2nd-gen Rear Springs or Spacer
Old Mar 6, 2007 | 07:14 PM
axledeep's Avatar
Looking for aftermarket Spacers or Springs that will lift rear of 2nd-gen 4R approximately 1-1.5" above stock. I have new Moog coils, but they still didn't level the truck, so I want to swap them out for other springs or add a spacer. Thanks.
Jimmy
Old Mar 6, 2007 | 07:36 PM
yotasavg's Avatar
i'm getting the ome 1.5" lift spring. make sure to get the HD if you do it.
you could get a spacer, and it'd do the trick. but if you ever want to lift above where it sat off the lot, you wont be able to do it with a spacer and you'll have to buy new springs anyway.
get the lift spring. it's only $66.02: http://www.rocky-road.com/4runner.html
Old Mar 6, 2007 | 07:48 PM
axledeep's Avatar
That's $66 per spring, right? I'm needing to spend far less than $130 total, especially considering I wasted $70 on MOOG coils . I ran OME on my old Tacoma and really like it, but I'm going for cheap these days. Thanks for the suggestion though.
Old Mar 6, 2007 | 09:20 PM
glenyoshida's Avatar
I was looking at spacers to lift the back end up too. I ruled them out.
I have the Downey 1.5 inch HD (Heavy Duty) on the rear and I really like them. If you do go with springs you will likely need to get longer shocks too, fairly soft ones if you are getting the HD coils.
I bought them straight from Downey and they weren't cheap for both shocks and coils. I came in at $342.53 to my door but IMHO well worth waiting a little bit longer instead of the spacers.
Old Mar 7, 2007 | 07:50 AM
UKMyers's Avatar
I've got a set of Downey coils I took off my truck when I did my SAS. I still have to get the brackets off the pile o' axle on the floor of the garage. Your stock shocks are fine with the coils. It doesn't lift it any it just puts it back to where it was back in the day when it came off the showroom floor. PM me if your interested. I'll let em go at a good price. I want this junk gone it's taking up too much room.
Old Mar 12, 2007 | 04:48 AM
axledeep's Avatar
Still looking for used springs or spacers for rear of 2nd gen.
Want 1" - 2" of lift over stock.
Old Apr 10, 2007 | 05:02 AM
axledeep's Avatar
bump
Old Apr 24, 2007 | 07:36 AM
axledeep's Avatar
Up top
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
Nickdigg
Jul 7, 2015 06:04 AM
