Thin wheel spacers?
Old Aug 25, 2009 | 10:40 PM
ESQ's Avatar
ESQ
Thin wheel spacers?
Ok, here is the situation. I mounted up my 285/75R16 Goodyear Duratracs on my stock rims. Beautiful tire, by the way
They rub on the frame rail at the back of the front tires when I turn the steering wheel completely to one side or the other. Interference is less than 1/4in. I also get a bit of upper control arm rub at full droop.
Now here is the question: can I safely run the thin 1/4in spacers? I don't want the larger ones that have studs pressed in. I don't need/want the tires to stick out another inch per side as the tread block edge sits almost flush with the top of the fender flares.
The ones that I've seen for sale say "Not for use in offroad vehicles". I currently have 1in of thread engagement on my wheel lugs. I would drop it to 3/4in with the spacers. Is that sufficient? I couldn't find any info on this site after searching.
Thanks in advance, guys!
Old Aug 25, 2009 | 11:06 PM
SWPERIC's Avatar
ive been running 1/4 wheel spacers for over a year now with no issues. i was thinkin about going to the one inchers but these are all i need to clear my tires and it still keeps them just under the fender flares. sorry thats a little off topic. get em. just check torque regularly.
Old Aug 25, 2009 | 11:12 PM
malteserunner's Avatar
x2 on re-torquing them. Any time you run spacers, it's a good idea to check the torque regularly.
Old Aug 26, 2009 | 06:54 AM
4Crawler's Avatar
I've run 1/4" wheel spacers on and off for probably 12 years, on- and off-road, no problems, as long as you have enough threads for the lug nuts to grab onto and check the torque periodically.
Old Aug 26, 2009 | 08:59 AM
ESQ's Avatar
ESQ
Great. 20mm of thread engagement remaining (i think they're M12s?) should be plenty. What brand do you guys recommend?
Old Aug 26, 2009 | 09:48 AM
HazMat's Avatar
Check out wheelers offroad. They sell them for 5 bucks a piece.
Old Aug 26, 2009 | 10:04 AM
ESQ's Avatar
ESQ
Sweet. Ordered.
Old Aug 26, 2009 | 07:31 PM
Matt16's Avatar
Lordco sells them for $7-12 IIRC. They do make your steering want to follow grooves in the road too due to you alterning the scrub radius (http://www.familycar.com/Alignment.htm). I'm picky, this bothered me, but probably wouldn't be noticeable to most people.
Old Aug 26, 2009 | 08:23 PM
85excab's Avatar
big o tires sells the 1/4" for less than $4 each
Old Aug 26, 2009 | 08:49 PM
SWPERIC's Avatar
i got mine at pepboys. they were kinda pricey but i had to have them right away.
Old Aug 28, 2009 | 05:09 PM
ESQ's Avatar
ESQ
I doubt the scrub radius would be noticeable on such a wide tire with only 1/2in wider track. It also puts the distance between the tires on each axle back to equal length at rest given the suspension lift.
punks_is_4x4
Aug 21, 2015 01:35 PM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
Yotoder865
Jul 9, 2015 07:51 PM
