22RTE block needed
Old Jun 16, 2007 | 07:29 AM
Turboz's Avatar
22RTE block needed
I cracked the #1 piston in my turbo toy and damaged the block. Looking for a rebuildable 22RTE block
Please email me at jjoswald@sbcglobal.net if you have one for sale.
I'm in Springfield, Missouri 65714
thanks
Old Jun 16, 2007 | 12:09 PM
cchinny's Avatar
22RTE engines
I have several turbo engines and parts. Make me an offer on whatever you need.
Old Jun 16, 2007 | 01:45 PM
Turboz's Avatar
I got your email and replied . . . Thank you
Old Jul 2, 2007 | 07:35 AM
4x4yoda's Avatar
i have one too. its a short block adn needs rebuild. i'm in michigan
Old Aug 6, 2007 | 06:24 AM
dj86515's Avatar
Hi,
Will a stock 22RE (1995) block replace a a 1986 22RTE block?
Old Aug 6, 2007 | 02:07 PM
cchinny's Avatar
Nope. The 22RTE block is different.
Old Aug 6, 2007 | 03:07 PM
ewong's Avatar
I thought that the later "laser blocks" could be machined to meet turbo specs
-- drill the oil drain hole and tap for two studs
(dunno what else is different)
Old Aug 7, 2007 | 05:33 AM
dj86515's Avatar
Where do I look up additional info. for machining non-turbo blocks to make it compatible and will a hairline crack on the exhaust manifold make a difference? If so, who has one and how much (block and manifold) to 86556. I'd like to keep it turbo-ish, otherwise reg. 22RE. Thanks for your knowledge.
Old Nov 22, 2007 | 08:38 AM
Turboz's Avatar
Bump. My truck is still sitting (dead) in the garage and I really need to get this thing fixed - It has the factory 22 TRE setup in it.
As far as using a 22RE block, I don't know about drilling and tapping oil lines for the turbo. I'm guessing the water lines from the turbo would just bolt on to the RE block?
My OEM Turbo block could be re-sleeved since only the #1 cylinder has damage to it. I think the stock CT-20 started to disintegrate and a piece of metal went through the intake tract and put a crack in the #1 piston. I put the TEC kit on it and it didn't run any better but I got my foot into it and heard a pop. Turns out I blew a small piece of the #1 piston out and it gouged the cylinder wall - the blow by pressure was causing oil to come out the breather on the valve cover
The truck is in Springfield, Missouri (65714) and I'm back and forth from there to Los Angeles for work
Here is a picture of it out at Superstition Mountain in Southern California
Old Nov 22, 2007 | 04:00 PM
cchinny's Avatar
Short block
Still have my short block 22RTE. Been sitting in my garage 2 or so years now. Let me know if you are interested. Also have a complete engine that could use a rebuild.
Old Dec 9, 2007 | 08:29 AM
Turboz's Avatar
could you quote a price shipped to 65714?
Old Dec 25, 2007 | 03:28 AM
cchinny's Avatar
Turbo Block
$100 for the block and you arrange/pay for shipping from 03766.
Old Dec 25, 2007 | 10:33 AM
Turboz's Avatar
I have never shipped anything like this before. I'm getting quotes in the $300 dollar plus range.
Anybody know a good freight service to use that has reasonable pricing?
Old Dec 26, 2007 | 06:14 PM
4x4yoda's Avatar
dayton freight
Old Dec 28, 2007 | 08:41 PM
rob17san's Avatar
thanks
I have a complete 22RTE engine with bad turbo. In Denver CO. Make an offer. Its running well actually.
Old Jan 1, 2008 | 08:27 AM
Turboz's Avatar
I dropped over 3k rebuilding mine a few years back and did it right. I'm planning on keeping this truck so I want the engine to be tight. How many miles does your engine have on it? I'm assuming it would need a rebuild. All I need is a block (since I already have a turbo truck) so all the other parts like injectors, throttle body, head . . . are not needed. I only want to spend a couple hundred (+shipping) and I hate to lowball so let me know what you would accept for it.
CChiney - the cheapest quote I can get from Conn is $340 - Cant afford that
Originally Posted by 4x4yoda
dayton freight
Based on their webpage, Dayton freight doesn't go up to Conn.
Old Jan 2, 2008 | 09:57 AM
cchinny's Avatar
Turbo Block
I have to double check, but the truck the engine came out of had 220k on it, but a new rebuilt engine was put in at 120k so I think there are 100k on the block. I have the paperwork. It may be less. No more than 100k though. It has been sitting a few years now.
The other engine I have is complete and has 290k on it. I can strip it down to the block if you like.
$100 and shipping for either. How much will FED EX freight charge? $100 and shipping barely makes it worth my time getting it on a palate and getting it over to fedex. It will probably need to be freighted to the fed ex office near you.
Old Jan 2, 2008 | 02:31 PM
Turboz's Avatar
I can go higher than $100 for the block, but I would hate to spend $300 on shipping
Anybody know the Pro's and Con's of resleeving a cylinder?
Old Jan 3, 2008 | 08:19 PM
kneedownnate's Avatar
Did you ask this guy? https://www.yotatech.com/forums/f107...39/index3.html
There's also a rebuilt turbo block on ebay for $500, but it's in redding, ca.
Old Mar 13, 2008 | 05:52 PM
Turboz's Avatar
TTT
Still need this part
