Tire rubs my a-arm
Old Nov 14, 2009 | 10:31 PM
krawnic's Avatar
Tire rubs my a-arm
Just barely on my passenger side tire rubs the upper a-arm. Im running 33x12.5 bfg km2s on stock 15x7 rims. I dont really know what backspacing ill need when i get new rims, I'm sure this has been covered before, but I need to get this problem solved quickly so any help would be appreciated.
Old Nov 14, 2009 | 10:34 PM
Elton's Avatar
find a local place that has 6x5.5 1/4'' wheel spacers might be the ticket there cheap too
Old Nov 14, 2009 | 11:15 PM
JamesD's Avatar
You can buy them at Advance Auto for $20 a pair. Mr. Gasket makes them. You will have to order them though and they should get them in the next day or so. Part number: 2376
James
Old Nov 14, 2009 | 11:17 PM
Elton's Avatar
dang 20 bucks .. i thought its better to have a 12.5 wide tire on a 8'' wheel ?
Old Nov 15, 2009 | 06:35 AM
kcpanages's Avatar
my rule of thumb i stick by is if my tread is 12.5 or wider i stay with a 10" wide rim.... less than 12.5 i stay with 8" wide rim
Old Nov 15, 2009 | 10:56 PM
krawnic's Avatar
I'm not going to bother with wheel spacers seeing as wheels are fairly inexpensive. So should i go with a 10" i don't plan to ever go wider that 12.5".
Old Nov 16, 2009 | 12:15 AM
muddpigg's Avatar
Down side of 10 rims is that the bead may not hold as well if you air down, of course there bead locks. But wider rims and wider tire may rub more with out lift but the do may lifts to compensate. Only cost time and money.
Old Nov 16, 2009 | 04:42 AM
krawnic's Avatar
yeah I dont really see the point in going with 10" wide rims. Im gonna go with 15x8, but i still have no idea about what backspacing i need
Old Nov 16, 2009 | 11:26 AM
JamesD's Avatar
Kind of but you can SAFELY run a 12.5 tire on a 7" rim. I have done it many times and so has many other people. Also I also used a 7" rim with a 275 tire on my Mustang without ANY issues at all. Just to give you another example. What I like about the stock rims is the factory offset is just about perfect and you save money by not buying any wheels. I would not go with a 10" rim. Then you will have fitment issues more than you would if you went with a stock 7" or aftermarket 8" rim.
James
Old Nov 16, 2009 | 11:54 AM
4Crawler's Avatar
Easy enough to measure and see what you have now:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/24.html
Old Nov 18, 2009 | 12:07 PM
highonpottery's Avatar
stock rims are usually around 4.75", so you probably want to get some 15x8 rims w/4" or 3.75" backspacing. i wouldn't go with 10" rims unless you like scratches.
Old Nov 18, 2009 | 10:16 PM
krawnic's Avatar
lol, scratches dont really bother me, but im still going with 8". Guess I should around town tomorrow and see whats available. thanks for the input everyone.
Old Nov 29, 2009 | 07:31 AM
krawnic's Avatar
well nothing in town....http://www.summitracing.com/parts/CRR-3975860/
going to order these,
Old Nov 29, 2009 | 07:41 AM
xxxtreme22r's Avatar
good choice, black i hope. I love those wheels. cheap and purdy lol.
Old Nov 29, 2009 | 10:53 AM
krawnic's Avatar
is 6x5.5 the correct bolt pattern?
Old Nov 29, 2009 | 11:10 AM
4Crawler's Avatar
Yes:
-http://www.4crawler.com/4x4/4R_TechInfo.shtml#Wheels/Tires
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
Jamie4runner2000
Jun 20, 2016 09:13 AM
Scatterbrain
Sep 3, 2015 06:46 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
