Rim Width for 33x10.5x15 BFG's?
Old Jun 2, 2009 | 07:39 PM
OutlawMike's Avatar
Gents,
I have searched on this, but can't find much on a rim width recommendation for 33x10.5x15's. 15x7 or 15x8. I am buying new rims, black rock crawlers.
Thanks,
Mike
Old Jun 2, 2009 | 07:50 PM
TOYOTA 1's Avatar
id go with the 8's.. the 7's would give you a tighter bead, but the 8's give you the option of running wider tires later on if you want. plus i ran my 35"x10.50 boggers on 8's and they were fine. its only an inch lol
Old Jun 2, 2009 | 07:52 PM
Fink's Avatar
Moved to Tires/Wheels.
TOYOTA 1 is right on.
If it were me I'd go with 8"ers.
Gives you more options later on if you want to go to a larger tire and will be easier to sell later on if the time comes.
If you're sure you aren't going to go bigger later on then I don't see why not to go with a 7" rim.
Fink
Old Jun 2, 2009 | 08:25 PM
scuba's Avatar
Not to mention if you have stock 7" wide rims (isnt that what most yota trucks are ?) the tire will bulge alot, Not a big problem with 10.5's but if you go wider you could rub on A arms and stuff
Old Jun 2, 2009 | 09:37 PM
kcpanages's Avatar
8" would be ok with a lil off-set. at least u can go 12.50 at most. dont go 10" wide with 10.50. u will tear ur rims up. if u want 7" paint ur stock rims and save ur cash
Old Jun 2, 2009 | 09:57 PM
4Crawler's Avatar
I run mine on stock 15x6 wide wheels:
http://www.4crawler.com/4x4/BFG_AT_KO.shtml
BFG lists recommended widths of 7"-9":
- http://www.bfgoodrichtires.com/specs...t-a-ko/44.html
Old Jun 3, 2009 | 08:29 AM
OutlawMike's Avatar
Thanks guys,
I think I will go with the 8's, as that will give me the option of going wider down the road.
Mike
Old Jun 3, 2009 | 10:00 AM
TOYOTA 1's Avatar
thats not becouse of the width, its becouse off the offset.
Old Jun 3, 2009 | 12:07 PM
Fink's Avatar
Backspacing is also another big factor in rim fitment.
Fink
Old Jun 17, 2009 | 07:57 PM
bullcrew's Avatar
stock 7"rs
Old Mar 16, 2010 | 04:52 AM
Jamey's Avatar
4 Crawler, I've been thinking of doing exactly this with the stock wheels on my '86. Do the tires wear funny in the center from being ballooned, or can you not really tell the difference...? (I did read your page that you linked to, but was unclear what exactly resolved the balloning.)
Also, did you have to run a wheel spacer to prevent the tires from rubbing the frame at full turn? I'd go with 33x9.5's instead, but they don't sell the mud terrain in that size, and back home in AK I grew to intensely dislike the A/T tread on ice and in mud. (which is all we had there lol) Being in AZ now there's no ice and barely any mud, but it's ingrained at this point lol.
Old Mar 16, 2010 | 07:30 AM
4Crawler's Avatar
It takes a little work to keep the tread wear even on 8" rims. I'll usually run them around 25 psi around town then run the pressure up for longer road trips. Then off-road, the outer tread usually gets worn down more than the center so overall they wear fairly even. I have run various spacers over the years, maily to keep the front tires off the springs and the rear tires off the frame.
Old Mar 16, 2010 | 08:04 AM
Jamey's Avatar
OK thanks
That answers my question then... I'll probably just want to go get wheels with less backspacing and a proper 7 inch width. That'll also give me the option of going up to 16's and running a 255/85R-16, which there seems to be a wider variety of.
muddpigg
Nov 2, 2015 05:36 AM
Cycles
Sep 29, 2015 06:37 AM
mat
Sep 17, 2015 11:18 PM
Dparr2ndgen
Sep 8, 2015 01:06 PM
AkitaDog
Sep 3, 2015 09:01 PM
