25.00
-22re alt harness $15.00
-2nd gen toy headlight bucket $5.00
-4runner rear window motor $25.00
-22re throttle cable $20.00
-gas capx2 $5.00
-oil filler cap $5.00
-radiator cap $5.00
-trans shift knob $5.00
-t case shift knob $5.00
-2nd gen sr5 dash clock $15.00
-deck lamp w/ switch from 4runner $10.00
-4runner rear window switch $10.00
-4runner rear window lock button $10.00
-2nd gen ashtray $5.00
-3rd gen extra cab v6 trans shifter cover $5.00
-4runner drivers seat belt and rear lap belt $15.00
-22r dipstick $5.00 x2
-rubber tcase mount $10.00 x3
-5 spd toy tranny x 2 $200.00
-v6 toy 5spd $200.00
-ifs front driveline $50.00
-sas front driveline $75.00
-ifs cv $20.00
-front driveline male shaft and flange w/ ujoint $15.00
-front driveline male shaft and flange w/o ujoint $15.00
-left and right knuckles $35.00 each
-sas hub $10.00
-sas spindle x2 $20.00
-v6 rear shaft 38 1/2" tube $40.00
-stock carriers w/ spiders 1 w/410 ring gear $20.00 ea.
-ring gear bolt lock plates $1.00 x9
-4.38 ring and pinion $75.00
-complete spider gear set $25.00
-ifs steering box complete minus ball bearings $50.00
-power steering resevoir x2 $20.00
-push pull steering box $50.00 x3
-v6 brake master cylinder $30.00
-v6 clutch master cylinder $25.00
-22r power steering pump w/ bracket and idler pulley $50.00
-22r power steering pump idler pulley &bracket $10.00
-skyjacker shocks sas front 11" body $20.00
-skyjacker 3" lift trackbar drop bracket $10.00
-factory rubber brakline front $5.00
-factory bump stops $5.00 x4
-front sas spring bolt $5.00 x2
- front shackle x2 $5.00
-bottom trunion bearing caps x2 $5.00
-passenger side steering arm $5.00
-ifs pitman armm $10.00
-drivers and pass knuckle w/spindle&backing plate $60.00
-pass side caliper (2piston)x2 $10.00
-pass side backing plate $10.0
-97 chevy 4.3 vortec "spider injector" intake manifold $50.00
-90's 4.3 valve cover 10.00
-chevy 4.3 alternator $20.00
-95 f350 standard cab seatbeltsblue $30.00
-intake filter check valve $5.00 95 7.3 powerstroke $5.00
-taurus electric fan $15.00
Old Feb 2, 2011 | 09:14 PM
2DoorRunner's Avatar
I need a v6 t-case mount (the rubber mount, not the crossmember). 10 bucks shipped?
If i am reading it correctly, you have a complete 4.10 third? What kind of condition?
If i buy the diff, i will just make the trip to ellensburg and pick it up.
Thanks! Pics would be appreciated. PM if ya want, or just post them up on here.
-Jack
Old Feb 3, 2011 | 07:48 AM
RBX's Avatar
RBX
pm'd sent, and got your reply
thanks
Old Feb 3, 2011 | 04:27 PM
GreenFlames's Avatar
do you have the kitchen sink as well?
Old Feb 5, 2011 | 07:29 PM
juheRoaryota's Avatar
took the words right out of my mouth lmao
Old Feb 6, 2011 | 06:21 PM
hillbillyjake's Avatar
i saw where you have an "ifs driveline". doe sthis include the a-arms? i have an 86 truck and need the lower a-arms. shipped to 26452. thanks
Old Feb 7, 2011 | 10:05 PM
92toyEFI's Avatar
i need a 22RE engine if you can find 1 of those around there
Old Feb 13, 2011 | 01:32 PM
sandigan's Avatar
I'm interested in the pushpull steering boxes. Are any of them power steering boxes? Let me know.
Thanks.
Old Mar 13, 2011 | 05:20 PM
VANCE164's Avatar
do u stuill have a gas cap and transfercase mount? if so let me know i have a buddy that can get it from you if you dont mind dropping it off to him at e-burg tire
Old Mar 13, 2011 | 06:00 PM
thrice's Avatar
You have a PM.
Old Mar 20, 2011 | 06:09 AM
Gov't Mule's Avatar
I just sent you a PM about an oil pickup tube.
Old Mar 20, 2011 | 07:35 AM
Bojangles's Avatar
You selling your house to? haha.
Im going to subscribe to this for when i get my paycheck haha.
Old Mar 24, 2011 | 09:49 PM
ya, i can do that. give me a call or text. (509)607-9111.
Old Mar 24, 2011 | 09:53 PM
hey guys, ill get back to all of you as soon as possible. i just sold a ton of parts at a swap meet, ill have to figure out what all i have left and update my list.
Old Mar 25, 2011 | 05:02 AM
RL's Avatar
RL
I could use the toy tool kit. Let me know.
Old Mar 26, 2011 | 01:44 PM
yotarover's Avatar
any chance you have the bolts for the timing cover,water, oil pumps?
Old Jun 1, 2011 | 09:07 AM
jmitchell2008's Avatar
i was wondering if you had the skid plate and mounting bracket for the gas tank an 93 22re
Old Jun 1, 2011 | 09:16 AM
dropzone's Avatar
Fossilized
thread closed, OP hasn't been around in weeks and never updated this list
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
mdev126
Oct 4, 2015 04:48 AM
Fundy Rider
Jul 16, 2015 01:35 AM
