Tire Suggestions please
Old Mar 12, 2010 | 06:08 PM
moneyshot's Avatar
I have a 97 4runner with a 3.4 in it. I just added a 2.5 coil spacer lift and 1.5 wheel spacers. I have the factory 16x7's which I would like to keep for the time being. So my question is what is the best size tire to run, I was thinking of 33" equivalent (305/70/16) but I'm not sure about width and the whole rubbing issue.
Any Idea's??????
Old Mar 12, 2010 | 10:38 PM
mightymouse's Avatar
search the what tires will fit thread you'll get your info there.
Old Mar 13, 2010 | 05:38 PM
pb4ugotobed's Avatar
With a 7 inch wheel, I wouldn't go any more than a 285/75/16. Any wider of a tire than that and you'd be better off going with some wider wheels. To do a 305 or a 315 i'd recommend at LEAST an 8" wide wheel, a 10" wheel would be preferred.
Old Mar 14, 2010 | 06:11 AM
moneyshot's Avatar
I know ideally a wider rim is better, but I know a couple people that have been running 12.50's or metric equivalent on factory 7 inch wheels and have never had a problem. I know its probaly pushing it but I'm building the truck in stages ($$$) and would like tires now and can always do wheels later.
Old Mar 14, 2010 | 06:32 PM
You can pick up a set of 6 lug wheels on craigslist for like 100 bucks. I don't know if you could fit a 15" wheel, but if you could that would be ideal for cheap, vastly available tires. I picked up a set of 15x10" wheels for 50 bucks with a set of old 35's on them. I gave the 35's to a buddy cause I don't need 'em, but you see where I'm goin with this...
Spend a little extra, be done with it, and do it right. Personally, I'd never run a tire that is almost twice as wide as the wheel.
Old Mar 14, 2010 | 08:41 PM
^99runner^'s Avatar
pb4ugotobed is correct. also i think you would have some rubbing issues with the 305. i ran them on my tacome with a 3" lift - rubbed the frame.... had 16x8 and put a 1" wheel spacer - rubbed the wheel well.... put a body lift on - problem solved
Old Mar 14, 2010 | 11:23 PM
rocket's Avatar
Any Idea's??????
285/75R16's. They fit and work well on factory wheels but even better with 16x8 aftermarket wheels if you ever decide to change.
Old Mar 15, 2010 | 02:52 AM
moneyshot's Avatar
Thumbs up
Thanks for the input guys! I see the 285/75/16 equals about 33x11.6 so that should be perfect. I cant fit 15's because of calipers so thats why I was having a hard time trying to figure out best metric size.
Flying91
45
Apr 11, 2024 04:39 PM
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
priest16
15
Aug 6, 2015 07:43 AM
DrZero
18
Jul 24, 2015 11:31 PM
