Old Apr 21, 2016, 03:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Tire Repair and Maintenance
Print Wikipost
Tire Pressure
Old Apr 6, 2009 | 08:56 AM
TONYTACOMA's Avatar
Tire Pressure
What is the best tire pressure to run for wear? I seem to remember the factory recommendation being something like 26F / 29R or something crazy
like that. My door sill plates are worn off...
tia
Old Apr 6, 2009 | 09:00 AM
camo31_10.50's Avatar
well for best results...look on the tire sidewall....it will tell you the MAX pressure..if you want the better mileage..run your tires at max...i dont know if it affects wear on the tires...i run my super swampers at 45..front and rear..gets about 18 on the highway if im bein easy on her..('86 4x4 with a 22R and 5spd)..most of the time people run between 35-40psi though..
Old Apr 6, 2009 | 09:33 AM
94Runner4x4's Avatar
i try to stay in the mid to upper 30's
edit: but this question will open up all sorts of opinions and view points on the matter
Old Apr 6, 2009 | 09:59 AM
97ltd4x4's Avatar
Unloaded..32psi
loaded with weight for traveling 35psi..
Old Apr 6, 2009 | 10:00 AM
DIHOWARD's Avatar
36 psi all around.
Old Apr 6, 2009 | 10:12 AM
toyNG's Avatar
I usually run somewhere around 36-38
Old Apr 6, 2009 | 11:46 AM
X-AWDriver's Avatar
32 is usually the recommended tire pressure on most tires but it depends on the tires and the truck they are on. I run my Nittos at 36psi and have been getting good wear and ride out of them. Max pressure is for when the truck is loaded down and needs more pressure to sustain the weight but definetly bad for an unloaded truck or car.
Old Apr 6, 2009 | 09:36 PM
SoCalPaul's Avatar
tia
If your tires are stock or stock-like, use the factory recommended pressures.
Oversize tires are designed for larger trucks & have higher load capacities then your truck can handle.
My Nitto Terra Grapplers are available in 2 load capacities.
Load range D, load capacity 3000 lbs, 65 psi max.
Load range E, load capacity 3415 lbs, 80 psi max.
Those are per tire. A 4runner weighs about 4,000 lbs empty so these tires are way overkill.
To get maximum wear takes a little fiddling. You can start by drawing lines across the treads with a chalk or grease pencil. Drive straight on a flat surface for a few revolutions. If the lines are worn in the middle, lower the pressure. If the lines are worn on the side, raise the pressure.
This will give you a good starting point, but you will still have to monitor your tread wear & adjust pressure accordingly.
I run 28-30 psi in mine.
In my experience, a good alignment makes more difference for extending tread life. I get a lifetime alignment. Costs about 2-3 times a single alignment but you can go back as often as you want.
Old Apr 6, 2009 | 09:46 PM
Plumbrbob's Avatar
I run my TSL's at 20 psi lol
Old Apr 7, 2009 | 04:37 AM
emptypockets's Avatar
I've been running my 285's at 30 psi and they ride well and show a flat footprint according to the water test.
Old Apr 7, 2009 | 07:20 AM
J'S LTD 4RNR's Avatar
I run 34-35 psi for my 265/75/16 BFG Allterrains for DD use with great wear.
Old Apr 7, 2009 | 04:23 PM
91diesel's Avatar
I have been running load range 'E' tires on my truck for 9 years now (235/85/16 and 265/75/16) I usually run 60-65lbs and I like the way they ride, the mpg, and the tread wear. On my other truck with 265/70/16 I put them at 40 psi and almost get the same effect as with the one ton tires.
Old Jun 16, 2009 | 08:06 PM
kilgoja's Avatar
stock recommendation on my 2009 tacoma was 30 front and rear.....i run about 34 all around on my new tires and rims....i wouldn't go above 35...if you do it makes the ride very harsh when you hit bumps in the road and such...maybe air up the rears if you have a heavy load on them....but normally 32-34 is good
Old Jun 16, 2009 | 08:12 PM
dmorenoprieto's Avatar
I run 35psi on my 33x12.5 BFG ATs
Old Jun 17, 2009 | 04:04 PM
KVRunner's Avatar
I run 35psi on 33X10.5 BFG Mud Terrains
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
calderp
Jul 27, 2015 09:58 AM
itzmywife's
Jul 25, 2015 04:55 PM
skoti89
Jul 8, 2015 12:05 AM
